I'm pretty sure this hasn't been asked yet
Old Mar 22, 2002 | 03:25 PM
NoleCLS's Avatar
Okay, so I want to do the comptech springs, but am concerned about the amount of drop in the back end......here is why......I am a bowler.....yes a bowler. And at any given time there can be as many as 10 bowling balls in my trunk which tends to lower the back end anyway. If I put springs on the car I am assuming that I will not be able to carry this amount of weight in the trunk b/c it may make the car to low.
My other question ....... if I did the comptech springs and the yellow konis, would that give me enough versatility to be able to carry that much weight and still have a good ride on the car?
And it is okay to laugh all you want at the fact that I'm a bowler, I get it all the time. But if you want to play for some $$$ Bring it!!
Old Mar 22, 2002 | 03:27 PM
wayneg's Avatar
My Tl-S has the springs and a body kit, and I don't have any problems with 2 people in the back seat. What's 10 bowling balls weigh- about 160lbs? Should be no problem.
Old Mar 22, 2002 | 03:29 PM
soopa's Avatar
The Creator
with comptech springs you will still be able to carry all that weight in the rear...
I assume 10 balls means 150lbs at most.
Not a problem assuming your not gonna run the slalom with them in there.
Comptechs give your car a "raked" look... and their not much of a drop in the back to begin with... so with that weight... its just gonna make your car look a lil more even... not saggy.
Comptechs would be the perfect choice for you.
There shouldnt be any issues.
Old Mar 22, 2002 | 03:31 PM
soopa's Avatar
The Creator
btw, I have my car dropped much lower then comptechs... I had about 150lbs in my trunk this weekend without a problem. Thats on top of my system which already weighs somewhere in the 50-100lb range.
Old Mar 22, 2002 | 03:32 PM
Styles__69's Avatar
i got a question .....
wats teh perfect drop amount..for both front and back.
like 1.5 inches in the back?
Old Mar 22, 2002 | 03:35 PM
scalbert's Avatar
Re: I'm pretty sure this hasn't been asked yet
What lanes are you typically at?? I won't take up that offer as my bowling skills are not the best. I prefer to have my pitcher of beer and roll an occaisional ball.
Old Mar 22, 2002 | 03:36 PM
soopa's Avatar
The Creator
there isnt one.
it all depends on your tastes... and what your looking to get out of the drop.
Old Mar 22, 2002 | 03:38 PM
wayneg's Avatar
Check the pics in the thread by Scooter to see how far the Comptechs drop the CL-S
gmilian's Avatar
Red X
in canada do you spell "what" wat? or do you just not know how to type or spell? in another post you spelled it the same way so i know it's not a typo.
Old Mar 22, 2002 | 03:57 PM
NoleCLS's Avatar
Dare I ask what you had in your trunk this weekend that was 150 lbs??? Wouldn't have anything to do with cement shoes would it?? haha
Old Mar 22, 2002 | 03:59 PM
NoleCLS's Avatar
Would you still suggest doing the comptechs with the Konis??
Old Mar 22, 2002 | 04:05 PM
JRock's Avatar
Old timer
Well then don't even consider H&Rs or Eibachs, which both lower the front AND back an even amount (so any amount of trunk weight will give you the "saggy-ass" look) and to a lower setting (2" all around vs 1" comptech rear and 1.5" comptech front). Comptech springs should be perfectly fine.
Old Mar 22, 2002 | 04:14 PM
oonowindoo's Avatar
my rear scratch with or without any passenger...
Old Mar 22, 2002 | 06:51 PM
Nicky Pass's Avatar
Fuct in the hed!
I like the comptech drop.....it looks juuuuuuuuust right
Old Mar 22, 2002 | 07:07 PM
BIGPOPPA21's Avatar
Death Metal
I thought the same thing cause i'm also a bowler. i carry 8 16pound balls and the car sits perfectly exactly the same as the drop in the front. i post pics tomorrow of my car on comptech springs with the balls
Old Mar 22, 2002 | 07:42 PM
FLL Type-S's Avatar
Iconoclast
Wayne, do you guys typically realign headlights after installing Comptech springs? Since I've had mine installed I've noticed that my headlights don't throw light as far as they used to, and I'm assuming it's because of the rake pointing the front of the car more downward then it was stock.
Old Mar 22, 2002 | 11:13 PM
Chris's Avatar
- daemonichris -
because JT kits suck!
cycdaniel
Dec 17, 2019 10:58 AM
HairyMonkey019
Apr 22, 2016 10:50 PM
theinsvnity
Sep 10, 2015 10:22 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
