Sick Idea
Old Jul 4, 2003 | 09:17 AM
bigman's Avatar
'Big Daddy Diggler'
Sick Idea
What do you guys think if i went with a 2.25 inch pipe from the cat to a single muffler in the middle, out to the Y with no muffler with pipes on both sides and the tips. It would be the same exhaust bu with one muffler and dual outlets. How do you think i would fare torque wise, do you think it would make much of a difference. I am just trying to see whats up. Because me and a friend are gonna be using my car as a guinea pig for some things now.
Old Jul 4, 2003 | 09:34 AM
NSXNEXT's Avatar
My guess would be a slight gain in low-end torque due to increased backpressure, but a loss in high-end torque.
Or I have no f'in idea what I'm talking about. Either one.
Old Jul 4, 2003 | 09:40 AM
Smitty's Avatar
F the muffler... do stra8 pipes from the Cat... you will have enough back pressure... Just don't do 3 inch all the way... do 3 inch tips only...Totally badass...
Smitty
Old Jul 4, 2003 | 11:07 PM
bigman's Avatar
'Big Daddy Diggler'
anyone esle, c'mon
Old Jul 4, 2003 | 11:37 PM
beerknurd's Avatar
Busy Living
Make it 3" pipes up to the muffler, then 2.25 to the ends. THen make that one muffler a dual capacity muffler, ala G35.
so at low RPM's it would be a single exhaust ( stock back pressure) then it would turn to dual exhaust at high RPM and give you more HP.
Old Jul 5, 2003 | 10:33 AM
bigman's Avatar
'Big Daddy Diggler'
where the heck can i get a dual capacity muffler. Will running a sing exhaust reduce backpressure, or increase it.
Old Jul 5, 2003 | 11:09 AM
bigman's Avatar
'Big Daddy Diggler'
Old Jul 5, 2003 | 11:19 AM
Nicky Pass's Avatar
Fuct in the hed!
The Type S's exhaust is as high flow as it gets. If you alter it too much, something would probably get messed up somwhere.
Old Jul 5, 2003 | 11:35 AM
bigman's Avatar
'Big Daddy Diggler'
i have a p
Old Jul 5, 2003 | 12:51 PM
civic4982's Avatar
SHIFT_over.so.I.can.see
gains most likely would be minimal if not detrimental to power unless you were pushing more power out of it already (NOS, FI) that would cause more exhaust from exiting. I think the key restrictive part that people have been complaining about is that A-pipe or downpipe or whatever it's called.
08KBP_VA
Oct 22, 2019 01:55 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
Gout
Nov 2, 2015 12:22 AM
Houston
Oct 8, 2015 01:27 AM
