Custom Poly Engine Mounts
Old Oct 5, 2009 | 09:05 PM
  #281
Rajca's Avatar
wham bam thank you ma'am
im gonna be doing this in the next week or 2. doing 94A
Old Oct 6, 2009 | 09:28 AM
  #282
jproy's Avatar
MP90 uninstalled
Rajca,
I have had 60A on all five mounts for about 9 mos. now and I think it is more than adequate. I know you are tracking your car. I suggest you at least fill only the rear with 60A. The vibrations are on the very brink of excessive and crazy with 60A in all the mounts. 60A is all I can imagine would be tolerable on a daily basis. I had the crappy innovative mounts and the excessive vibration was to much on a day to day driving basis. Just something to consider.
Old Oct 6, 2009 | 11:18 AM
  #283
RUF87's Avatar
Lead Footed
Originally Posted by jproy
Rajca,
What's the matter? Don't like driving around in a rolling vibrator?
Oh, and crappy Innovative mounts is being too kind.
We were . . :rippedoff
Ruf
Old Oct 15, 2009 | 12:43 PM
  #284
StreetKA's Avatar
im ordering new one right now... cant wait anymore.... is that part number correct ? 50800-S0K-A82 ? im going poly fill it should i use 60A ? anyone tried to fill it from a bottom ? there is no other way if you want to fill it from a top you have cut the rubber right ?
Old Nov 4, 2009 | 02:42 PM
  #285
StreetKA's Avatar
a front mount just arrived but i dont how to get to it... where to drain fluid and whats the easiest way to fill it up with polly i know it been posted but i could find instruction how to do it right to do not mess it up
Old Nov 4, 2009 | 08:58 PM
  #286
distortedolskool's Avatar
the front mount is not to be drained. only filled between that top plate and the main mount. look at the pics on page 1 or 2 and you'll see the duct tape i used to hold the poly in place.
Old Nov 4, 2009 | 09:49 PM
  #287
StreetKA's Avatar
yup that makes sense now for me thanks... i'll do it tomorrow
Old Nov 5, 2009 | 10:30 AM
  #288
crap. take that back because that was my first test. you still fill the same area but keep the top cover on also. this entire area above and below the plate get filled. this is because the motor under load pulls upward on the front mount. this is why the poly is needed above the plate. check these pictures out.
Old Nov 5, 2009 | 11:05 AM
  #289
StreetKA's Avatar
you have such a good timing haha i just started doing it. thanks for a hassle
Old Nov 5, 2009 | 12:23 PM
  #290
civicdrivr's Avatar
I sincerely hope thats sarcasm.
Old Nov 5, 2009 | 01:05 PM
  #291
StreetKA's Avatar
it is sarcasm, thanks distortedolskool for help
Old Nov 6, 2009 | 11:07 AM
  #292
the revised front mount was discuss in the thread i know. read the entire thread before starting. remember this was a new project we were trying. jproy posted some great pictures and discovered the issue with my first front mount. glad we could help!
i just drove my car last night and she still doesn't hop. i will inspect the mounts this afternoon for any recent wear.
Old Nov 6, 2009 | 11:36 AM
  #293
phee's Avatar
I got the Shifts
my mounts broke my rear engine mount bracket and my tranny bell housing where the bolts go in. any suggestions?
Old Nov 7, 2009 | 06:07 PM
  #294
what durometer of poly did you use?
did you cut the rear rubber out or just fill in with poly around it?
do you have all 3 mounts poured?
Old Nov 11, 2009 | 02:39 PM
  #295
StreetKA's Avatar
another question how to get the front mount out ? i know i need to lift the motor up but can i get from top or that has to be done from a bottom ? i know that sounds stupid but i have to prepare myself to what kind of tools and how many jacks im gonna need if necessary... i need quick answer. thanks
Old Nov 11, 2009 | 07:04 PM
  #296
DC3328's Avatar
Your Garage
my guess would be a jack under the oil pan
Old Nov 11, 2009 | 07:08 PM
  #297
phee's Avatar
I got the Shifts
60a
gutted and filled all three and i left the tranny mounts stock (thats where most of the vibration comes from)
Old Nov 11, 2009 | 07:09 PM
  #298
phee's Avatar
I got the Shifts
Originally Posted by DC3328
my guess would be a jack under the oil pan. make sure to put a piece of wood between them
fixed
Old Nov 11, 2009 | 10:57 PM
  #299
60a
i didn't gut my rear....just filled in the gaps. i know my rear moves because it bulges out at the bottom. the bulge is just the movement of the mount pressing the poly outward. maybe gutting the rear should not be advised since when the engine is under major throttle it rocks back, placing most of the downward force on it. sorry to hear about the troubles.
Old Nov 11, 2009 | 11:33 PM
  #300
phee's Avatar
I got the Shifts
yea. i would recommend not filling the rear.
its all good. ive got a new bracket and its in the shop for "re-inforcement"
Old Nov 12, 2009 | 09:34 AM
  #301
civicdrivr's Avatar
I didnt gut the rear either, just filled. The filling is starting to push out though.
Old Nov 19, 2009 | 08:24 PM
  #302
StreetKA's Avatar
i have my mount done today it was drying whole week and finally got it installed today i painted them black cuz i used the home depot poly 60A i must say its a huge improvement wheels still hop but not as much as it was b4
it took me 3 hours the remove old and install new one
Old Nov 24, 2009 | 09:13 PM
  #303
StreetKA's Avatar
so looks like home depot poly isnt good enough... again lesson learned cheap is expensive i have to do it again so here it is poly urethan 60A from homedepot for 3$ tube and after i poured it into my front mount i let it dry for like i think 10 days or more. after the pain with install it feels like a shit again...
here is the pic
Old Nov 24, 2009 | 10:02 PM
  #304
Rajca's Avatar
that sucks ass.
Old Nov 25, 2009 | 05:52 AM
  #305
mcmaster.com
Old Mar 13, 2010 | 04:36 PM
  #306
Rajca's Avatar
just pulled teh trigger on 80a. been told that 80a is holding up great from ppl that abuse their car a bit. so 80a with two nrg engine torque dampers will be enough
Old Mar 13, 2010 | 07:39 PM
  #307
civicdrivr's Avatar
^ Thats my setup
Vibrations are there but I couldnt be happier with it. They have about 20k on them, 6k of which are after the build.
Old Mar 13, 2010 | 07:40 PM
  #308
Rajca's Avatar
nice. thx for the update
Old Mar 18, 2010 | 12:51 PM
  #309
J32A26MT's Avatar
I'll put you in the wall
I don't understand why it would be bad to fill the rear mount. I want to take these lame ass torque dampers out and I would rather gut the rear and fill it. I was going to buy a new rear mount to fill, but maybe I will buy a new rear one and gut and fill the one with 86k on it so if i don't like it for some reason I have a new factory one I can use. Only problem is I would have to swap out the old one with the new one in order to fill the old one so my car is not out of comission for a week. That and it would be twice the labor and a pain in my ass. ANY THOUGHTS?
Old Mar 18, 2010 | 12:53 PM
  #310
J32A26MT's Avatar
Also, why not fill the bottom part of the front one where the fluid goes? In the beginning of this DIY the bottom was filled. If the bottom was filled along with the top inbetween the plate and cover wouldn't it be pretty damn strong? Is it not being reccommended just because it is unnecessary? Or is it bad for the fluid to not be in there?
Old Mar 18, 2010 | 03:19 PM
  #311
victorvu's Avatar
what do you guys think about 80a in front and the rest 60a?
Old Mar 18, 2010 | 04:56 PM
  #312
Rajca's Avatar
i gutted the front one, spilled out all the fluid and but 80a in it. ill make "another" diy with gutting the mounts then filling them
rubber that i took out to get the fluid out and ply in
will finish the rest when i get more poly
Old Mar 28, 2010 | 02:05 PM
  #313
J32A26MT's Avatar
Just ordered 2 of the 60A, I can't wait! Finally! Anyone able to give me some better insight on whether or not to fill the bottom of the front mount? I should have enough to do it if I don't do the rear one...
Old Mar 28, 2010 | 02:07 PM
  #314
Rajca's Avatar
fill in the bottom
Old Apr 5, 2010 | 02:17 AM
  #315
cu0ngsayz's Avatar
so hows the DIY coming? im in need of new mounts
Old Apr 5, 2010 | 03:13 AM
  #316
StreetKA's Avatar
+1
Old Apr 5, 2010 | 04:21 AM
  #317
Rajca's Avatar
progress is stopped. had to fix the damn tl and no i have to save up for court/ticket/lawyer costs. so all mods are put on hold
Old Jul 29, 2010 | 01:29 PM
  #318
AcuraTL99's Avatar
Sorry to revive this post.
Has anyone ever filled their mounts with 40a?
Old Jul 29, 2010 | 10:47 PM
  #319
Rajca's Avatar
40a is nothing. 60a is a bit harder than stock
Old Jul 30, 2010 | 02:53 AM
  #320
AcuraTL99's Avatar
I see, so basically the main mounts that have to be filled are the front and side just by reading from page 1 to now. Correct?
