XS Power, Manzo or Comptech Headers
Old Feb 7, 2019 | 03:15 PM
AcuraCl1's Avatar
I have an 03 Acura Cl 6 speed. Currently the only mods I have to the car is Eibach Springs/Struts and a JTC Customs Short Shifter.
I just purchased a set of the Magnaflow 14832 Mufflers, and plan to update all of the piping to 2.25" and deciding on whether i want to remove the resonator, or upgrade the resonator to Magnaflow and whether its worth it to upgrade the cat to a highflow.
I am in the process of purchasing some headers, as it appears I have 3 choices to choose from, XS Powers, Manzo, and Comptech. It appears the XS Powers run around $260 shipped, manzo around $120, and comptech $650. I live in TN, so CARB is not important.
What are your recommendations of these 3, as I would like to get the most power out of the headers as I can, One of the reasons I am upgrading the piping to 2.25" for the exhaust.
I will most likely be upgrading to a DIY 3.5" Cold Air Intake also.
Old Feb 7, 2019 | 03:29 PM
If you have sourced a set of CLS-6 Comptech headers for $650, then those would be the one's I'd get. Make sure they have the 'bend' in the rear manifold to allow for the rear motor mount bracket.
In the picture below:
Top set are for an automatic.
Bottom set are for the CLS-6.
Originally Posted by '03CLS6
Old Feb 7, 2019 | 06:55 PM
Iggy's Avatar
Manzo headers are complete crap! I made the mistake of trying them out, worst $120 I ever spent.
Old Feb 8, 2019 | 02:48 AM
lateralus's Avatar
i have a set of comptech and manzos for each of my cls6's the comptech flex pipe took a crap and needed to get a new one welded in... the manzo had to use better hardware and gaskets ... but other that the manzos have lasted 4-5 years without any issues..
i think any of those headers outside of a set of comptechs come out of the same factory ie manzo/srs/xspower/megan racing etc
Old Feb 11, 2019 | 04:07 PM
mattcl-s's Avatar
I installed XSP headers for 2 years now and have had no issues. I would recommend get them ceramic coated to minimize heat
Old Feb 12, 2019 | 01:18 PM
AcuraCl1's Avatar
Thanks, it appears the manzo are a little smaller, is this correct:
  • 1.5" Inlet
  • 2.25" outlet
XSP Headers:
  • 2.5" COLLECTOR, 2.35" INLET
  • ALL DIRECT BOLT-ON TO ANY AFTER-MARKET 2.25"-2.5" CAT BACK
I am going to upgrade the piping from the CAT to 2.25 removing the resonator to the Magnaflow 14832. Just trying to get as much flow as possible. What do you think.
Old Feb 13, 2019 | 09:16 AM
mattcl-s's Avatar
  • 1.5" Inlet
  • 2.25" outlet
XSP Headers:
why not just go 2.5? I did not that its much but 2.25 isnt much better than stock, also you might want to use a resonator it will sound very raspy unless you're going for that. I have a magna flow resonator 6inch round 36" long it will keep the drone down at freeway speeds
Old Feb 13, 2019 | 10:15 AM
AcuraCl1's Avatar
I was going 2.25 since that is the size of the inlet on the exhaust.
would u recommend just doing 2.5 for all piping and having it downsize to 2.25 at the exhaust inlet.
and for the resonator, which magnaflow one did you go with.
my exhaust is the 14832.
Old Feb 13, 2019 | 01:18 PM
Just an FYI.
If you go with either the Manzo or XS-P headers, the consensus is to not use the nut and bolt hardware provided from China.
It is advisable to get Grade 8 nuts and bolts from a local hardware store.
Review the thread below if you already have not; especially, post #22.
https://acurazine.com/forums/2g-cl-p...review-959686/
Old Feb 13, 2019 | 03:22 PM
AcuraCl1's Avatar
Thanks, I will definitely get upgraded hardware. Just trying to see if its worth $120 more for the XS Power headers over the manzos.
Old Feb 14, 2019 | 10:40 AM
TheWeez's Avatar
I Wanna Beer
XS Power use to be $120 shipped when I bought them.
Also, don't use the gasket they include. Buy new ones made by a reputable company. The ones included are thin and tend to leak. Gaskets are cheap, so it's worth getting quality ones.
Jonathan Hill
2G CL Problems & Fixes
61
Jun 2, 2019 12:15 PM
DaJaySterrr
Apr 12, 2017 12:13 PM
coopcoop30
Sep 18, 2015 05:11 PM
shawn.m
23
Aug 2, 2015 02:02 PM
J32A
Dec 20, 2005 12:13 PM
