Rattle, only during start-up and shut-down tho...
Old Mar 14, 2010 | 10:59 PM
SYLKIE's Avatar
Wye-Ey-Fore Sicks-Spd
I've gathered that this car has alot of rattles. However, I have one that is not the common sunroof/glove box/etc and I can't identify it. It very occasionally happens when turning on the engine, but more often occurs during shut-down, right as the engine finishes spooling down, just before it comes to a complete stop. It almost sounds like a loose part somewhere inside the engine or something. Only happens for a second. I've never heard it under normal idling or acceleration. Any ideas before I hit up the dealer?
Old Mar 17, 2010 | 11:35 PM
SYLKIE's Avatar
bump. anybody?
Old Mar 17, 2010 | 11:42 PM
Jacobpockros's Avatar
It's probably the exhaust pipes underneath your car hitting the heat shield.
Old Mar 18, 2010 | 09:00 AM
fuzzy02CLS's Avatar
Could be, or bad motor mounts allowing engine play, or a loose exhaust system.
Old Mar 19, 2010 | 04:42 PM
SYLKIE's Avatar
thanks for the replies guys. not a heat shield, just did headers the other day, and the exhaust was hanging perfectly. hanger was good too. can't be a motor mount, cuz i just did those as well (well, two of them anyway). it sounds like internal/external engine. i almost feel like it could be valves out of adjustment or something. but i dont think that makes sense, considering its only at shut-down.
Old Mar 20, 2010 | 01:59 AM
civicdrivr's Avatar
Intake.
Old Mar 22, 2010 | 06:23 PM
celynka's Avatar
Sundance Gold in
Rusted through or loose heat shield on the exhaust ... bur since you are in FL it might be loose
Old Mar 22, 2010 | 06:31 PM
98JDMCL's Avatar
Justin's
Maybe the motor mounts..they say when the mounts are going it applies alot of pressure on the front pipe..take it to the dealer and get it looked at it real quick...can cost you alot in the long run!
Old Mar 22, 2010 | 07:19 PM
i still vote heat shield....
Old Apr 18, 2010 | 11:31 AM
LiquidCLs6's Avatar
Intake.
x2 I think mine started after I installed my CAI. The mounting setup allows for quite a bit of movement.
Old Apr 23, 2010 | 08:32 PM
BAGII's Avatar
Intake.
civicdrivr hit the nail on the head. My AEM intake rattled at startup and shutoff. It hits against the hole that it goes down through into the bumper. Just shove something soft between body and intake.
marcelft
Jul 10, 2018 06:17 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
3GTLOwns
Sep 9, 2015 09:51 PM
