Pls help yellowish fluid in engine bay
Subscribe
Sep 21, 2008 | 12:24 PM
There is a run off and accumulation of some type of yellowish fluid on the timming belt side of the motor. and there seems to be an accumulation of the fluid under the mout/damper part.
It still drives normal no engine codes, just a little slower than it is used to be but i think itis the hot weather here in TX or
I just want to know if i fked smthng up becos i drv this thing HARD
The pics are below for more specifics:
Reply 0
Sep 21, 2008 | 12:27 PM
your motor mount is torn.
Reply 0
Sep 21, 2008 | 01:12 PM
Yep, Broken side mount. Time to replace. Very common. Not much of a problem. Use 1/2 ratchets & extensions & a breaker bar & the bolts should come off.
Reply 0
Sep 21, 2008 | 02:30 PM
THANKS Y'ALL.
nOW IS THERE ANY THING BAD THAT CAN HAPPEN IF HOLD ON FOR SOMETIME & $$$$ BEFORE I DO IT.
LOW ON $$$ RIGHT NOW.
pLUS I THUT I WAS TOLD THE SIDE MOUNTS WERE CHANGED WHEN I REPLACED TRANNY, GOTTA LOOK THAT UP.
BECOS I DONT THINK THIS PART IS UNDER WARRANTY OR IS IT ??
Reply 0
Sep 22, 2008 | 11:48 AM
Quote: Yep, Broken side mount. Time to replace. Very common. Not much of a problem. Use 1/2 ratchets & extensions & a breaker bar & the bolts should come off.
WHAT HAPPENS IF I DONT REPLACE IT IN TIME.......
CAN IT DAMAGE SMTHNG ELSE IN THERE OR ...................
Reply 0
Sep 22, 2008 | 12:27 PM
There are many cars out there with them broken. Most owners don't even know it.
A new side mount isn't that much $. Install yourself(it's easy). Save up for it.
You should be ok for a short time. I would not hold off too long though.
Reply 0
Sep 22, 2008 | 02:53 PM
oK, THANKS . WENT TO THE STEALER TODAY OH I MEANT DEALER AND THEY GUOTED ME $200 TO HAVE IT REPLACED.
i GUESS SINCE EVERYBODY SAYS ITS ANY EASY INSTALL i WILL JUST ORDER THE PART AND SEE IF I CAN DO IT MY SELF.
I WUD TRY ACURAPARTS.COM AND SEE...........
THANKS AGAIN
Reply 0
Sep 22, 2008 | 05:56 PM
Also take CAPS LOCK off.
And yes its easy to change the side one yourself.
Reply 0
Sep 22, 2008 | 06:13 PM
cap off
Reply 0
Oct 3, 2008 | 02:25 PM
Passenger front Side Mount part # ??????????
DOES Anybody know the part number for this side engine mount ? or I was also considering going the innovative route but I guess he sells them in sets(3) and I only want to change the passenger side mount that is torn.
So i changed my mind.
Passenger Side Mount part # ??????????
best place to order it also will be helpful.
Reply 0
Oct 19, 2008 | 01:32 AM
https://acurazine.com/forums/2g-cl-2001-2003-50/broken-motor-mount-692012/.
wow CL-Slick u must have crazy connections on acurazine.
Since i asked the same question and even added pics and i still aint got the answer and u seem to have got an answer 4 ursef in less than 2 hrs.
well played
https://acurazine.com/forums/showthread.php?t=692012
Reply 0
Subscribe
