Removing the Cat???
Old Aug 17, 2002 | 06:22 AM
Juker008's Avatar
TRELOS
Removing the Cat???
Is it ok to remove the cat and replace it with a straight pipe? Or would it mess up my lean/rich miztures?
The reason why I say this is if I can remember last. Isn't there an O2 sensor in our cats that monitor emissions and lean/rich readings? And doesn't the O2 sensor allow the ECU to self adjusts to allow better fuel economy and less emissions?
If it is ok to replace the cat with a straight pipe. Then is it just a simple remove and replace job. Or would I have to do extra work than just putting in a straight pipe?
Juker008
Old Aug 17, 2002 | 06:49 AM
NJ_CLS_driver's Avatar
You'll never pass emission testing if you do that. The Cat burns off much of the excess pollution that would be let out by the engine. But I see your from FL. I don't think you guys have inspection on your cars do you.
Also, I think it would be illegal to remove the cat.
Old Aug 17, 2002 | 07:13 AM
23wt's Avatar
Mugen Racing Team
If you don't have inspection and want your car to have more power during mid range... get a custom piping without cat... that is what alot of ppl do in my area...
Old Aug 17, 2002 | 08:28 AM
Pappy's Avatar
Do it! U Only Live Once!
I believe it is illegal for a mechanic to remove it. They could be fined heavily by the feds. I don't know if you would be able to stand the loud noise all of the time. Check into it thoughly first before you make any changes. We have no inspection in FL.
Old Aug 17, 2002 | 10:33 AM
maevonee's Avatar
jjust remove the silence resontator. my car sounds sweet...
Old Aug 17, 2002 | 12:23 PM
Juker008's Avatar
TRELOS
Ok ok. Here in Fla. we have no inspections and the thought of having my mechanic getting busted for removing my cat is obsurd.
But what I need to know is if my car will work without a cat. Or do I need to cat so that my ECU can regulate emissions and keep the rich/lean mixture right?
Correct me if I'm wrong but isn't there an O2 senson in the cat or is it just before the cat. Removig the cat will ovbiously remove the O2 sensor form the exhaust system, so is that ok, or would I have to have the O2 sensor in the straight pipe?
Tnx
Juke0r08
Old Aug 17, 2002 | 04:06 PM
AkuraCLS's Avatar
ALi G in the House!
buy a dog to remove the cat
Old Aug 17, 2002 | 07:25 PM
scalbert's Avatar
Yes, there is an O2 sensors in the cat by removing the cat and even putting the sensor back in-line will cause a DTC to be set. Additionally, why remove it?? You can only gain a few ponies at best all while spitting out more emissions.
While working on a catalytic converter heat stress test at Calsonic we flow benched the converter. At 400 CFM there was only 3 - 4 Inches pressure drop. This equates to about 3 HP gain by removing it...
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
lowgrowl
Sep 26, 2015 05:18 PM
