Possible New Mod??
Old Apr 9, 2010 | 01:34 PM
  #881
DC3328's Avatar
Your Garage
so what are the pros and cons of blocking the egr
Old Apr 9, 2010 | 03:06 PM
  #882
ThegreatGATHby's Avatar
EGR in non-turbo gasoline engines is for emissions control at light load and idle conditions. It also helps the catalytic converter achieve light-off temperature quicker under cold start conditions.
Old Apr 9, 2010 | 03:41 PM
  #883
DC3328's Avatar
Your Garage
right, so what's good and bad about it? I'm assuming lose a little gas mileage gain a little power?
Old Apr 9, 2010 | 03:43 PM
  #884
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
I get the same average mileage now I got before I modded anything. 22-31 depending on city/highway & driving moderately/like a lunatic.
Generally I get about 25 in a mixed drive style/type of road.
Old Apr 9, 2010 | 04:12 PM
  #885
Gain mileage and power, lose emissions control
Old Apr 9, 2010 | 06:35 PM
  #886
kdawg8526's Avatar
13.2@106mph G37 RWD Sedan
Won't the check engine light come on if you block the egr
Old Apr 9, 2010 | 06:37 PM
  #887
Rajca's Avatar
wham bam thank you ma'am
yes it will
Old Apr 9, 2010 | 11:15 PM
  #888
jaMezBOI's Avatar
philly flickin'
the CEL
There are no performance gains at all from blocking off the EGR
may reduce gas mileage....minimally
now its just one less thing that can go wrong
Old Apr 9, 2010 | 11:41 PM
  #889
friesm2000's Avatar
B A N N E D
lose gas mileage, correct, since the egr puts inert gas into the cylinders, so not as much fuel has to be injected to maintained the air fuel ratio, but also will have higher NOx emissions without it, due to the cylinders have to burn more fuel and run hotter due to the increased heat from the additional fuel, that has to be burned
then increased power, HELL NO, it is turned off when you go WOT, so it would not be a diluted air charge, about the only thing i might say you get from getting rid of the egr, would be increased throttle response, from not having to clear the manifold and such but we are talking milliseconds to to clear the manifold though
what the hell are you smoking???
kinda true with loseing emissions control, but again see above
yes and very brightly, once you go through the drive cycle to meet the critia for setting a code for that (unless the valve is removed, which then it should come on right away)
Originally Posted by jaMezBOI
the CEL
x2
what is minimally by your judgement???, 1-2 MPG less would not surprise me at all, but might actually be more then that though
but yes one less thing to worry about, but what complexity are you adding though, by trying to keep that light off???, and not like it is too high of a upkeep on our cars, clean it out like every 50K miles or so
Old Apr 10, 2010 | 12:37 AM
  #890
jaMezBOI's Avatar
philly flickin'
The reason why I am blocking off the EGR is because I think it may solve the erratic idle I have when the 09 Manifold is on.
Old Apr 10, 2010 | 12:40 AM
  #891
friesm2000's Avatar
B A N N E D
are your sure you don't have a vaccum leak somewhere???
cause if the egr was working properly before it should be working properly still, especially with spotless passages in the manifold
also have you let it do the idle relearn procedure???
Old Apr 10, 2010 | 08:42 AM
  #892
jaMezBOI's Avatar
philly flickin'
the EGR ports do not line up properly with our intake runners. I put the stock manifold back on and no problems, so I know it has something to do with the manifold or TB adapter.
no, I did not. Once I know everything is sealed properly I will do that. How exactly do I perform the idle relearn procedure?
Old Apr 10, 2010 | 09:24 AM
  #893
friesm2000's Avatar
B A N N E D
basically let it warm up fully to operating temp, with everything off (radio, A/C, HVAC system) then let it sit there for 10 minutes just idleing, and don't include the time when the fans turn on either just minus that
and blocking the egr, normally at the valve itself, will not do anything for you then, since you will still have a vacuum leak
and for them lining up, how far are we talking off, cause a little bit off is alright, as long as it can seal fully
Old Apr 10, 2010 | 09:31 AM
  #894
e30cabrio's Avatar
It took a few days for mine to get normal. I suggest you put it together, make sure you have no vacuum leaks and let it idle, even if it does not immediately normalize drive it like that, allow it to idle as long as possible every time you park until it learns the new hardware.
I did not remove the egr & I did wire up the butterflies.
Old Apr 10, 2010 | 05:13 PM
  #895
jaMezBOI's Avatar
philly flickin'
thanks, I'll do this next time.
If I had a vacuum leak would it not happen when I put my stock manifold back on? This is why I am going to be blocking off my EGR.
The reason why I don't think its a vacuum leak is because this only happens when I put on the 09 manifold. Stock manifold everything runs fine.
There are pictures posted somewhere of the gasket from the 09 manifold on the MDX IM spacer to show how much the EGR is off. Im not 100% sure if its sealed, hence the reason why I'm going to block it off.
I did drive it after I had the manifold installed and it continued to have the erratic idle which was fine, but then the RPMs would drop to 200-300 and the engine would struggle to stay on. Then the CEL, VSA and ! came on, turned car off and back on then only the CEL stayed on... trying to find an OBD2 reader so I can see what code its throwing. I don't want to be driving my car around if its going to be dieing out like that on me.
When I was driving, I had it in second and did a slight pull how I normally drive and it wasnt moving at the start and then slightly after it seemed like it opened up and pulled properly. No idea what was going on there.
How did you hook the 2 pin clip to the 5 pin connector on the cover plate? I know there are ways to connect them but I'm not about to put something together and hope it stays together. I tried getting the 5pin clip from acura but they do not sell them by themselves.
Maybe this is all because I never did the idle re learn procedure.
Old Apr 10, 2010 | 06:39 PM
  #896
e30cabrio's Avatar
What you are describing sounds like a vacuum leak & the ECU not knowing what to do. That it happens with the 09 can mean you are leaving something loose/disconnected when you put in the part not designed for the motor.
I had a small leak at the TB, and there are several vacuum inlets on the 09 not on the 01-03.
As far as the electrical connection, I made a connector using wire & male female connectors. The female going to the solenoid & the male going to the car's harness.
Use the wiring diagram I posted.
How long did you drive it? It took mine DAYS.
Old Apr 10, 2010 | 08:29 PM
  #897
jaMezBOI's Avatar
philly flickin'
Had any extra inlets capped and tested each one multiple times.
Only drove it for 5 minutes before it started to shut off.
Old Apr 10, 2010 | 09:26 PM
  #898
e30cabrio's Avatar
You need to let it get used to the new set up.
The more you change (egr) the more the system needs to learn. Do what you want, I am telling you what worked.
Is there a learning disability among the Canadian young?
Old Apr 10, 2010 | 10:09 PM
  #899
jaMezBOI's Avatar
philly flickin'
must be the time of the month for some people
I told you what I have done to eliminate some of the possibilities. I'm trying to give as much information so it will help other understand whats going on.
attacking where I was born... classy
Old Apr 10, 2010 | 10:13 PM
  #900
kdawg8526's Avatar
hey cmon dude that was uncalled for
Old Apr 10, 2010 | 10:27 PM
  #901
e30cabrio's Avatar
You have been told repeatedly by numerous people the ECU needs to learn for a period of time yet keep making changes after less time than it takes to boil water.
You are not helping anyone because you do not have a clue nor have you succeeded at this mod. Try what has been successful maybe you will succeed.
You are not the first young Canadian here to act this way so I asked a question.
Your reaction tells me I hit a nerve.
I will not be answering any more questions from you until you try what has been suggested.
Not appreciating when helped or thanking for attempts at help= classless.
I asked a question.
Too thin skinned for the net?
Not my problem.
Old Apr 10, 2010 | 11:03 PM
  #902
Rajca's Avatar
i agree with e30. hes got the 09 manifold on and its working out for him. do what he says then start arguing.
Old Apr 10, 2010 | 11:46 PM
  #903
jaMezBOI's Avatar
philly flickin'
I understood the first time someone said that the ECU needs to learn with its new hardware. Never once did I show any indication that I disagreed with you/anyone, nor that I did not understand.
read things through before you post. I'm trying to help you guys understand what I have and havnt done so it can help you guys come to a conclusion.
Take your panties out of a knot bud
and which way might that be?
When I posted in this thread I have done nothing but answer the questions that people have asked me what I've tried and haven't tried.
I never asked you to answer any questions, you posted voluntarily.
Old Apr 10, 2010 | 11:51 PM
  #904
jaMezBOI's Avatar
philly flickin'
I agree, I know that he had his put on and was working with no issues. That's why any input he has given I have noted down.
I answered a question of his asking how long did I drive it and got a personal attack for what...
Old Apr 10, 2010 | 11:58 PM
  #905
e30cabrio's Avatar
You refuse to follow this simple direction.
That is good advice, I suggest you follow it. You cannot help when you have not accomplished an endeavor.
I do not have your panties
Like you know what you are doing when you are clueless.
You responded to the question did you allow time to learn NO, yet you have not done the simple task of just leaving it alone to learn.
You asked people that SUCCEEDED, As one of them I tried to help.
YOU ARE WELCOME
Old Apr 11, 2010 | 12:01 AM
  #906
e30cabrio's Avatar
I told you several times, Fries told you several times you did not do it.
You answered no you did not do it, I ASKED A QUESTION.
If you see yourself in a general reference that is not my issue.
Old Apr 11, 2010 | 12:11 AM
  #907
jaMezBOI's Avatar
philly flickin'
I havnt had time to even TRY it
you still dont understand
I said I knew what I was doing? Don't recall that either
Im learning as people post, and trying to gather information.
do you not understand that I have not attempted to put it on since thursday. So i never said anything about what you said being wrong. I havnt said anything that you or anyone else has told me has been incorrect because I havnt even had time to go to the shop.
YOU ARE WELCOME
you are one of those people, haha k....
Thanks!!!!!
just to make this clear for you since you must have a hard time reading
I have not tried anything anyone has told me yet because I havnt been to the shop since thursday. Everything that has been posted has been greatly appreciated and has been noted down... so the next time I give it to my mechanic to install I can help him out and we can hopefully solve the problem.
Old Apr 11, 2010 | 12:15 AM
  #908
e30cabrio's Avatar
You will get no help with your attitude.
I am one of 2 people that have done this & have written two DIYs go, find the threads you will get no help from me and I hope the other person ignores you also.
You never said you had not tried since Thursday, you just said you did not let it learn.
There is a possibility your manifold is bad, Civic had a bad one. I hope that is the case seeing as you are a serious piece of work.
Old Apr 11, 2010 | 12:32 AM
  #909
jaMezBOI's Avatar
philly flickin'
referring to the time I put it on, hence the past tense. fio
lol, alright thanks man
Old Apr 11, 2010 | 12:34 AM
  #910
e30cabrio's Avatar
Nice semantics. you win.
Hope you downloaded my pinout. I paid to get it and posted it, you are not the first to act like you are entitled to other peoples efforts, I'll email it going forward when polite people ask for it.
They can thank you for not having it readily available.
Old Apr 11, 2010 | 11:06 AM
  #911
friesm2000's Avatar
B A N N E D
minus all this lol
and for testing that vacuum leak, put the 09 manifold back on, start it up, you might have to tighten the throttle cable a little much, just so it can stay idleing, then basically take some carb spray and start spraying (you might need 2 cans btw idk) along all the seems and such, and see when the idle smooths out and such, there is your leak
but yeah it almost sounds like you might be missing aport that needs to be plugger or something, cause that leak sounds like it is of decent size, which would be a port or something more then likely
Old Apr 11, 2010 | 12:04 PM
  #912
jaMezBOI's Avatar
philly flickin'
minus all this lol
yeah, thats how we found the first leak at the TB was with carb spray. Then when we pushed over the thermal gasket it fixed that leak but still no dice.
I dont believe he tried to tighten the throttle cable but we will try that next time.
yeah thats what it seems like
When I would turn the car on it would idle fine. Its only when we touch the throttle it would go back to its erratic idle.
Next time im going to let it idle properly all through the idle relearn procedure and see if that changes any results.
Thanks for staying on topic
Old Apr 11, 2010 | 12:43 PM
  #913
civicdrivr's Avatar
If it would idle fine then once you touch it it goes erratic, its electronic, not a vacuum leak. Im 90% sure the issue with my idle is EGR related, but its also possible it could be the sensor in the power steering or the A/C circuit (yes, they are all connected to the idle circuit).
When you start the car and it idles fine, turn the steering wheel. Do you have the erratic idle again?
When the idle keeps jumping, pull the intake tube off the throttle body. There is a port on the bottom of it. Plug it with your fingers. Does the idle go back to normal? If it does, something in the circuit is telling it there is increased load so the ECU compensates by opening the IACV a bit. I went through 2 brand new IACVs all with the same issue, so I know its the not the IACV itself, its something else in the circuit. I checked all the wires going to the IACV and the wires at the ECU for the IACV, and they were all within spec.
I took off the sensor part of the IACV, locked the fin that spins inside it in the closed position and plugged the sensor into the harness so the car thinks the IACV is operational. Its ghetto, but it works for now.
The only issues with blocking the IACV is when the A/C is on and youre idling, the revs will dip down alittle bit.
Old Apr 11, 2010 | 11:40 PM
  #914
jaMezBOI's Avatar
philly flickin'
Thanks! great information
Ok, Ill try this the next time I put it on.
Ill definatly try blocking it off with my fingers and see if thats the issue. If it is Ill go the same route as you and lock the fin in the IACV. Great idea!
I dont use my A/C anyways, rolling down my windows is my A/C
Old Apr 12, 2010 | 12:50 AM
  #915
civicdrivr's Avatar
If your IACV is stuck open (likely), clean it out or try a new one and see what happens. It could be a simple fix such as that. Mine wasnt though
Old May 13, 2010 | 01:43 PM
  #916
kdawg8526's Avatar
hey guys im finally got some time off work and gonna get the manifold installed after its been sitting in the garage. but just a few quick questions though
i heard that people got a idling problem after installing it... is this happen to everyone? or only if theres a hose leak
and is it easy to figure out which hoses go where will my mechanic be able to figure it out?
do i need 09 tl manifold bolts to get this manofold bolted in?
and what do i do with the switch on the left side of the top plate (as shown in picture) do i plug anything into it or does it stay disabled? vvvvvvv
Old May 13, 2010 | 02:00 PM
  #917
civicdrivr's Avatar
Yes, you need to plug it in. That controls your IMRC.
There are two more bolts on the TL manifold for the top plate.
I had an idle issue but that turned out to be a crack runner that we didn't notice until two weeks ago.
Old May 13, 2010 | 05:29 PM
  #918
kdawg8526's Avatar
So I just need 2 extra bolts.. I can use my old bolts for the new manifold?
Old May 13, 2010 | 05:47 PM
  #919
civicdrivr's Avatar
Yea.
Old May 13, 2010 | 07:50 PM
  #920
kdawg8526's Avatar
Thanks man.
Do u know what the part number is for those 2
