Pls help yellowish fluid in engine bay
Old Sep 21, 2008 | 12:24 PM
poisx7's Avatar
Wink Pls help yellowish fluid in engine bay
There is a run off and accumulation of some type of yellowish fluid on the timming belt side of the motor. and there seems to be an accumulation of the fluid under the mout/damper part.
It still drives normal no engine codes, just a little slower than it is used to be but i think itis the hot weather here in TX or
I just want to know if i fked smthng up becos i drv this thing HARD
The pics are below for more specifics:
Old Sep 21, 2008 | 12:27 PM
CleanCL's Avatar
your motor mount is torn.
Old Sep 21, 2008 | 01:12 PM
fuzzy02CLS's Avatar
Yep, Broken side mount. Time to replace. Very common. Not much of a problem. Use 1/2 ratchets & extensions & a breaker bar & the bolts should come off.
Old Sep 21, 2008 | 02:30 PM
poisx7's Avatar
THANKS Y'ALL.
nOW IS THERE ANY THING BAD THAT CAN HAPPEN IF HOLD ON FOR SOMETIME & $$$$ BEFORE I DO IT.
LOW ON $$$ RIGHT NOW.
pLUS I THUT I WAS TOLD THE SIDE MOUNTS WERE CHANGED WHEN I REPLACED TRANNY, GOTTA LOOK THAT UP.
BECOS I DONT THINK THIS PART IS UNDER WARRANTY OR IS IT ??
Old Sep 22, 2008 | 11:48 AM
poisx7's Avatar
WHAT HAPPENS IF I DONT REPLACE IT IN TIME.......
CAN IT DAMAGE SMTHNG ELSE IN THERE OR ...................
Old Sep 22, 2008 | 12:27 PM
fuzzy02CLS's Avatar
There are many cars out there with them broken. Most owners don't even know it.
A new side mount isn't that much $. Install yourself(it's easy). Save up for it.
You should be ok for a short time. I would not hold off too long though.
Old Sep 22, 2008 | 02:53 PM
poisx7's Avatar
oK, THANKS . WENT TO THE STEALER TODAY OH I MEANT DEALER AND THEY GUOTED ME $200 TO HAVE IT REPLACED.
i GUESS SINCE EVERYBODY SAYS ITS ANY EASY INSTALL i WILL JUST ORDER THE PART AND SEE IF I CAN DO IT MY SELF.
I WUD TRY ACURAPARTS.COM AND SEE...........
THANKS AGAIN
Old Sep 22, 2008 | 05:56 PM
fsttyms1's Avatar
Also take CAPS LOCK off.
And yes its easy to change the side one yourself.
Old Sep 22, 2008 | 06:13 PM
poisx7's Avatar
cap off
Old Oct 3, 2008 | 02:25 PM
poisx7's Avatar
Talking Passenger front Side Mount part # ??????????
DOES Anybody know the part number for this side engine mount ? or I was also considering going the innovative route but I guess he sells them in sets(3) and I only want to change the passenger side mount that is torn.
So i changed my mind.
Passenger Side Mount part # ??????????
best place to order it also will be helpful.
Old Oct 19, 2008 | 01:32 AM
poisx7's Avatar
https://acurazine.com/forums/2g-cl-2001-2003-50/broken-motor-mount-692012/.
wow CL-Slick u must have crazy connections on acurazine.
Since i asked the same question and even added pics and i still aint got the answer and u seem to have got an answer 4 ursef in less than 2 hrs.
well played
https://acurazine.com/forums/showthread.php?t=692012
Caddy
1G RDX (2007-2012)
Sep 18, 2015 12:44 PM
jblessing
Wash & Wax
Sep 17, 2015 09:28 PM
ghuns
Sep 16, 2015 04:26 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
