Custom Poly Engine Mounts
Old Feb 12, 2009 | 01:52 PM
  #121
jproy's Avatar
MP90 uninstalled
Originally Posted by fsttyms1
Well with the rubber in the ends i think it would keep vibrations from coming into the cabin. Either way i will be playing and trying to figure something out.
Could you make a 1/8 thick, high grade steel brace that would fit on top of the part of the upper support? Fold it over the sides of the existing support so it covers three sides of the upper support. It would look just like the existing upper support but fir right over it adding a ton of strength. Make it run the length of the upper support from fender to fender. That should make it plenty strong enough. Shouldnt be to hard to do with the right tools. Still cant wait to see how it turns out. Jim
Old Feb 18, 2009 | 08:44 PM
  #122
distortedolskool's Avatar
poured up the new front mount tonight. hope to install this weekend.
Old Feb 18, 2009 | 09:27 PM
  #123
jproy's Avatar
MP90 uninstalled
I poured my side and front. They are pretty solid. The front mount might as well be a solid mount. I have the untouched stock and untouched trans mounts still installed. I have little more vibration than stock but about as much as we would have imagined the Innovative mounts would have caused if they were built correctly. I nailed it through third and didnt get much wheel hop. I actually dont think I had any wheel hop, I think what I felt was the LSD swapping power from left to right and vice versa as each wheel lost traction. Remember, we dont have a quafe differential in there so I dont think we will ever be able to smoothly burn down both tires on dry pavement. What I felt was a slow controlled alternating pull to each side not a vilolent hop that made the whole car shake like it was going to come apart. I used 60A and intend to fill only the gaps on the trans mounts and the rear mount. I am VERY pleased with the results. My front Innovative mount was much more deformed than my Innovative rear. With just the 60A poly filled front and side I have about the same performance level as I had with all three Innovative mounts installed but without any of the harsh vibrations. Once the motor is warmed up, at idle, I cant tell the difference between my OEM poly filled and the stock OEM mounts, even with the A/C on.
Old Feb 18, 2009 | 10:14 PM
  #124
i can't wait. i believe we just might have done it.
Old Feb 18, 2009 | 10:19 PM
  #125
jproy's Avatar
MP90 uninstalled
And with the permission of Distortedolskool,
Thanks! I drove the car about 30 miles today and can't believe how much this does for the overall performance of the car! It's amazing how responsive and connected the handling, braking, and acceleration are with the proper mounts!
Old Feb 18, 2009 | 10:27 PM
  #126
jproy's Avatar
MP90 uninstalled
Thought you might want to see the Innovative failure.
Rear mount
Old Feb 18, 2009 | 10:54 PM
  #127
oooo i've been whore'd!
i took progress pics tonight and i'll post tomorrow. the cut mount sections really show the details and are very informative. thanks for the help with these mounts!!
btw digital calipers way better than my OG dial calipers.
Old Feb 19, 2009 | 12:17 PM
  #128
jproy's Avatar
MP90 uninstalled
Drove another 30 miles this morning. I think we did!^^^^^^
Old Feb 20, 2009 | 11:53 AM
  #129
EL19's Avatar
good job guys
Old Feb 20, 2009 | 01:58 PM
  #130
J32A26MT's Avatar
I'll put you in the wall
The more I look at the front mount taken apart...the more it confuses me. I don't understand how it works. I see that you cut the rubber top out out to fill the inside with poly, and put the rubber back on it. It looks like there is a cover, too. Did you fill up any other part with poly? I see the bolt that goes through the mount to the outside, so i understand the goal is to keep it from flexing up or down as the motor moves. I am picking up a new front mount for $35 today so maybe it will make more sense after i get to mess around with it.
The side seems fairly easy to strip and fill. I am going to order one today, as well. Have either of you stripped out a rear mount yet to fill it correctly?
Do you like the 60a...or would you reccommend the rest of us getting something stiffer?
I can't wait to do this. Thanks for all your R&D on this Distortedolskool and JPROY. I will also post my pics whenever I get mine completed.
Old Feb 20, 2009 | 07:58 PM
  #131
ok here is another diagram. the black is the front mount main body, the blue is the metal/rubber plate that goes on top, and the red is the cage or retainer. the yellow is the poly that will be poured. as seen the poly will push against the red cage and keep the black "rubber piston" from moving up. i originally only poured poly below the blue plate and that stopped all downward movement but did nothing for upward forces. (thank jim for figuring out the details on the piston movement and cage purpose.)
Old Feb 21, 2009 | 09:30 AM
  #132
SPoolinspOON's Avatar
OG 3.x^7 rawr
so how is everyone handling warranty on the Innovate mounts? exchange and sell?
Old Feb 21, 2009 | 11:57 AM
  #133
jproy's Avatar
MP90 uninstalled
The diagram is very accurate. I will post more also as the r&d progresses. Have 150 miles on em now and couldnt be happier. All the slop in the driveline is gone. Car feels so solid. Good work distorted! By the way, you dont need new mounts. Everything i am using was badly blown as an oem mount. The poly uses the solid structure of the mount to do what it does. When will this be stickied???????
Old Feb 24, 2009 | 04:04 PM
  #134
Billy Sacco's Avatar
Kilos of yayo in
I know you guys are on the right track. I mean if you just compare the innovative mount to the oem, OEM mount is just so much beefier and solid. Now I wish I did not throw out my blown side mount . As for the Innovative warranty I think they will just give you more of their crappy mounts after you pay to have your blown ones shipped back to them. No thanks.
Old Feb 27, 2009 | 10:05 PM
  #135
jim-
oooooo my how lovely it is!
i don't think my innovative mounts provided this much support and traction, and mind you without the vibrations. this has got to be the best thing yet, besides a SC.
currently my setup is the 60a filled front, 60a gutted and filled side (with 6speed counter weight on the side) and the 60a filled rear mount. if anyone needs some poly and wants to try the 80a i will have a can in the black market.
Old Feb 27, 2009 | 10:32 PM
  #136
civicdrivr's Avatar
Just one can for sale?
Old Feb 27, 2009 | 10:35 PM
  #137
i am now also accepting offers on my old innovative rear mount...
makes a great door stop
a perfect dvd/book stop
or better yet, an awesome tp holder. i saw less roll hop when i wheeled off the sheets!!
Old Feb 27, 2009 | 10:55 PM
  #138
yep one extra can of 80a that i decided not to use.
https://acurazine.com/forums/showthr...8#post10581818
Old Feb 28, 2009 | 01:10 AM
  #139
DC3328's Avatar
Your Garage
great job guys
Old Feb 28, 2009 | 12:34 PM
  #140
jproy's Avatar
MP90 uninstalled
That is great news! I am still loving mine. I will pull and pour the rear and trans mounts today with 60a. I now have 450 miles on my custom mounts. They are still perfect and have no defornation. If anyone wants to do this to thier mounts and doesnt feel comfortable doing it themselves, i will pour your mounts if you ship them too me + parts/labor. Pm me if you want to do it. We still need someone with an auto too see what happens when we fill the rear. I will help someone with appropriate mods to figure this out.
Old Feb 28, 2009 | 10:19 PM
  #141
another austin local, chtrcy, should be purchasing his poly this week. i keep hounding him to be the first auto with these mounts.
i just got back from 2 car meets tonight and love the new mounts. i still haven't picked up my synrcomesh yet from gm. hopefully get to that this week since work has calmed itself some.
Old Feb 28, 2009 | 11:12 PM
  #142
OG 3.x^7 rawr
sweet. I ordered my poly yesterday...I will be filling my mounts when I get a chance.
I'm running GM Synromesh Friction modifed....god stuff but I wouldn't run it too long. I use it as a conditioner for 10k miles and then switch back to Honda MTF.
Old Feb 28, 2009 | 11:16 PM
  #143
why only that long and not the full switch?
Old Mar 16, 2009 | 08:10 PM
  #144
just pulled the transmission mounts out tonight. they appear to be similar to the side mount as it looks to be filled with hydraulic fluid and have the rubber bubbles. i am going to cut the bubbles out and drain the mounts. i will leave enough rubber to hold the center pins stable while the mount is filled. the 60a poly should be in tomorrow. out on the street by friday!
i also did the syncromesh switch but have yet to take her out.
Old Mar 16, 2009 | 09:18 PM
  #145
jproy's Avatar
MP90 uninstalled
Good work! Im still enjoying mine. I didnt get a chance to do the rear or trans mounts yet.
Old Mar 16, 2009 | 10:49 PM
  #146
phee's Avatar
I got the Shifts
very good thread. i will have to look at it in detail. got a front, side, and rear mount today. i think i have an extra side mount for a 6 speed laying around. anyone want it? pm
Old Mar 16, 2009 | 11:28 PM
  #147
chtrcy's Avatar
Kevin...I brought my front and side mount from the garage and I guess I will get with you on Saturday and order mine for the auto...
Old Mar 16, 2009 | 11:44 PM
  #148
sinfulj32's Avatar
cant wait for the tranny mounts update... i've been wanting to do them for a while. good work guys
Old Mar 17, 2009 | 12:55 AM
  #149
jproy's Avatar
MP90 uninstalled
I wanted to say, if you are using new or good OEM mounts, it is not necessary to cut the large thick rubber diaphragm that holds the post in place. I only did it to see what was inside. You can drain your good mount of fluid if you want by drilling a hole through the bottom of the mount if you want but I do not see how removing the fluid from a non-blown mount is necessary in any way. Probably better to just leave it alone. FYI
Old Mar 17, 2009 | 06:35 PM
  #150
yes on the front mount i did not cut anything, only added.
as for the trans mounts, they do not have fluid in them. just solid rubber that is a beast to remove. one down...
Old Mar 17, 2009 | 08:07 PM
  #151
chtrcy's Avatar
Just ordered the poly for my automatic and will start on them in a couiple of weeks. Will keep you updated on the progress.
Old Mar 18, 2009 | 12:45 AM
  #152
sinfulj32's Avatar
do you need to cut out the stock rubber?
Old Mar 18, 2009 | 02:04 AM
  #153
the poly doesn't adhere to well to the rubber and with the 4 rubber brackets and 2 bubbles the majority is all rubber. this does not allow enough room for the poly to fill in and bond to itself. i believe the rubber would just push out under load. with the larger mass of rubber it handles the loading better and does not squeeze out.
i will be pouring them tomorrow after work. i had to leave to go to sxsw tonight so the mount project went on hold.
Old Mar 18, 2009 | 02:10 AM
  #154
Accord_V6_400m's Avatar
4drs just wanna have fun!
Hows the vibration with all this 60A polyurethane? This should be equivalent to the innovative 60A mounts.
Old Mar 18, 2009 | 06:11 AM
  #155
very very minimal, almost not even noticeable. the poly might be the same hardness as innovative but that is the only thing they share in common.
Old Mar 26, 2009 | 05:36 PM
  #156
the trans mounts are in and all is well. and all i can say is traction is a wonderful thing.
slamming it in first from a stop gets you very very minor hop but mainly squealing tires. this is a great improvement because with stock mounts you get uncontrollable wheel hop. first from a roll just give you more chirping and no hop. this is just as good as, or better, than the innovative mounts. obviously better because the interior vibrations are barely noticeable. they did not increase any with the trans mounts completed on top of the 3 others. jim...
if you are currently hating your innovative mounts. spend $66 in poly and get what you were originally looking for. and if you need help let me know. this weekend i will be starting the first poly auto mounts.
Old Mar 27, 2009 | 11:28 PM
  #157
civicdrivr's Avatar
I've got to do this really soon. I just have to many things on my to-do list right now
Old Apr 6, 2009 | 09:56 PM
  #158
chtrcy's Avatar
Distortedolskool (Kevin) came over to the casa today and we pulled my front and side mount out and will be filling them with the 60a poly tomorrow. Should be reinstalling them on Thursday. Cant wait to see what the automatic does with VSA off!
Old Apr 7, 2009 | 08:40 AM
  #159
Old Apr 9, 2009 | 10:36 PM
  #160
civicdrivr's Avatar
Pouring them this weekend! Im going to let them setup all next week and install next weekend. Wish me luck!
BTW, Im running 80A all around.
Quick question, what did you use to inject the poly into the mount? Did you just pour it in?
