Engine Mount Bolt&Nut Torque Spec
Old Nov 5, 2022 | 05:20 PM
Poorboy325's Avatar
Post Engine Mount Bolt&Nut Torque Spec
Does someone have the torque Spec for engine mount bolts of front, side, and rear engine mounts? I tried searching but they seem to vary by car. FACTORY SERVICE MANUAL is appreciated.
Vehicle model 2014 ACURA RDX
Namely:
#16, #15, #23, #14, #11, #12, #20 in illustration.
Bonus question: Do I need to replace the bolts for passenger side engine mount, even if they aren't rusty?
Last edited by Poorboy325; Nov 5, 2022 at 05:34 PM. Reason: forgot to include car model
Old Nov 6, 2022 | 01:10 PM
altair47's Avatar
#16,20 - 40 ft.lb
#11,12,15,23 - 47 ft.lb.
All these bolts are completely reusable
Old Nov 6, 2022 | 01:44 PM
Poorboy325's Avatar
Originally Posted by altair47
#16,20 - 40 ft.lb
Thank you!!! Are these specs from RDX service manual? Common knowledge?
Old Nov 6, 2022 | 02:35 PM
altair47's Avatar
Mitchell 1 ProDemand
Old May 5, 2025 | 11:00 AM
t0md0's Avatar
OEM or Aftermarket?
I know this question is a bit OT.. but I'm curious if you went with OEM or Aftermarket?
Old May 5, 2025 | 11:17 AM
IMHO, OEM is always best if you can fit them into your budget; however, if that is not possible & aftermarket is the only affordable option check out rockauto.
Find each mount OEM part # on the website below and shop them on RA.
Genuine OEM Acura Parts and Accessories Online - Acura Parts Warehouse
Old May 5, 2025 | 01:35 PM
t0md0's Avatar
Yeah.. I mean I figured OEM is the way to go if possible. I just recently replaced my front with Beck/Arnley from RA since the OEM is ridiculously priced. I don't regret it. But I was told by mechanic that he also recommended that I replace the others as well minus the rear (he thinks I can put that off for now).
Do you have any experience with Anchor, DEA, or Westar brands and which ones I should buy from RA? I might end up going OEM for the side mount but aftermarket for the upper and lower transmission to save some money.
Old May 5, 2025 | 03:53 PM
Looking at what's available, aftermarket wise, compared to OEM for the one motor mount & two trans. mounts DEA is the ticket since there is not much choice?
Now you get into the question of 'do I have the mechanic replace the rear one, while he is there, & just pay the $$ and be done'?
You don't mention how many miles are on the vehicle?
Old May 5, 2025 | 04:43 PM
t0md0's Avatar
Yeah I mean the only choices from RA are Anchor, Westar, and like you said, DEA. Was there a reason you picked DEA or it was just a toss up 🤣
As you can tell, the price difference between going OEM and aftermarket is huge. Honestly after fixing just the front I'm already darn happy, even with going aftermarket Beck/Arnley. Doing the others will be cherry on top I guess. And yes, I am honestly debating about just having him do all but if he says the rear can wait.. I might just listen to him.. and like I said, the car feels fine? I have a 2013 with 107K miles.
Old May 5, 2025 | 04:59 PM
When I searched those OEM part numbers above, on RA's part number search functionality, DEA was the only one's that came up?
Personally, I have used Beck/Arnley as well to replace the side engine mount on my automatic CL-S & was surprised it stated it was made in Japan.
When the front & rear crap the bed, Beck/Arnley will be the first considered, since they are 'kind of' middle of the road, price wise.
Old May 5, 2025 | 05:34 PM
t0md0's Avatar
Ahh you searched for specific OEM parts numbers. I did a search by drilling into the year, make, and model and it gave me other choices.
For the front Beck/Arnley was the most expensive one out of the other choices (mine was made in Malaysia btw) and I also read from another user they had a good experience so I went that route.
bdtl
Jun 12, 2016 07:52 PM
UTAH TSX
2G TSX Performance Parts & Modifications
Oct 9, 2014 06:47 PM
gdong
Nov 6, 2013 08:40 PM
kc1337
Sep 9, 2012 12:01 AM
CedNBHTL
Feb 26, 2007 02:12 PM
