Possible New Mod??
Old May 14, 2010 | 01:47 AM
  #921
civicdrivr's Avatar
Not off hand. You can use the two bolts that hold the stock IMRC motor to the rear valve cover if you want, they're just not as pretty.
Old May 14, 2010 | 01:56 AM
  #922
kdawg8526's Avatar
13.2@106mph G37 RWD Sedan
no worries ill try to figure it out tomrow hopefully everything goes as planned
thanks for your help ill let you guys know what happened tommroow
Old May 14, 2010 | 12:57 PM
  #923
kdawg8526's Avatar
shit i think i got the wrong intake manifold the tb adapter isnt lining up
and i measured the opening for the tb its about 68mm
and from what i read before i thought the 09 3.7l tl had 80mm opening
i ordered part number 17160-rk2-a00... can someone tell me is this really the part number for the 3.7.
damn i dont know what im going to do if this is the wrong one they said no refunds for this special order part
Old May 14, 2010 | 01:03 PM
  #924
brian6speed's Avatar
Lone Wolf
just look at an acura parts website. that is the only 09 tl manifold they offer.
Old May 14, 2010 | 01:19 PM
  #925
kdawg8526's Avatar
isnt there 2 different manifolds? 1 for the 3.5L and 1 for the 3.7L
i called acura and they said 17160-rk1-a00 is the 3.5L
and 17160-rk2-a00 is the one i bought which is for 3.7L... but for some reason when i opened the box and look at the manifold there is a marking on it that says RK1
ill post a pic and show what im talking about
Old May 14, 2010 | 03:17 PM
  #926
richardparker's Avatar
3.7L Nitrous Breathing CL
Seams kinda fishy, Is their a honda part # tag anywhere on the package?
Old May 14, 2010 | 04:02 PM
  #927
civicdrivr's Avatar
Post pics.
Old May 14, 2010 | 04:38 PM
  #928
kdawg8526's Avatar
damn it i had to return it it turned out to be the one for the 3.5L base tl they took it back seems they made a mistake.. it was already a previous returned part
accidentally packed it in the wrong box.
but now the sad thing is the 3.7L manifold is on backorder until end of june..
and that goes for canada and u.s cause i called acura in lynnwood washington they said its back order also june
so im stuck with stock manifold for now
Old May 14, 2010 | 05:05 PM
  #929
civicdrivr's Avatar
That sucks. If I can fix my new TB my TL manifold will be up for sale.
Old May 14, 2010 | 05:28 PM
  #930
kdawg8526's Avatar
id take it but you probably want to sell the top plate and adapter with it.. which i already have
Old May 15, 2010 | 12:39 PM
  #931
civicdrivr's Avatar
Yep.
Old May 18, 2010 | 02:01 AM
  #932
kdawg8526's Avatar
this is what the imprint on the manifold looked like... it said RK1... it was supposed to say RK2
Old May 18, 2010 | 11:06 PM
  #933
k bye's Avatar
this seems like a nice mod
Old Jun 3, 2010 | 12:18 PM
  #934
kdawg8526's Avatar
got the manifold yesterday after such a long wait.. i will be installing it by next week. ill let u guys know how it goes
Old Jun 9, 2010 | 11:27 AM
  #935
I'm not trying to clutter up your thred with BS but,
your avatar is creeping me out civic.
Old Jun 9, 2010 | 11:30 AM
  #936
Lone Wolf
oh you made it seem worse than it is. That manifold is a special order item so it will always take awhile to get it. The first one i received was damaged so i had to get a 2nd one sent out. Still havnt installed it yet.
Old Jun 9, 2010 | 12:53 PM
  #937
kdawg8526's Avatar
but it took a month to get another manifold
Old Jun 9, 2010 | 06:18 PM
  #938
kdawg8526's Avatar
quick question here. how do u wire up the imrc for the new manifold. i noticed the old manifold imrc has only 2 pin conection. and the new manifold has a 5 pin connection
Old Jun 9, 2010 | 06:52 PM
  #939
gnuts's Avatar
3.5 psi
check the long thread on the TL manifold....the info is in there.
Old Jun 10, 2010 | 06:32 PM
  #940
kdawg8526's Avatar
can i anybody get me the link for the pinout diagram for the imrc on the 2009 tl manifold or let me know where i can find it
i looked in the diy thread and it doesnt show up anymore think it got deleted
Old Jun 10, 2010 | 07:03 PM
  #941
gnuts's Avatar
3.5 psi
Ya the diagram is removed, but here is the info:
Bolt it up, connect all vacuum hoses needing vacuum, route the crankcase ventilation, the wires are really easy.
White/blue is positive, it goes to the right hand connector on the IMT on the new manifold, white/red (this threw me off) is negative, goes to the left hand post on the IMT (4 neg, 5 positive)
The two holes towards the TB need bolts, two more than the stock manifold had. I'll get them next time I am at a dealer.
Old Jun 11, 2010 | 03:21 AM
  #942
kdawg8526's Avatar
^thanks thats perfect. so i only wire 2 of the pins in the imrc and leave the rest 3 alone
Old Jun 11, 2010 | 06:57 AM
  #943
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
CL:
TL
Old Jun 11, 2010 | 11:03 AM
  #944
kdawg8526's Avatar
thanks alot man i wouldnt have been able to get that without you
Old Jul 1, 2010 | 03:16 PM
  #945
azndecoy66's Avatar
hmmm.. is this possible with a tl-p?
can you do this on a tl-p?
if so what would you need? haha thanks in advance for your guys help!
Old Jul 1, 2010 | 04:11 PM
  #946
kdawg8526's Avatar
^dont think so because the throttle body adapter that makes the manifold work with our stock tb is only made for the tl-s tb
and from what i remember the tl-s throttle body and tl-p throttle body are different
Old Jul 1, 2010 | 07:49 PM
  #947
civicdrivr's Avatar
The TBs are different but the bolt holes arent, so the the TL-P TB will work.
You can run this manifold as long as you get the top cover from a 2008 Accord 4 door V6, PN 17116-R70-A00
That one doesnt have the IMRC on it.
Im not sure if its even worth it though.
Old Jul 1, 2010 | 09:51 PM
  #948
Rajca's Avatar
wham bam thank you ma'am
i dont think its worth it if u dont have the imrc. u can get the tl cover with the imrc and get a, shit...ummmm for got whats its called, but jjashaa had it on his tl-p with the 02-03 type s manifold. look for his thread
Old Jul 1, 2010 | 10:01 PM
  #949
civicdrivr's Avatar
RPM activated switch.
Old Jul 1, 2010 | 10:54 PM
  #950
azndecoy66's Avatar
thanks guys for the response! the reason i was thinking about this was because i was thinking about replacing my tl-p IM with the tl-s IM..
what do you think is the best move then? just sticking with the tl-s IM or going the 09 TL IM route?
Old Jul 2, 2010 | 01:34 AM
  #951
friesm2000's Avatar
B A N N E D
easy, look at MSD's ignition and then look for a module to activate a shift light, then you just hook the imrc up instead of the light, but then again there are tuning isues when it does activate though , so probably not completely worth it
Old Jul 2, 2010 | 01:43 PM
  #952
azndecoy66's Avatar
hmm... but in here:
https://acurazine.com/forums/2g-cl-frequently-asked-questions-52/type-s-intake-manifold-cl-p-discussion-thread-486697/
they said you put in the IMRC and rpm activation switch.. and couldn't i put in a type s throttle body also? sorry if im way off im trying my best to understand this stuff haha =P
Old Jul 2, 2010 | 01:44 PM
  #953
azndecoy66's Avatar
that is the type s IM replacement thread on a tl-p btw
Old Jul 3, 2010 | 10:47 AM
  #954
azndecoy66's Avatar
anyone???
Old Jul 3, 2010 | 10:54 PM
  #955
civicdrivr's Avatar
I dont see why you wouldnt be able to install the Type S TB.
Old Jul 5, 2010 | 08:41 PM
  #956
azndecoy66's Avatar
thanks!
Old Jul 21, 2010 | 12:34 AM
  #957
kdawg8526's Avatar
new manifold installed with no troubles.. everythings perfect.. my mechanic left the air temperature sensor hanging outsidethe manifold is that ok??
for more pics click here
https://acurazine.com/forums/2g-tl-photograph-gallery-99/2009-tl-manfold-2g-tl-s-784539/
Old Jul 21, 2010 | 12:40 AM
  #958
civicdrivr's Avatar
Extend the wires and put it in the intake tube.
Old Jul 21, 2010 | 12:46 AM
  #959
kdawg8526's Avatar
should i put it in one of the hoses that go to the intake? or do i drill a hole into the intake pipe
Old Jul 21, 2010 | 01:18 AM
  #960
civicdrivr's Avatar
Drill a hole in the intake pipe.
