How to check for tire leaks?
Old Mar 10, 2004 | 02:59 PM
Scrib's Avatar
Administrator Alumnus
OK... I'm not sure if it's the warm and then cold weather... A poor seal, or a hole, but my wife just called and said the "Low Tire Pressure" light came on in her car.
Is there an easy way to check for a leak? It's not like this is happening frequently; i.e. weekly, but the light came on about 3-4 weeks ago. I'm not thinking it's a leak, but how can I be sure?
Old Mar 10, 2004 | 03:11 PM
PavDog's Avatar
Blackbird baby..
Sounds like you've got a slow leak.. The tire places usually put the tire in a water bath and look for bubbles. You might want to try brushing soapy water on the tire and look for bubbles. Otherwise I'd take it to a shop. Could be a valve, bead, etc. It won't hurt to have it reseated either.
Old Mar 10, 2004 | 03:20 PM
GEB's Avatar
GEB
If your luck enough to have a Discount Tire around, they'll check it and fix it for free!!
Old Mar 10, 2004 | 03:21 PM
vinarnold's Avatar
pav dog has it right, its the right way to do it.
Old Mar 10, 2004 | 03:39 PM
Scrib's Avatar
A local tire shop will do it for 18 bucks... Probably throw some air in there and get the car over there this weekend.
Then again... I don't even know if the tire is low. For all I know, the tire pressure monitor could be outta whack.
Old Mar 10, 2004 | 03:43 PM
Red-CL's Avatar
Doin' da crack shuffle
Also, if your wife drive the car and partially parks on the curb that could cause a tire to gradually lose pressure.
Just my
Old Mar 10, 2004 | 03:52 PM
Scrib's Avatar
Just my
Nope...
She's been taught VERY well.
Old Mar 10, 2004 | 03:54 PM
Red-CL's Avatar
Originally posted by Scrib
Nope...
Good job Scrib
Old Mar 10, 2004 | 03:55 PM
Eggplant-EX's Avatar
Yup! Head to Discount Tire.
Old Mar 10, 2004 | 07:39 PM
Scrib's Avatar
Both rear tires were down to 18psi!!!
Not sure what happened. I'll keep an eye on the both. :o
Old Mar 11, 2004 | 07:48 AM
dallison's Avatar
registered pw
sounds like a it could be a freak thing. that has happened to me before. once i put more air in its ok, just weird
Old Mar 11, 2004 | 07:50 AM
dallison's Avatar
registered pw
only bad thing about those monitors is that they may not always be acurate and its one more thing that can break
Old Mar 11, 2004 | 07:53 AM
Scrib's Avatar
It certainly did it's job, considering the rear tires were severely low. But it strikes me as odd as both were exactly the same, 18psi.
I'll definitely keep an eye on them.
Old Mar 11, 2004 | 08:40 AM
NOLACLS's Avatar
You can also try to spray some windex on it or something like that. When it hits a leak it will start to foam up so you can see it easy.
cycdaniel
Dec 17, 2019 10:58 AM
lland
Oct 4, 2015 04:47 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
GhostTL09
Sep 19, 2015 01:57 PM
NetGnome
Sep 7, 2015 08:33 PM
