Uni -Chip Owners Only Discussion Thread......
Old 09-13-2004, 01:13 PM
  #801
mrsteve's Avatar
Well I'm glad to see they are working with you.
Old 09-21-2004, 05:59 PM
  #802
AuCLSman's Avatar
update to my posts #775 & #797, recieved another updated "D" map chip with less fuel fuel removed in the 5k range and above. installed, did idle relearn and (6) wot runs in both "A" & "B" modes.
results: minor power gain is noticeable thruout rpm band from 2k-7k , however cels (intermittant flashing ) from 6.5k to 7k band only. the other notable item, the vehicle does not "leap" in power at vtech engagement , it is nearly linear in acceleration. then removed chip and harness and did (3)wot runs . no cel's , same pre-chip power with very noticable vtec engagement.
spoke to josh @ unichip, he will pow-wow w/ other tech's and try some other approach to solve.
to be continued.......... (any board mbr suggestions welcome)
Old 09-21-2004, 07:46 PM
  #803
mrsteve's Avatar
Have they checked the wiring harness?
Old 09-21-2004, 09:34 PM
  #804
///M POWER
darrinb's Avatar
i might get the d map too
Old 09-22-2004, 11:35 AM
  #805
AuCLSman's Avatar
mr.steve , yep, sent 2nd harness, installed and ran with different chips, same cel problem. any other thoughts/ideas?
Old 09-22-2004, 11:37 AM
  #806
mrsteve's Avatar
Do you know what the code is that is triggering the CEL?
Old 09-22-2004, 03:04 PM
  #807
AuCLSman's Avatar
mrsteve,
the codes as follows: po300 mutiple cyl misfire detected, po301 cyl #1 misfire, po302cyl#2 misfire, po303cyl#3 misfire, po304cyl#4 misfire, po305cyl#5 misfire,po306cyl#6 misfire. freeze code: po302cyl#2 misfire detected. pending code: p1399 mfg. specific powertrain trouble code. these are the initial codes detected when i installed the first chip. i have assumed all subsequent codes are cyl misfires. as the cels occur between 6.25k and redline
Old 09-22-2004, 03:05 PM
  #808
mrsteve's Avatar
I'm assuming you are way too lean. Put it on a dyno yet?
Old 09-22-2004, 03:12 PM
  #809
AuCLSman's Avatar
mrsteve,
the people at unichip feel the ecu is reading an erroneous crank sensor signal which is read as this misfire code. josh @ unichipstated that the pnp harness module had a capacitor (or resistor?) installed to mask this code in the initial design. thinking my harness was faulty, he tested a new harness and sent to me for install, which i did.
cels still persist
Old 09-22-2004, 03:15 PM
  #810
AuCLSman's Avatar
no dyno until i see this problem solved. i will say they have tried numerous solutions and the cels now only occur at 6.5k to 6.6k and above.
Old 09-22-2004, 03:18 PM
  #811
AuCLSman's Avatar
sorry i missed your post. lean, perhaps however i've not heard any substantive pinging , just cels and power seams consistant to redline
Old 09-29-2004, 02:44 AM
  #812
racersky's Avatar
i know this is an old thread and all but would a unichip work on a CL-P?
Old 09-29-2004, 05:36 AM
  #813
mrsteve's Avatar
Old 09-29-2004, 06:53 AM
  #814
racersky's Avatar
dam that's so gay. Than what do pplz with CL-P use? Nothing?
Old 09-29-2004, 08:21 AM
  #815
Not Asian
phipark's Avatar
nothing
Old 09-30-2004, 04:19 PM
  #816
Prez & GC, .Net
Dizzy's Avatar
Steve: how's the unichip working so far after all these months? Any changes? Still the same? We're about to get our shipment of Unichips over at V6P. Hopefully we won't run into the same problems the CL's have been having. Our test cars seem to run fine and we're about to test an S/C accord v6 w/ CL-S cams next week.
Any advice on what to look for as far as issues? Besides, the pinging, misfires, running lean, etc... So we should all be using 92+ octane?
Thanks.
Dizzy
Old 09-30-2004, 04:27 PM
  #817
mattg's Avatar
hopefully you guys won't be in for disappointment. nobody from our GB has been very thrilled w/ their gains.
Old 09-30-2004, 05:41 PM
  #818
dj5
dj5's Avatar
The chip definitely was not worth the investment. However, if I were going to buy the Unichip, I would buy the blank and take it to a custom tuner. Unichip charges $100 less for the blank and a custom tune costs around $150 - $200.
08KBP_VA
10-22-2019 01:55 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
Jimmy_D
10-07-2015 11:52 PM
xsilverhawkx
10-05-2015 11:00 AM
jmaxima03
09-27-2015 10:22 AM
Quick Reply: Uni -Chip Owners Only Discussion Thread......
