ANC buzzing on passenger side
Old Jun 7, 2023 | 11:18 AM
deadhead21's Avatar
I just recently got an 05 RL and I’m hearing a buzzing noise from the passenger side of the car. I did some research and found that it was the ANC module and I need to unplug it. Does anybody know where I can locate it? I know it is on the passenger side in the trunk, but I don’t know what I should be looking for to unplug. I have seen diagrams of it but if some could just tell me where it is that would be very helpful.
Old Jun 7, 2023 | 11:45 AM
deadhead21's Avatar
I
I know that it is somewhere around here if anyone can let me know where I can find it, that would be very helpful
Old Jun 7, 2023 | 12:59 PM
HEAVY_RL's Avatar
https://www.google.com/search?q=Acur...&bih=706&dpr=2
Old Jun 7, 2023 | 01:00 PM
HEAVY_RL's Avatar
https://acurazine.com/forums/2g-rl-a...-tools-814274/
Old Jun 7, 2023 | 01:17 PM
deadhead21's Avatar
Thank you. I was able to find these
Old Jun 7, 2023 | 02:58 PM
HEAVY_RL's Avatar
Cool, the link I shared will allow you to just turn it off before digging in so you can confirm that is the issue.
Old Jun 7, 2023 | 04:03 PM
deadhead21's Avatar
I tried the systems diagnostic test to turn off the ANC module and it worked, the buzzing stopped. Once I am back from work, I will start on the module removal process. Thank you
Old Jun 8, 2023 | 04:19 PM
HEAVY_RL's Avatar
right on, take pics to help the next person
Old Jun 8, 2023 | 09:12 PM
deadhead21's Avatar
so I was able to do it but didn’t stop to think to take new pictures, but I can explain with the pictures below. You first will need to remove the 3 bolts which are circled in red below. They take a 10 millimeter socket wrench. Then i circled in red about where you should find the module you need to unplug. It is connected to the amplifier and should look like the other attached image. You just need to unplug the wiring harness to the module on the side of the amplifier then re-assemble. Be careful of the fiberglass insulation from under the trunk liner, I was being dumb and rested both elbows on. After all was said and done, I now have no annoying buzzing noise
Kman20739
4G TL Problems & Fixes
Mar 30, 2017 10:05 PM
sysfailure0x5a
Nov 15, 2011 07:27 PM
Mitch89
2G RL Photograph Gallery
Jul 18, 2011 06:32 PM
media_mogul
Feb 5, 2009 12:04 PM
