Functional Insert Vents
Old May 27, 2007 | 02:17 PM
SuperTrooper169's Avatar
In the Mid-South meow
Just a teaser picture but more to come on Tuesday. Crappy cell phone picture but you get the idea. I cut out the fake vents and replaced them with actual vents. I also painted the inserts and lower grill satin black to match my grill. I think the vents coupled with my AEM CAI gave me like 20 HP!
Old May 27, 2007 | 02:47 PM
horsepowercrzy18's Avatar
intake
very nice idea!
intake
how did you make the mesh stay? like did you glue it or tape it
Old May 27, 2007 | 03:24 PM
Thanks. I used plastic bonding glue. The mesh is plastic painted silver so it bonded pretty good to the plastic inserts.
Old May 27, 2007 | 03:36 PM
hey
also how did you take the plastic fog light inserts out?
Old May 27, 2007 | 03:39 PM
PM'd you back.
Old May 27, 2007 | 05:05 PM
m733l's Avatar
nice. i was thinking of doing the same thing but never got around to it.
Old May 27, 2007 | 06:11 PM
Sun Diego CL-S's Avatar
says "hello to my TLX".
it looks good. it certainly is functional for the Icebox/CAI's since the scoop is directly behind the bumper garnish. i haven't brought myself to do that yet. but it would paint the mesh black. this would work for you too.
Old May 27, 2007 | 07:40 PM
LOL, is that like "It puts the lotion on it's skin or it gets the hose?"
Well for you it'd look better black because you're NBP and blacked out, but for me I love the way it looks with my SSM. You'll see in the picts on Tuesday. It looks badass. But you're right, it should actually give me a sort of ram air effect with my CAI, but I'm sure it's very minimal.
Old May 27, 2007 | 09:22 PM
Okay, I have nothing to do, so I installed software for my digital camera on my home laptop, so here's the DIY.
Here's all the parts and tools needed. I took the bumper cover off because it's easier to paint the lower grill with it off, but if you're just doing the inserts you can just take them off with a screw driver without taking the cover off, but obviously it's easier with access to the back.
Here's the plastic gutter guard material I bought from Home Depot. It was $1.80.
First step is cut out the fake vents on the back of the inserts. It's crutial you go slow and try to make the cut as straight as possible, but if it doesn't come out straight you can sand, file or use an x-acto knife to level the back off. After everything is straight sand the inserts and spray with your color of choice. I choose Rustolium Satin Black to match my grill.
Figure out which way you want the diamond pattern facing. I went with the same direction as the fake vents on the inserts.
After cutting out a panel big enough to wrap around the back of the insert, bend the ends over the back. Not only will this make it nice and snug but it'll give more surface area for the glue to hold it on.
Next paint the plastic gutter guard material what ever color you chose. I choose a silver metallic to match my SSM.
Next I masked off the bumper cover to spray the lower grill satin black to match the inserts and my grill that I painted satin black a while ago. It always bothered me that the inserts and lower grill were a little more gray than the satin black of the grill. Problem solved!
After the paint and the glue (used a plastic bonding glue from Wal-Mart, but I'm sure any permanent glue like Gorilla glue will work) are dry reassemble everything and enjoy the finished product.
Old May 27, 2007 | 09:41 PM
CleanCL's Avatar
why dont you just take out the whole plastic insert and put mesh behind the opening?
Old May 27, 2007 | 10:10 PM
rondog's Avatar
Former Sponsor
Don't mean to hijack, but there are a few people doing it a little different than you. I think you should go back in and cit the hole a little bigger, to let even more air in, I liek the idea tho.
finally, this is how I ended up doing, just for a little contrast:
Old May 27, 2007 | 11:01 PM
Thanks for the suggestions. It's a total up-to-you kind of mod, so obviously we all have different likes and dislikes.
Well there's guides that are molded into the bumper cover (you can see them in the first pict) so it'd look kind of cheesy with those visible if you just attached material behind the opening, but I guess you could technically cut mesh to fit inside the opening flush with the bumper cover and some how attach it, but that would definitely take some skill to get them the perfect size and shape. Another reason I didn't do that was because the plastic mesh I bought wouldn't be big enough to fill the entire hole left from removing the insert. I'd have to go find another material. I also figured I'd just modify the inserts so if it didn't work either I could leave them without the mesh or just replace them. Plus call me crazy but I just kinda like the style of the inserts.
Not a hijack all all, Ron. I remember seeing your vents from a while back. I'm definitely not trying to say this is my original idea, I just figured I'd do a little DIY. I like how you painted yours to contrast the NBP. I'm happy with the way they are, I wasn't really too concerned about the actual functionability of them, ie taking in as much air as possible. I could go back and make the holes bigger but it's not like an inch or so will give that much more air flow. Plus it's just easier to make sure the holes are realatively the same size by just cutting the fake vent section out of the back because it's straight and not at an angle. Plus just like with CleanCLs suggestion the mesh sections aren't big enough to cover much more of a hole.
Old May 27, 2007 | 11:11 PM
kyle77777's Avatar
Gonna cost to catch up
Looks great, you really should paint the new vents black though. DO IT!
Also, you should have cleared your diffuser since you had the bumper off already IMO
Old May 27, 2007 | 11:17 PM
CleanCL's Avatar
there sure is mesh big enough, you just didn't look hard enough. ;]
i removed all the plastic in there and put mesh behind it.
again not to hijack your thread, but i did have a thread going around, something like "ronjon grill eat your heart out", lol. but i plan to go back in and shave those runners you are talking about to make the entire thing even and putting in some powdercoated mesh. i just haven't been motivated to do another project right now.
Old May 27, 2007 | 11:23 PM
kyle77777's Avatar
Clarrise
Can you put a before and after pic of the front. The paint looks the same on the bumper to me?
Old May 27, 2007 | 11:24 PM
Sure, I'll do it, right after I drop it. NEVER! :4x4&SILVERMESH4TW!!!:
Old May 27, 2007 | 11:27 PM
Oh, no doubt there's mesh big enough, but you're right, I scanned through Home Depot and found the plastic mesh and figured it'b be easier to attach than metal. Plastic seems to bond better to plastic verses metal to plastic. Post picts when you get around to it. I'm sure it'll look killer. Your car is sick as it is!
Old May 27, 2007 | 11:29 PM
lnarreola's Avatar
hi where all you guys get those fog light covers from i really needthem?
Old May 27, 2007 | 11:31 PM
PimpCL23's Avatar
contrarian in fashion
Ron and SuperTroop...
Nice jobs! i only wish i had a 2nd gen cl... oh well... my 1st gen will have to do
Old May 27, 2007 | 11:32 PM
Before
After
Old May 27, 2007 | 11:36 PM
kyle77777's Avatar
https://acurazine.com/forums/car-parts-sale-361/fs-03-cl-road-lamp-inserts-%2425-shipped-366525/
Old May 28, 2007 | 05:41 AM
m733l's Avatar
i really like the first one. i think i'll go with that idea
Old May 28, 2007 | 06:50 AM
fuzzy02CLS's Avatar
Looks good
Old May 28, 2007 | 08:37 AM
03silvertypeS's Avatar
looks good....i've been thinkin about doing this as well
Old May 28, 2007 | 03:57 PM
hey
looks awesome! im in the process of doin that right now!
Old May 28, 2007 | 04:14 PM
BigLizard's Avatar
Moderator Alumnus
Right on...now there is more ideas for noobs to look at when they want to go "roadlampless"
Old May 29, 2007 | 06:55 PM
JohnBlayz142's Avatar
Keeping the Stealth alive
Hmm....I like some of these ideas...
Old Jun 12, 2007 | 06:12 PM
nbennettksu's Avatar
i heart latin chicks
very clean front-end...no rock chips!
Old Jun 12, 2007 | 09:09 PM
RYANGP's Avatar
Not a doctor
looks good maaan; nifty idea
i never realized they '03 vents didn't let air through. that seems a little silly
if i ever decide to swtich my road lamps for the 03 inserts, i'll definitely give this a shot
4drviper
Apr 23, 2025 07:13 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
soupi
14
Nov 15, 2015 11:15 AM
12vancover
Oct 16, 2015 12:04 PM
hashbrown
Sep 29, 2015 12:13 PM
