Recently changed headlights dead again
Old Mar 22, 2025 | 08:30 PM
missingsaga's Avatar
6th Gear
Hi folks, I'm new to the forum. I bought a used 2015 RDX in January. When I bought it, the passenger headlight (low beam) was dead. Got it fixed, but now two months later, it is dead again. What kind of issue am I looking at here and how much would it take to get it fixed for good so it doesn't happen so soon again?
Old Mar 22, 2025 | 09:12 PM
altair47's Avatar
How did you fix the headlight?
Old Mar 22, 2025 | 09:34 PM
6th Gear
I took it to the mechanic and they replaced the headlight. Paid about CA$200 for the part, if I remember correctly.
Old Mar 22, 2025 | 09:43 PM
altair47's Avatar
Buy a good TYC headlight, install an LED bulb and the headlight will last forever.
Old Mar 22, 2025 | 09:54 PM
6th Gear
Sorry I'm new to all of this. This is my first car, pardon any ignorance. So does this mean the whole assembly will have to be replaced and then a new bulb is put in? So the replacement I had done in January just didn't cut it and was a stopgap?
Old Mar 22, 2025 | 10:03 PM
altair47's Avatar
Let's start from the very beginning, did the low beam become weak or go out completely?
Old Mar 22, 2025 | 10:04 PM
6th Gear
If it helps, I was able to find the receipt for the work done in January. It was "HID headlight ballast right front"
Old Mar 22, 2025 | 10:05 PM
6th Gear
It went out completely and as mentioned above, the ballast was replaced.
Old Mar 22, 2025 | 10:08 PM
altair47's Avatar
In this case, we found out that you have HID headlights, this means that you can first swap the bulbs in the right and left headlights to make sure that the problem is not in the bulb.
Old Mar 22, 2025 | 10:12 PM
6th Gear
We will try that out and come back here with an update. Thanks for your help, appreciate it!
Berkshire
Sep 12, 2021 04:09 PM
ChillRobP
Nov 7, 2010 02:04 PM
CCColtsicehockey
Dec 9, 2007 12:59 PM
miclado
May 10, 2007 02:23 PM
sbuswell
Mar 30, 2006 09:42 AM
