Engine Question
Height - Oil pan to top engine cover - appx. 24 inches
Width - Outside pulley to edge of trans - appx. 34 inches
Depth - Rear exhaust mani to front exhaust mani - appx. 24 inches
This was on a 6 speed manual and is not 100% exact as I used a tape measure. Also, take in to consideration the orientation of the axle position on the trans in relation to your wheels. Also, I measured the trans too as I would assume your tranny will not bolt up to the 3.2.
Isnt the J30 in the CL the same J30 in the 6th and 7th gen Accords? So if you got the parts for the 3.0CL, the J32A2 should technically just bolt up, no? You can drop the 3.2 into the Accords, so I would think the same is true for the 1st gen CLs.
Its been done. I remember reading a members sig and it said that he has the j32 in their. He was going to boost it and had everything to boost it from a members 2nd gen. But the engine bay was didd and nothing fit
Thanks guys i appreciate it. I have the 3.0 so it will be easy if its a direct bolt on no prob then it will be a fun project for me...now i just have to get a 6 speed into my car when i get the engine...
The tranny will not directly bolt on to the 3.2...and it is suggested in the first gen to get a new one if you do any high performance mods. So it would be a wise decision for me to get a custom trans or see if the 6 speed trans from the CL-S will fit on the first gen
wusty23jd
09-24-2015 11:41 AM
Billu99tl
09-13-2015 11:30 AM
