odd question...bear with me.
Old Oct 23, 2009 | 05:32 PM
Type S-uper's Avatar
130+ mile club in
so, when we turn the key to ign II there is a faint sound like a buzz or hum and i'm sure it has something to do with the fuel. now, for the last i'd say 6-8 start ups, the sound has turned from a faint buzz or hum to more of some mechanical function dying...like batt power. I dont know exactly how to describe this. But i'm sure this is something that requires some kind of attention...thanks in advance.
Old Oct 23, 2009 | 05:38 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
Is it the fuel pump priming that your hearing ?
Old Oct 23, 2009 | 05:41 PM
130+ mile club in
i'm guessing it is...but it sounds naaassty when it does it now. and it sounds as if it comes right from the dash
Old Oct 23, 2009 | 05:46 PM
Any difference the perfomance,sluggish when pressing the pedal after running for awhile.
If the pump was getting blocked from junk it would change the sound,or even when the pump starts getting weak it will sound differnt
Old Oct 24, 2009 | 12:42 PM
130+ mile club in
the car is sluggish...especially after seafoaming the car which is weird...so it's probably the fuel pump?
Old Oct 24, 2009 | 12:57 PM
130+ mile club in
and the car is also progressively taking longer to start
Old Oct 24, 2009 | 06:18 PM
civicdrivr's Avatar
Fuel pump is on its way out.
Old Oct 24, 2009 | 06:24 PM
130+ mile club in
ohhhh ok, thanks...now have to start checking prices
Old Oct 24, 2009 | 10:29 PM
friesm2000's Avatar
B A N N E D
could also be a bad pgm-fi (main) relay cause that is right in the dash above your feet (drivers) since you mentioned it coming from the dash. and then the fuel pump would not be getting enough voltage so it would not be able to pump enough fuel then
fyi: fuel pumps do not like undervoltageing, and if they get that they like to die a premature death
Old Oct 25, 2009 | 12:14 AM
civicdrivr's Avatar
It could be the main relay, but 99% of the time they just completely stop working (at least in my experience).
Pull the main relay out and inspect all the solder connections. Resolder is neccessary. See if the sound goes away.
Old Oct 25, 2009 | 02:05 AM
Allout's Avatar
Blown is Best
I've also had a bad ignition switch that made that noise before it went out. When it finally died, the car wouldn't stay on or would intermittently die.
Old Oct 25, 2009 | 04:04 PM
CHOPSTICKSONLY's Avatar
hmm, this also happens to me whenever I start my car, it would hum/buzz. Then after i would let it warm up, and when its fully warmed i would drive it, after i put into D5, once i hit ~20 ish km, there would be a longer/louder buzz (like 1-1.5seconds long), but would then go away until the next time i start up my car.
Could this be the abs turning on? I'm no mechanic and if this is somewhat serious i would like to learn more and get it fixed.
thanks in advance
Old Oct 25, 2009 | 06:03 PM
130+ mile club in
i appreciate the advice fellas. i'm going to check the relay as soon as i get a chance. i would hate for my pump to go due to the relay. dont want any premature endings...im gonna leave that one alone LOL
Old Oct 25, 2009 | 07:20 PM
ACRIIGHT's Avatar
Let us know what you find out. This is my first Acura/Honda and I've only had it for 2 months but the seller told me it was the ABS system.
Old Oct 25, 2009 | 10:00 PM
yeah thats what i was told as well
to OP, would be nice if you find out what it is ^^
Old Oct 26, 2009 | 12:44 PM
130+ mile club in
yeah i'm going to check it out tonight or prolly tomorrow since i have the day off. i'll be sure to come on and let you guys no what the deal is
Old Oct 27, 2009 | 01:48 PM
130+ mile club in
ok, so i plan to tackle this issue today and i'm wondering where exactly is the pgm relay located? it's not the sterring column right? moreso the piece just beyond it?
Old Nov 8, 2009 | 11:11 PM
hey man, any luck?
Old Nov 9, 2009 | 03:34 AM
YeuEmMaiMai's Avatar
thanks in advance
ABS self test
Old Nov 9, 2009 | 12:52 PM
dfv3.2CL-S's Avatar
Most likely the ABS system self check and fuel pump being primed
GWEEDOspeedo
Jan 15, 2016 10:39 PM
Houston
Oct 8, 2015 01:27 AM
Skirmich
Oct 1, 2015 12:59 PM
hashbrown
Sep 29, 2015 12:13 PM
mellsonnj
Sep 24, 2015 04:42 PM
