problems installing UR pulley
Old Jan 21, 2004 | 04:58 PM
darrinb's Avatar
///M POWER
went to godspeed in novi to get my crank pulley on and they couldnt get the stock one off w/ a impact gun, they said there gun wasnt strong enough and u need some other tool to get t off that they didnt have....
any one have this problem before??
Old Jan 21, 2004 | 05:13 PM
ModAddict's Avatar
You said they were the best around. :P
There is a special tool to hold the pulley and crank, while you get a 20 foot pry bar on that bitch. I'll see if I can find it,.. I almost bought one.
Old Jan 21, 2004 | 05:15 PM
darrinb's Avatar
///M POWER
he was gona order the part from acura but said it wouldnt be worth it...
oh btw when i was there they just finished up installing a twin turbo greddy kit on a 350z, sooo hot
Old Jan 21, 2004 | 05:32 PM
ModAddict's Avatar
There are two different sizes. As much work as they do on motors, they should buck up and have the right tools. The bottom link is a kit with both sizes. I was going to get the top one.
http://www.etoolcart.com/index.asp?P...ROD&ProdID=629
http://www.etoolcart.com/index.asp?P...ROD&ProdID=697
http://www.etoolcart.com/index.asp?P...PROD&ProdID=41
Old Jan 21, 2004 | 05:35 PM
darrinb's Avatar
///M POWER
thanks for the link
Old Jan 21, 2004 | 05:43 PM
ModAddict's Avatar
No problem,... print it, and take it over to the shop, and say WTF?
Old Jan 21, 2004 | 07:07 PM
Ant7701's Avatar
Sweet as Gold
fucking amatures..did u still have to pay them for the attempt???
Old Jan 21, 2004 | 07:18 PM
CCType-S's Avatar
The anti-misshift
Darrin, let me ask my friend to see if he have the tool.
Old Jan 21, 2004 | 08:54 PM
typeR's Avatar
i had this problem and the fix is so easy...pull the fuse in the car for the fuel pump,and ingnition coil, just to be safe...put a breaker bar on it pin against the ground infront of the car and just turn the key acouple few times...the car turning over WILL loosen the bolt...i just did this last week...
Old Jan 21, 2004 | 10:33 PM
Chaptorial's Avatar
Thats a good question...
Old Jan 21, 2004 | 10:55 PM
blader's Avatar
Audi S4 driver
thats a pretty slick idea
Old Jan 21, 2004 | 11:26 PM
darrinb's Avatar
///M POWER
no i didnt pay, i'll call him w/ the news tommorw type r, thanks
Old Jan 21, 2004 | 11:29 PM
typeR's Avatar
believe me..i was hitting it with the gun for 15 minutes...then we broke out the tourch...still nothing...then i got on AV6 remembering what a guy abe did there (he's working on a GB for RVM pulleys)...anyway he did the breaker bar tech. and 2-3 turns of the key it was off...
Old Jan 21, 2004 | 11:33 PM
typeR's Avatar
Old Jan 21, 2004 | 11:34 PM
darrinb's Avatar
///M POWER
good lookin out, i'll let ya know how it goes
Old Jan 22, 2004 | 02:28 AM
sgmotoring's Avatar
Bleed Honda Blue
Good idea but don't used your torque wrench as a breaker bar.
Old Jan 22, 2004 | 07:55 AM
CCType-S's Avatar
The anti-misshift
Old Jan 22, 2004 | 08:31 AM
typeR's Avatar
we used a pipe..this is that guy abe
Old Jan 22, 2004 | 11:46 PM
darrinb's Avatar
///M POWER
i contacted the guy who installed it and type r's method might put too much stress and pressure on the starter so he didnt want to be liable in case something happened
i think imma go to a shop w/ a stronger impact gun, if that dont work i'll order the tool
Old Jan 22, 2004 | 11:54 PM
Chopsie's Avatar
Beware of leakage
Shit, you would think that a performance would have the tools necessary to complete the task. Good luck Darrin.
Old Jan 23, 2004 | 08:43 PM
ChadT's Avatar
Spectacular Aroma About
Too bad you're not a little closer. I've been looking for something to test my new 1000 ft lb IR Titaniuim impact wrench on.
Old Jan 23, 2004 | 09:05 PM
CLpower's Avatar
teh Senior Instigator
:wackit:
Old Jan 24, 2004 | 03:39 PM
ChucksTL_RENAMED's Avatar
A 3/4 gun can be used or you can heat up the nut with a torch for maybe 15 seconds and then hit it with an impact gun, that should do it. Don't get it too hot as the seals nearby could be damaged.
Old Jan 24, 2004 | 03:45 PM
darrinb's Avatar
///M POWER
imma find another shop
Old Jan 25, 2004 | 10:37 PM
flint's Avatar
Find another shop. When we did mine the guy that was helping me had a weaker impact wrench at home and we couldn't get it off. He drove to work and got a much better one and it took about 15 seconds working on the bolt but it came off. If you have a good gun, it will come off without a torch or breaker.
Old Feb 2, 2004 | 11:25 PM
darrinb's Avatar
///M POWER
i cant find n e other place, this sucks
Old Feb 2, 2004 | 11:41 PM
mattg's Avatar
i had Acura install mine. is your dealer anti-mod?
Old Feb 3, 2004 | 12:01 AM
typeR's Avatar
dude just do what i told you'...itll work in 2 minutes...pull the fuse to the ignition...turn it over a couple good times and you'll be home free
Old Feb 3, 2004 | 07:48 AM
ModAddict's Avatar
1. Payn Tech in Troy (248)-649-3966
2. Specmo, on Woodward in Royal Oak (248)-691-8842
Old Feb 3, 2004 | 07:58 AM
CCType-S's Avatar
The anti-misshift
yeah, contact Payn Technologies or http://www.payntechnologies.com
Old Feb 3, 2004 | 03:52 PM
Chaptorial's Avatar
Its time to drive out to NJ Darrin. :nj:
Old Feb 3, 2004 | 04:19 PM
Ant7701's Avatar
Sweet as Gold
I wish I lived closer to a whole bunch of u guys....I can install just about anything and would save u guys a shit-load of cash. Darrin...just find a Comptech approved Acura dealer...or even a regular dealer. All they need is the crank holder.
Old Feb 3, 2004 | 04:29 PM
SC TL's Avatar
Ei-Accord on the V6P.net board installed mine over the weekend using TypeR's method. His install took less than an hour.
Old Feb 3, 2004 | 10:18 PM
darrinb's Avatar
///M POWER
thanks for the links brad,
my dealer is semi mod friends but i rathet them not do the install
Old Feb 3, 2004 | 10:23 PM
darrinb's Avatar
///M POWER
my installed said that would put to much pressure on the starter and he doent want to be liable
darrinb's Avatar
///M POWER
paa should pay me a visit
Old Feb 3, 2004 | 10:59 PM
typeR's Avatar
you do it your self or tell him you'll sign off...it's no biggie
Old Feb 3, 2004 | 11:13 PM
darrinb's Avatar
///M POWER
i'll think about it
Old Feb 3, 2004 | 11:14 PM
Chopsie's Avatar
Beware of leakage
Damn man, still fightin with this. I figured you gotten it on already. Your goin through some shit tryin to get this done.
Old Feb 3, 2004 | 11:44 PM
darrinb's Avatar
///M POWER
not really i only tried once, i have been busy w/ school and work so i havent had time to find other places to install
cycdaniel
Dec 17, 2019 10:58 AM
iCrap
Sep 11, 2015 06:21 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
NSolace
Sep 3, 2015 08:02 PM
