Custom Poly Engine Mounts
Old Apr 17, 2009 | 12:32 PM
  #201
1hotcls6's Avatar
motor is back in. off to tune!
Old Apr 20, 2009 | 12:09 PM
  #202
civicdrivr's Avatar
Got 4 of the 5 in on saturday. Waiting to do the rear mount. It was hot as hell here saturday and I couldn't stay outside much longer. It doesn't rattle or vibrate alot, but it's noticeably more then stock. I like it. Clutch engagement, acceleration, braking and even gas mileage is now improved. I've got about 300 miles on since I put them in. I can't wait to get the rear in. I think that would make the biggest difference.
Old Apr 23, 2009 | 06:23 PM
  #203
IntenseMX's Avatar
How does this compare to:
https://acurazine.com/forums/2g-cl-2001-2003-50/polyurethane-motor-mounts-w-pictures-479527/
Really wanna do this, got new replacement mounts sitting right next to me.
Old Apr 23, 2009 | 09:10 PM
  #204
distortedolskool's Avatar
https://acurazine.com/forums/showthread.php?t=479527
i started with Jeremy's how to. then i ended up finding this poly online and going with it. the roofing poly is basically a substitution for the real thing.it is basically the same method, just a different substance.
Old Apr 24, 2009 | 10:16 AM
  #205
IntenseMX's Avatar
You think it will have similar results? i just spent 350 on my 3 montor mounts with lifetime warranty, don't really want to spend another 80 for poly lol...
Old Apr 24, 2009 | 10:22 AM
  #206
IntenseMX's Avatar
It's just "Jeremy" doesn't fill them inside the rubber he just covered them all around, where ever he could. Wouldn't that put more pressure on the rubber itself causing it to rip/ break alot faster?
Old Apr 24, 2009 | 11:11 AM
  #207
No i don't think so. The center pin flexes the rubber into the air spaces under load. with the air gaps being filled with poly it will slightly reduce the amount that the rubber can flex. i went a step further by cutting out and filling the entire mount. this way the center pin does not even flex against the soft rubber, its load is directly on the poly.
note on the rear 6mt mount i did not cut out any rubber. i just filled the gaps.
Old Apr 24, 2009 | 11:27 AM
  #208
IntenseMX's Avatar
I'll try Jeremy's way just because of the cost... Altho still deciding.. what to do what to do
Great project dude! This will for sure save ppl $ on mounts replacement!
Did you put some serious miles on this yet?
Old Apr 24, 2009 | 04:38 PM
  #209
chtrcy's Avatar
I have put a couple of hundred miles on mine and the vibration had slightly went away but the car still drives great. A far superior product than stock and I will do it all over again. I think 60a poly is the way to go but thats my
Old Apr 24, 2009 | 05:21 PM
  #210
civicdrivr's Avatar
I still need to swap in my rear mount, but it seems as though I won't be able to this weekend. Hopefully next weekend.
Old Apr 24, 2009 | 07:16 PM
  #211
Rajca's Avatar
wham bam thank you ma'am
whos got the 80A poly filled mounts? hows the rides, and vibration.
Old Apr 24, 2009 | 07:34 PM
  #212
civicdrivr's Avatar
That would be me!
I have only 4 of the 5 in so far, the rear isnt in yet. There is a noticeable amount of vibration at idle. Driving though is pretty normal. Ill update once I put the rear in. I may find some time sunday to do it.
Old May 9, 2009 | 12:57 PM
  #213
ryebreadisme's Avatar
Low and Slow
This thread is great! Much thanks to Jproy and distortedoldskool!
Old May 12, 2009 | 11:20 PM
  #214
TheSentinel's Avatar
Any update on the 80a?
I'm looking to do this but wondering if i should do it to new OEM mounts.
And since i doubt innovative will take my mounts back, Anyone know what the scrap price of these would be?
Old May 13, 2009 | 11:26 AM
  #215
civicdrivr's Avatar
80A here:
I still havent gotten the rear mount in
Ive been working 60+ hour weeks and no time off on weekends so I dont have the time to do it. With the other 4 mounts installed there is a noticeable amount of vibrations at idle. I assume doing the rear mount will make it worse. When you turn the AC on you definately notice it. Its not something that annoys me though. Once driving it feels just like stock, just without the wheel hop.
Old May 13, 2009 | 06:39 PM
  #216
60+ hours, ouch. One of my friends is pulling one of those months, haven't seen him drink too much yet.
Back on subject: So should i just put in the new OEM as is or with 60a or 80a(its cheaper atm).
Old May 13, 2009 | 08:23 PM
  #217
2Fast4you's Avatar
I read all the posts on this thread and got some good info but am still not sure what to do with a busted front mount I would like to just use the broken front mount I have but how would I do this properly?
Old May 13, 2009 | 10:00 PM
  #218
civicdrivr's Avatar
2fast: I sent you a PM.
Sentinel: My job is always like this If you have the time I'd suggest filling them with poly. What durometer is up to you though. I like my 80a but I came from a rock hard Civic, so Im used to the vibrations. Other members have used the 60a with great results. If you want something smooth Id suggest the 60a.
Old May 19, 2009 | 10:38 AM
  #219
chtrcy's Avatar
I like the 60A personally with because of the minumum cabin vibration with the A/C on. Upi to you. 80A will be harder and have more cabin vibration.
Old May 19, 2009 | 11:42 AM
  #220
civicdrivr's Avatar
x2. Once the A/C is on at idle, you feel it.
Old May 19, 2009 | 11:59 AM
  #221
typeR's Avatar
i thought id mention it was suggested a million years ago to control wheel hop the radius rod bushings should be swapped out with poly ...
Old May 19, 2009 | 10:01 PM
  #222
civicdrivr's Avatar
Yup, poly radius rod bushings do wonders. Do the bushings from an Accord fit?
I replaced the front crossmember in my Civic that used heim joints instead of bushings. It completely transformed the car.
Old May 19, 2009 | 10:06 PM
  #223
Rajca's Avatar
pic of what bushing u guys are talking about?
Old May 19, 2009 | 10:26 PM
  #224
civicdrivr's Avatar
Un momento
Old May 19, 2009 | 10:28 PM
  #225
civicdrivr's Avatar
#10 and 11.
EDIT: The 98-02 Accord use the same bushing, now to find a company that makes them.
Old May 19, 2009 | 10:33 PM
  #226
Rajca's Avatar
so polly fill those too???
Old May 19, 2009 | 11:03 PM
  #227
from what i remember these can't be filled. they are that crap rubber and should be replaced with actual poly bushings.
Old May 19, 2009 | 11:13 PM
  #228
http://www.mckinneyraceworks.com/cat...products_id=32
i'm pretty sure energy sells some poly bushing that would work
Old May 19, 2009 | 11:30 PM
  #229
civicdrivr's Avatar
I sent ES an email a few minutes ago. They dont have anything available for the Accord or the TL/CL. A quick cross reference of the Honda part # showed that only the Accord used the same bushing, but Im sure other models use it as well. Ill keep looking into this, as I still have a slight bit of hop in first gear under certain circumstances.
EDIT: The bushing for the Prelude fits the Accord/CL/TL?
EDIT 2:I think the Prelude bushings do in fact fit.
EDIT 3:No definative answer on the Prelude bushing. Dammit.
Old May 20, 2009 | 03:17 PM
  #230
typeR's Avatar
they cant be hard to modify
Old May 20, 2009 | 09:59 PM
  #231
civicdrivr's Avatar
Im going to look at a few other drop in methods for those bushings, as those definately curtail alot of wheel hop. I love me some spherical bushings, but I don't love modifying them.
Old May 21, 2009 | 03:36 AM
  #232
Anyone have any suggestions to poly filling the TL rear mount. The CL doesn't really compare in pics.
Old May 21, 2009 | 03:45 AM
  #233
here are the rest
need anymore pics?
Old May 21, 2009 | 09:33 AM
  #234
SPoolinspOON's Avatar
OG 3.x^7 rawr
same thing, cut a hole and drain the fluid. fill it
Old May 21, 2009 | 11:14 AM
  #235
2Fast4you's Avatar
would it be alright to just fill the front and side mounts with poly?
Old May 21, 2009 | 01:00 PM
  #236
phee's Avatar
I got the Shifts
hey guys. i got a brand new 6 speed rear mount that im letting go for 110 shipped OBO. thought id chime in for you guys. also got a side mount that has a bent bracket (easily fixable) for 30 bucks shipped.
pm me.
Old May 21, 2009 | 03:31 PM
  #237
whoa whoa. that mount is similar to the front mount and should not be drilled and drained. i'll take a look at those pics tonight and see. i'm thinking something very similar to what we did to the front mount, detailed in my awesome MS paint sketch.
i know someone PM'd me about the mounts and ill get to that later this evening. work has been pwn'n me.
post a link to the larger pictures (the first set-last picture is a great one) and one top view. i will sketch on them in pshop tonight and repost them. basically the same as the front mount. i am not sure if that mount had the shield like cap on it similar to the front mount. any idea?
Old May 21, 2009 | 05:36 PM
  #238
unfortunately i can't post/get to the pics at work, I'll put up the link as soon as i can, there seems to only be the dust cap pictured in the 2nd group last pic.
Old May 21, 2009 | 05:54 PM
  #239
civicdrivr's Avatar
I think you could tape off the sides to create a seal and then fill it like the front mount.
Old May 21, 2009 | 07:50 PM
  #240
jproy's Avatar
MP90 uninstalled
This is just damn genius!!!!
I am also in contact with them. They sell the LCA bearing replacements for the bushings for the 2002 Accord which is a direct fit replacement for our car, TL or CL.
I have also cross referenced all the part numbers for the radius rod bearing parts between the two cars and all of the first 5 digits are the same.
Prelude,
front bushing 51381-SM4-013
rear bushing 51391-SM4-013
disk washers 51399-SM4-000
bolt 90303-SF1-003 it is the same
TL/CL
front bushing 51381-S84-A01
rear bushing 51391-S84-A01
disk washers 51399-SOA-000
Even the radius rods have the same first 5 digits.
If I cant reach them I may just order a set and see what happens to the caster. They would work for sure but you may have to shim the radius rod to achieve the correct caster which would not be difficult. I have done it before. It would just take a steel collar sized to the correct length.
There was a thread here about what the first 5 digits meant, the second 3 digits, and the third 3 digits. Who wants to find it?
What a great mod this would be! I bet it would altogether eliminate the wheel hop.
