Everyone I need help with a battery issue
Old Jan 11, 2008 | 09:27 PM
crowland's Avatar
I am running into a battery problem. I frequently travel and have returned to my car at the airport frequently with a dead battery after 3-4 days of sitting still in the garage. I am already sure that none of the lights have been left on and the battery was purchased within the past year. I can not figure out where the car is drawing current and running the battery down. It is getting very frustrating carrying a charger pack each time I head out of town so any suggestions are appreciated. Thanks in advance for the help.
Old Jan 11, 2008 | 09:56 PM
fenixxishot's Avatar
disconnect the negative terminal and your set
Old Jan 11, 2008 | 09:57 PM
TCM 01 CL-S's Avatar
Uses turn signals in my
You don't leave an ipod or any kind of charger attatched did you (never hurts to ask)?
Old Jan 11, 2008 | 10:40 PM
fuzzy02CLS's Avatar
Get a volt meter & see what the amp draw is while the car is off. Then compare it to when it's running. Also get the battery tested to make sure it's holding a charge.
And check you battery cables are secure & clean.
Old Jan 12, 2008 | 01:31 AM
TOPHER33884's Avatar
Just go all out & get an Optima Yellow top! Bad ass batteries.....
Old Jan 12, 2008 | 02:51 AM
andyjl's Avatar
just buy a new battery, only costs like 80-90 bux with installation
Old Jan 12, 2008 | 02:54 PM
PMGCamaro's Avatar
First, determine if you have a voltage leak. If there's an electrical issue somewhere that drains your battery when the car is off, replacing the battery won't help.
Old Jan 12, 2008 | 03:07 PM
underst8's Avatar
140,000 miles young
read dude, read. His battery is less than a year old. I vote the volt meter method first.
Old Jan 13, 2008 | 07:26 AM
fliplyricist1's Avatar
Staggered 1st Gen
if you jumpstart your car, disconnect the positive terminal of the battery while the car is running. if the car dies right away when you do this, it's your alternator that's not charging the battery and needs to be replaced
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
scionxb3003
Sep 14, 2015 01:52 AM
whitesoxsfan12
Sep 13, 2015 02:09 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
