Fan ?
Old Jul 13, 2004 | 08:05 PM
Louie11's Avatar
Fan ?
I never noticed this until I started to go to the dyno and the operator keeps telling me about how hot my engine is. I've noticed this on hot days and with some spirited driving, when I get home I leave the engine running and pop my hood. Theres a blast of heat coming from the engine compartment but the fans are not running. You would think they would be on. Wonder if they are broken, or do they have a safety and turn off when the hoods open? As a matter of fact I don't think I have ever seen them on since I've owned the car. This has also sparked my attention because I was planning on doing the cooling mod soon.
Old Jul 13, 2004 | 08:37 PM
proaudio22's Avatar
-S namyaC-
Turn your A/C on (manually), and get out and listen. The fans should come on. If they don't run, you got a problemo.
Old Jul 14, 2004 | 10:19 AM
Louie11's Avatar
Thanks I'll try that today.
Old Jul 14, 2004 | 10:39 AM
Smitty's Avatar
you know there is a Temp gauge right on your dash...
Mind telling me if it is at the half way point after the car has been started and running for 5-10 minutes?
Old Jul 14, 2004 | 01:00 PM
Louie11's Avatar
No smitty. After start up and driving for awhile, The gauge usually sits at 1 to 2 ticks under half.
Old Jul 14, 2004 | 01:06 PM
Smitty's Avatar
that is the normal operating postition....
Old Jul 14, 2004 | 01:30 PM
Louie11's Avatar
So does that mean that the fans only turn on if the gauge goes to half or higher?
Old Jul 14, 2004 | 01:39 PM
NiteQwill's Avatar
Adventurist.
Not necessarily. You can start your car cold and run into traffic and your fans will turn on prematurely b/c there is no moving air into your car. It can all depend on weather conditions, traffic, etc.
Old Jul 14, 2004 | 01:45 PM
Smitty's Avatar
Louie trust me on this one.... if your gauge is sitting at 2 clciks below half way and it never goes up above that, then your fans are working properly...
The first 10 minutes of that car sitting there and running would make that dumbie needle on your dash SKY rocket to the RED (overheat area) if your FANS were NOT working.
your fine... enjoy your Acura..
Old Jul 16, 2004 | 09:25 PM
patek007's Avatar
Louie... what Smitty said... ... and furthermore... keep always in mind that internal combustion engine is very inefficient design... and in 100 years of solid although operaion.. noone had improved upon the miserly 87% inefficiency... i.e. 87% of heat that you felt when opening the hood... is a pure WASTE... but trust the all aluminum knocker... it does NOT need as much cooling as the solid iron blocks.... .
Old Jul 17, 2004 | 09:28 AM
blader's Avatar
Audi S4 driver
With the cooling mods I definetly notice my fan kicking on alot more often, but for short periods of time
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
hashbrown
Sep 29, 2015 12:13 PM
juanrl
Sep 29, 2015 03:25 AM
