Tranny shifting hard
Old Oct 9, 2010 | 10:51 PM
smaster's Avatar
Hey guys, I just did a 2x2 tranny fluid change and small outside filter change on my 01 3.2 CL; but my tranny still changes gears a little rough but shifts fine. Tranny shifts really hard on elevated drive ways. any ideas on what it could be?
I did not do a 3x3 chage i did the 2x2 and filter
Old Oct 12, 2010 | 05:43 PM
aznboi2424's Avatar
umm the reason we call it a 3x3 is because we change out 3 quarts of fluid each time for 3 times.
The way your saying is that you drained out 3 quarts of fluid but put only 2 quarts in twice so that means your 2 quarts low? Im just hoping you did 2 correct drain and refills instead of 3 but correct be if im wrong.
Old Oct 24, 2010 | 12:01 AM
smaster's Avatar
Yea, i did drained 3 and filled 3 only two times, meaning its full on fluid, i just didnt do a 3x3
Old Oct 24, 2010 | 12:02 AM
smaster's Avatar
i would need to drain 3 more quarts and fill 3 more quarts for it to be a 3x3
Old Oct 24, 2010 | 10:24 PM
MIKE8898's Avatar
Bonki Ehrite!
Kinda sounds like it could be a motor mount?
Old Oct 24, 2010 | 11:10 PM
smaster's Avatar
ill look into and get back with you, i checked out my tranny mount and its fine.
Old Oct 25, 2010 | 11:32 AM
NSXNEXT's Avatar
Obviously first inclination is it's the tranny.
I've had hard shiffts and it turned out the throttle position sensor (located in throttle body) was bad.
Honestly, your best bet is to wait until your throw a check engine light (CEL) then get the code red and report back to us.
Old Oct 27, 2010 | 01:06 AM
smaster's Avatar
Well all my mounts are fine, the 2 for the tranny and the 3 for the engine so im going to check my TPS tomorrow
Old Oct 28, 2010 | 02:27 PM
smaster's Avatar
My CEL came on, it came up p0108 which was the map sensor high air input it said. So i replaced the sensor and cleaned my TB while i had it out and the shifting is better but its still there.
Old Oct 28, 2010 | 02:55 PM
NSXNEXT's Avatar
Based on your last response I'm going to reiterate that I think the throttle position sensor is either bad or somehow got knocked out of adjustment.
http://www.iapdirect.com/product.php?productid=42003
Old Oct 29, 2010 | 09:11 AM
smaster's Avatar
well i know my TPS is in my TB so can i sitll test it with an odometer like other TPSs or do i need something special
Old Oct 29, 2010 | 12:35 PM
civicdrivr's Avatar
You can use a multimeter and read the voltage direct from the TPS or you can hook up a scanner and read it that way.
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
joflewbyu2
Oct 8, 2015 11:16 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
