Aftermarket Headers causing Oxygen sensor malfunction
Old Oct 27, 2010 | 08:50 AM
DC2*&*CL-S's Avatar
I swapped out my headers for an ebay set while doing the 05 TL trans swap on my 02 CL-S.
About a day later the CEL came on and was giving codes for both oxygen sensors and they both were replaced. CEL stayed off but returned a day later with the bank 1 heater sensor malfunction.
The codes always say its the heater that is malfunctioning.
- I thought adding some 02 sensor extensions which position them further from the exhaust flow would help, still getting CEL.
- I followed the wires back to check for any damage on the harness and found nothing.
- I have also used a couple of NEW sensors to eliminate the possibility of a faulty unit but as many time as I exchange them for NEW ones the code always returns.
ONLY thing I can think of is the headers, cause I did not get these codes prior to changing the old ones out.
Anyone had any similar issue with this, I have searched but found nothing.
Old Oct 28, 2010 | 01:31 PM
civicdrivr's Avatar
What brand sensors?
Old Nov 8, 2010 | 09:12 AM
kalisto2k1's Avatar
4th Gear
Hello,
Maybe the extra flow or heat throws them off spec. Could be the ebay headers too. There is a o2 sensor trick mod with diodes as an option if you can't get them to work but you want to keep the headers.
Old Nov 10, 2010 | 02:05 PM
DC2*&*CL-S's Avatar
I have tried OEM and Denso and universal. They all work a day or two and then start throwing codes.
I'm planning on selling the car and will probably just put the stock headers back with some NEW sensors. Insurance on 2 cars has been killing me and I rather keep my 4 banger Integra.
4drviper
Apr 23, 2025 07:13 PM
Charles Bennett
Jan 28, 2018 08:53 PM
RobbDizzle
Oct 15, 2015 11:16 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
