Replacing Brakes
Old Feb 7, 2007 | 05:13 PM
Sloth32's Avatar
Replacing Brakes
Ok so am waiting to get my brakes from Exelerate and then I will be replacing them my self (with some help) soon. I am not that knowlegable on cars and have never done this. I can't seem to find a do it yourself on the brakes and rotors for the second gen cl. So any help or advise will be appreciated.
Old Feb 7, 2007 | 05:24 PM
Bobbydoedoe's Avatar
I'm Cool
are you just replacing the pads? or both the pads and the rotors? Heres a DIY found on Google (most cars are similar when it comes to changing brake components)
http://www.automedia.com/Replacing/B...cr20050701bp/1
Old Feb 8, 2007 | 07:38 AM
DelawareCLS's Avatar
HTML Code:
https://acurazine.com/forums/showthread.php?t=186243&highlight=brakes
That'll get you through the brake pads themselves. Easy breezy.
I'm sure a search on "rotors" will turn up plenty of help on swapping them out.
Old Feb 8, 2007 | 10:50 AM
Sloth32's Avatar
I am doing the rotors and will do a search on that and see what I come up with. i have been told it is pretty easy, I just want to make sure I have the best idea as to what I am doing before I do it.
thanks for the help
Old Feb 8, 2007 | 01:17 PM
fuzzy02CLS's Avatar
Hardest part are the screws that hold the rotors on. You'll likely need a light touch & heavy hand or an impact screwdriver to get them off without striping them & having to drill them out.
2nd hardest are the caliper bolts. Sometimes they can be really tight.
After that it's cake.
Old Feb 8, 2007 | 02:19 PM
Sloth32's Avatar
Hope so I am extremely excited to finally be rid of this nasty vibration whenever I brake.
Old Feb 8, 2007 | 07:43 PM
Blazin_TL's Avatar
Registered User
Replace Brake Pads
http://www.cardomain.com/ride/184466/24
Replace Rotors
http://www.cardomain.com/ride/184466/23
Old Feb 8, 2007 | 07:47 PM
keithseymour's Avatar
I just did my rear pads tonight. It took about an hour. You need to have a caliper tool to make it easy.
Old Feb 8, 2007 | 10:05 PM
Excelerate's Avatar
Former Sponsor
Make sure you break in the new setup properly. Speed up to about 60 mph and slow down to about 10 mph starting with light pressure and moving up to moderate pressure by about the 8th time. Allow the brakes to cool. Be easy on the brakes for the first few hundred miles. No hard braking; try not to engage ABS. And no 120mph-0 stops. Obviously if you have to stop you stop but you risk damaging the rotors.
Old Feb 9, 2007 | 10:24 AM
Sloth32's Avatar
Thanks for the help man. that will definetly come in handy
Originally Posted by Blazin_TL
mada51589
Jan 9, 2025 04:40 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
gqdabien
Sep 8, 2015 11:41 PM
asahrts
Sep 4, 2015 05:55 PM
nishant11
Sep 2, 2015 10:34 AM
