I-027: DIY: ANC Disable for aftermarket sub with NO TOOLS
Old Apr 3, 2011 | 05:05 PM
Carbon Legend's Avatar
Here is a little DIY i through together so those of you who have large hands like my self know its a pain to get to the rear ANC mic to disconnect it.
Here is a way you can do it without using any tools just need your keys and your hands
http://www.youtube.com/watch?v=cVRMEtRnNEQ
Old Apr 3, 2011 | 09:02 PM
HEAVY_RL's Avatar
Great vid.
Old Apr 4, 2011 | 05:52 AM
miner's Avatar
Nice DIY - thanks.
Old Apr 4, 2011 | 07:19 AM
EL19's Avatar
Wow, wish i would have seen this before I went back there fooling around. I almost lost the 3rd brake light clips LOL Great vid, going to try this tonight
Old Apr 4, 2011 | 08:53 AM
HEAVY_RL's Avatar
The only thing to remember is you might have to turn it off for both Key fobs.
Old Apr 4, 2011 | 03:30 PM
i have not tested both keys i will verify it tomm when i do some work to the car.
Old Apr 7, 2011 | 11:35 PM
oo7spy's Avatar
Has anyone been able to get it to remain off? I have to turn it off every time I start up. Not very hard, but annoying nonetheless.
Old Apr 8, 2011 | 11:49 AM
HEAVY_RL's Avatar
oo7 just curious, does your car say "welcome driver 1" when you get in?
Old Apr 8, 2011 | 12:31 PM
oo7spy's Avatar
Yep. I keeps all of the radio settings but not the ANC setting.
Old Sep 28, 2011 | 11:20 AM
theNHBRL's Avatar
hey carbon, has these settings remain for you or is it like oo7spy, that you have to redo the step every time you turn on the car?
Old Sep 28, 2011 | 04:47 PM
I am not experiencing any burping of the sub or the 50hz humm. as far as i know the rear ANC mic is still connected. when i go into my diag mode anc shows off for me.
Old Sep 29, 2011 | 11:01 AM
oo7spy's Avatar
Maybe a change due to MY? NHBRL, try it and see if it sticks. If it does, this is definitely the easiest route to go. Mine always said, "ANC ON" when I started the car.
Old Jul 17, 2014 | 01:23 PM
daze05rl's Avatar
im also experiencing the need to turn it off every time I restart the car and my fob is linked to driver 1 so I know its not that any one figure this out?
Old Jul 17, 2014 | 01:55 PM
oo7spy's Avatar
Disconnect the ANC module harness from the Bose amp in the trunk.
Old Jul 17, 2014 | 08:15 PM
Mike734's Avatar
Why do you want to disable ANC? When I cover the front mic with my finger there is a very noticeable hum that I assume is road noise and that the ANC system was developed to cover. If something has happened to cause a burp or 50 hertz hum why is it not possible to address that issue? Too expensive? I already think the car is too loud on the road. Doesn't disabling the ANC system just make it that much louder?
Old Jul 17, 2014 | 08:48 PM
If you have a aftermarket subwoofer it will make a humming sound. so by disabling the ANC it prevents the 50hz hum
Old Jul 18, 2014 | 10:34 AM
daze05rl's Avatar
thanks 007 spy im going to get on alldata right now and get a diagram to see wich one it is.
Old Jul 18, 2014 | 11:41 AM
daze05rl's Avatar
ok I tried looking everywhere online to see which plug it is or harness and cant seem to find it I know how the bose amp looks cause I tapped into it for the aftermarket amp and remember a couple plugs I just don't want to disconnect the wrong one. does anyone have a picture or something more specific also whats with the whole disconnecting the mics?
Old Jul 18, 2014 | 11:43 AM
daze05rl's Avatar
nvm guys sorry just found it
Old Jul 19, 2014 | 07:41 AM
oo7spy's Avatar
To disable you have to disconnect either the mics or the harness. No need to do both.
Old Jul 20, 2014 | 05:01 PM
daze05rl's Avatar
Pulled the plug from the module all gone now
Old Jul 2, 2015 | 06:57 PM
dre707's Avatar
Can anyone show me what the anc module looks like and what to unplug from device since I was only able to disconnect the rear mic but not the front mic. I can get into the Bose amp so it should be easy
Old Apr 16, 2016 | 02:24 PM
Masta120's Avatar
I recently got a 2016 RDX AWD Advance, and noticed the sound system was lacking in bass. I followed the steps in the following thread to disable the ANC, and it definitely made an improvement:
https://acurazine.com/forums/audio-b...er-car-919478/
However, whenever the car is turned off and then on again, the setting resets and ANC gets re-enabled.
Anyone know how to disable this permanently, without having to mess with the mic or the module itself? Thanks.
Old Apr 17, 2021 | 07:58 AM
Geezey617's Avatar
Anc
hey Did you ever find the wire connected to that stock amp for the anti-noise cancellation to disconnect pics please
Manimal_Forever
Nov 12, 2012 09:16 AM
NiteQwill
28
Mar 15, 2011 08:29 PM
Dantes
Jun 10, 2004 01:03 PM
