Won't start
Old Nov 25, 2010 | 05:23 PM
Are El's Avatar
Won't start
So we finished T'giving dinner, piled into the RL to head off to see some friends, and it won't start. Turn the key, makes a couple of clicking noises, and afer a few seconds, it stops.
Don't think it's the battery, as all the lights & accs seem to be on. But the Navi screen keeps asking for the code before allowing access.
It's an '06 with 47K miles.
Any ideas out there?
Old Nov 25, 2010 | 06:20 PM
Are El's Avatar
Additional info:
The electronics are freaking out out. At various times (and intermittently) trying to start it, the Navi always asks for the PIN, the radio won't come on, the Navi screen blinks the Acura Link logo then goes blank completely, the info display warns me to check ABS and VSA.
Old Nov 25, 2010 | 06:45 PM
neuronbob's Avatar
Trust me, it's the battery. This happened to me while i owned my RL. This is a very common issue in the RL as the OEM Delco batteries suck. Put in a new battery and you should be golden.
Old Nov 25, 2010 | 06:48 PM
Are El's Avatar
Thanks. But date code on the battery is Feb 2010. Surely it isn't bad yet?
Old Nov 25, 2010 | 06:56 PM
neuronbob's Avatar
It could be, or you could have a current leak somewhere. The latter also happened to me during my RL ownership. Again, though, the OEM batteries really suck.
Best thing to do is to have the battery tested at the dealer. If it's bad, then you need a new battery and the story is over. If it's not bad, then the dealer needs to hunt down a current leak. In my case, it was in the rear trunk release (installed by the dealer). The Bluetooth radio is another frequent cause for current leak, but honestly it could be any electrical part.
Old Nov 25, 2010 | 07:13 PM
Are El's Avatar
Thanks. The headlights don't dim, so maybe the current leak is the deal. Can't get the radio to power on now at all.
Old Nov 25, 2010 | 07:39 PM
Megatron's Avatar
The easy thing to try right away is to JUMP it. If it starts, it's battery related. If it doesn't, it proves you have other troubles.
Old Nov 25, 2010 | 09:02 PM
HEAVY_RL's Avatar
As could as its been getting up there, I say battery too.
Whats the CCA on your battery?
Old Nov 25, 2010 | 09:06 PM
nsx_2k's Avatar
Yup, mine only had 27K miles and it was the battery. The electronics will do the craziest things. Replacing the battery will resolve your issues.
Old Nov 25, 2010 | 09:16 PM
Are El's Avatar
Acura battery and the punchouts say Feb 2010.
Old Nov 25, 2010 | 09:21 PM
HEAVY_RL's Avatar
if the punch outs are from Feb take it back to them.
Old Nov 25, 2010 | 09:58 PM
Are El's Avatar
For sure. Are these batteries this bad? If so, I certainly don't want another one.
Old Nov 25, 2010 | 10:32 PM
HEAVY_RL's Avatar
Well, IMO there are better batteries than the stock one.
BUT just because it has a new sticker on it doesn't mean the battery was ever really good from the start.
There are a lot of variables, and you could have an issue with the car, none the less I think your symptoms are battery related.
Old Nov 26, 2010 | 10:11 AM
Are El's Avatar
Jump start and new battery have it up and running again. Now just need to make sure there isn't something draining it.
Appreciate everyone's help........especiallyy on a holiday. Cheers.
Old Nov 26, 2010 | 11:18 AM
rlerman's Avatar
could be alternator related, but haven't heard much about problems with them.
by any chance did you not turn the car off all the way. If you don't and leave it in ACC mode, it will drain it. When you jumped it, you should have taken it for a 15 min ride to let it charge back up. you could have waited a few hours and then tried to start it again. If it started right up, you would be good to go.
If it is a drain problem and you put in a new battery without resolving it, you are back to square one.
Old Nov 26, 2010 | 02:55 PM
Blazing GT's Avatar
A C U R A B A T T E R Y
if this is own your battery be aware that this battery will last 2 months! lol
its the battery.
shit, autozone batteries (Duralast) has a better CC lolo
Feb 25, 2020 09:57 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
