2001 CL type-S ABS/VAS lights on
Old Apr 18, 2010 | 12:24 PM
mrbeer69's Avatar
2001 CL type-S ABS/VAS lights on, should I be able to read the codes?
I can not find a blue two pin connector by the glove box...Do I need to take the glove box out?
I can not find the blue two pin connector on: http://techinfo.honda.com
Old Apr 18, 2010 | 01:17 PM
StreetKA's Avatar
tranny is going out man
Old Apr 18, 2010 | 01:40 PM
mrbeer69's Avatar
Why would you say that....I just replaced it 5k ago....
Old Apr 18, 2010 | 01:57 PM
98JDMCL's Avatar
Justin's
Was it a used tranny...
Old Apr 18, 2010 | 02:40 PM
mrbeer69's Avatar
rebuilt, 36k warranty. What are you thinking it is?
Old Apr 18, 2010 | 04:09 PM
celynka's Avatar
Sundance Gold in
Your tranny is not going out - you just have ABS system problem. ABS system codes can not be read by generic obd readers . There are few that can do it but these are top notch $200 devices like INNOVA 3160 or you need Honda HDS interface to read the codes. Probably one of the ABS wheel sensors went bad, just test them with regular multimeter. Could you explain more clearly why you are looking for some blue connector?
Old Apr 18, 2010 | 06:18 PM
mrbeer69's Avatar
Thanks for the info, why did I buy the Innova 3130...
I was looking for the blue connector because of this post ( I know, wrong years, but I could not find anything better):
Originally Posted by Nakamichi
Try getting the ABS Diagnostic Trouble Code (DTC), it could probably point you in the right direction. Or someone may be able to get you the troubleshooting steps.
How to get ABS Diagnostic Trouble Code (DTC)
1. Use a paper clip is similar conductive device to complete the circuit for the service check connector located on passenger's side under the dash.
Same shape as this, except on passenger side and blue
2. Turn the ignition switch ON (II) without the brake pedal depressed.
3. The blinking ABS light frequency indicates the DTC.
NOTE: If the DTC is not memorized, the ABS indicator will go off for 3.6 seconds, and then come back on.
4. Turn the ignition switch OFF, and remove the paper clip.
Old Apr 18, 2010 | 08:20 PM
mrbeer69's Avatar
celynka,
Have you ever used a INNOVA 3160 to get the ABS codes?
I was able to upgrade my 3130 to ABS code for $100. But it does not find any code on my CL.
Old Apr 18, 2010 | 08:24 PM
celynka's Avatar
Sundance Gold in
We still have that yellow connector ( SRS ) but not the blue one. For the scanners - only INNOVA 3150 & 3160 supports ABS
Old Apr 18, 2010 | 10:26 PM
mrbeer69's Avatar
celynka,
You did not answer my question: Have you ever used a INNOVA 3160 to get the ABS codes?
This site: http://www.canobd2.com/TechInfo/News...fo%2fNews.aspx
Sayes that:
Equus Products, Inc., is pleased to announce the availability of an ABS Firmware upgrade for its INNOVA® 3110 CanOBD2® Tool and INNOVA® 1303 and 3130 ScanTool – CanOBD2®. The optional upgrade is available to current owners of these select tools via the upgrade button from the included OBD-PC Link™ application. The purchase price of this upgrade is $99.99 (U.S.).
So I bought the upgrade online and did the firmware update, but can not get the codes and thus I ask again; Have you ever usaed a INNOVA 3160 to get the ABS codes? from an Acura?
Old Apr 18, 2010 | 11:09 PM
celynka's Avatar
Sundance Gold in
No I have not used generic scanners on my car since I got HDS unit
Old Apr 18, 2010 | 11:30 PM
celynka's Avatar
Sundance Gold in
Just did some quick research and looks like INNOVA covers only GM ,Ford and Chrysler. That sucks!
Old Apr 19, 2010 | 02:10 AM
mrbeer69's Avatar
That is why I asked, how much for HDS unit?
Old Apr 19, 2010 | 07:31 AM
celynka's Avatar
Sundance Gold in
I got myself chinese knock off from ebay. Original one is very expensive - used ones go sometimes for 1.5k . Check out this link: http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
mugen_kid
Nov 13, 2015 10:38 PM
Azonics
Sep 22, 2015 05:28 PM
Jpro
Sep 13, 2015 07:14 PM
3.5RLv-tec?
1/2G MDX (2001-2013)
Sep 7, 2015 11:00 PM
