Custom Poly Engine Mounts
Old Dec 16, 2008 | 07:48 AM
  #41
fuzzy02CLS's Avatar
I would leave them in. Why would Acura put them in if the car didn't need them for some reason. Mine were left on with stock & innovative.
Old Dec 16, 2008 | 10:41 AM
  #42
jproy's Avatar
MP90 uninstalled
They are useless in the oem application and completely negated with a mount firm enough to reduce or eleminate wheel hop. If they did what Acura wanted them to do, we would not be having this conversation. It really doesnt matter either way though. Your call.
Old Dec 16, 2008 | 11:22 AM
  #43
jproy's Avatar
MP90 uninstalled
Fuzzy, you know that argument is like swiss cheese. We all know Acura has done a lot of things they could have and probably should have done differently.
Old Dec 16, 2008 | 09:04 PM
  #44
distortedolskool's Avatar
well all the mounts are installed. everything went pretty smoothly except for the rear. it needed a little twist to get the bolts all started. all i have left is to tighten up the front mount bracket. one of the bolts has to be tightened from underneath but i'm DONE for today. so tomorrow tighten, then road test.
Old Dec 16, 2008 | 09:12 PM
  #45
poisx7's Avatar
well cant wait to hear the results, but the true test is in a three - 4 months when they are settled in well.
Old Dec 16, 2008 | 10:21 PM
  #46
jproy's Avatar
MP90 uninstalled
Man, get your ass out of bed! Tighten the fricken bolt and go burn some rubber.
J/K! Seriously though, you are killing me. I am dying to know how this worked out for you. Since I looked at my front innovative mount and noticed it is completely collapsed I am in dire need of an alternative. GET IT DONE SON!!!! Look luck. Cant wait for the results.
Old Dec 16, 2008 | 10:23 PM
  #47
civicdrivr's Avatar
Roadtest!!!!
Old Dec 17, 2008 | 06:57 PM
  #48
road test: no weird vibrations in neutral at idle. there is a small increase compared to stock, or from what i remember stock being. a very very very slight increase in vibrations in neutral with AC on. before with my innovative mount when the AC was turned out the vibrations more than doubled and increased in sound. in first gear barely rolling (parking lot style) no increases. it is misting outside so i did some punches from 5mph and up. the wheel hop still happens in first but it was that way with the innovative. from what i can tell the amount of hop did not increase. it's hard to say without a way to measure but i know for a fact it is way better than stock.
basically these provide what we wanted the innovative mounts to do. less wheel hop, more traction and daily tolerant vibrations. now to just drive and see how they age!
side notes: i do not have front or rear engine dampers installed. also i noticed that the IM rear mount is very squishy as compared to my IM side mount poly. does IM not have a consistency for their mounts? my home brewed 60a poly is much stiffer when poked as compared to the IM poly. i believe my mounts are stiffer but for some reason cause less vibrations.
Old Dec 17, 2008 | 07:12 PM
  #49
jproy's Avatar
MP90 uninstalled
They cause less vibration because they are aligned like they are supposed to be, something innovative didnt give a shit about doing.
Good job! I will be pulling my front innovative mount shortly and will purchase the poly fill you used. I will try it too. Tell me you took some pics of the mounts showing how much and where the rubber you removed is? Thanks, Jim
Old Dec 17, 2008 | 08:35 PM
  #50
http://www.mcmaster.com/nav/enter.asp?partnum=8644K24
you will need 2 cans for all mounts but you might be able to squeeze just one. instead of measuring it out 10:1 (don't quote me) i just mixed the entire amount and had some leftovers. i figured it was better to have extra then to have a "cold joint" within the mount.
i wanted to measure the height of the stock and IM pins but forgot to. i figured the vibrations had to have been created just from the dimension errors. it was a sign when those damn things had to be forced in.
little DIY:
on the front and rear mount i did not cut out any rubber. i thought i took a pic of the side but i am unable to locate it. basically on the side i cut the rubber bubble at the top out and drained the mount. the bottom piece appears to be solid but is not. the only solid part is 2 small rubber bars at approximately 8:00 and 4:00. from 4-8 is just a thin layer that can be cut out. the 2 bars will hold the center pin in place. just rinse it out very well and then fill.
for the front i removed the top cover and top plate. just sand the rubber to roughen it with the dremel. i put the top plate back on and tightened the nut down. Then you can wrap the mount in duct tape except for a small pour hole. this poly fills the front and forms a pancake.
on the rear mount i just sanded, taped up one side and then filled the mount.
if you need any sketches or clarifications please just let me know.
Old Dec 17, 2008 | 08:46 PM
  #51
nbennettksu's Avatar
i heart latin chicks
A video, Kevin, or it didn't happen
Old Dec 17, 2008 | 09:07 PM
  #52
shit you know i don't mess around when it comes to DIY.
a video of what...my car actually out of the garage for once? none the less, out of the garage in the rain/mist! now it's water spotted damn it!
Old Dec 17, 2008 | 09:25 PM
  #53
LIPPSTUH's Avatar
Unregistered user
Sounds like a great diy . I'll wait till summer comes gj
Old Dec 17, 2008 | 10:01 PM
  #54
naw I was jk man. I know its a top notch job
Old Dec 18, 2008 | 12:48 AM
  #55
civicdrivr's Avatar
Nice. Can't wait till you've got some miles on this. I wonder what wheel hop would be like with slightly stiffer poly?
Old Dec 18, 2008 | 08:45 AM
  #56
CleanCL's Avatar
They cause less vibrations because they are not made entirely of polyurethane. At any rate, still a nice job. You are pretty damn handy.
Old Dec 18, 2008 | 01:25 PM
  #57
nf3d0149ab's Avatar
Old Dec 18, 2008 | 01:57 PM
  #58
Billy Sacco's Avatar
Kilos of yayo in
Just makes you wonder why innovative did not just completely copy the stock setup and add some reinforcement to that.
Old Jan 7, 2009 | 12:47 AM
  #59
LIPPSTUH's Avatar
Unregistered user
any updates on the performance/durability?
Old Jan 7, 2009 | 01:37 AM
  #60
its his weekend car, maybe ask again on Sunday
Old Jan 7, 2009 | 06:08 AM
  #61
everything seems to be holding up, no visible "doughing". i still have not installed the stock or NRG dampers yet. when i installed the mount one of the NRG dampers was pulled apart. those things always seemed like junk as i could never get them to depress. and yes this is all after only like 25 miles total, yep weekends.
Old Jan 7, 2009 | 10:54 AM
  #62
LIPPSTUH's Avatar
Unregistered user
it'll take you 10 years to put 1,000 miles to test them
Old Jan 7, 2009 | 05:23 PM
  #63
might be going to dallas in 2 weeks so that's 200 miles each way. i'll report back when i log some miles.
Old Jan 7, 2009 | 11:23 PM
  #64
krazykrnboi's Avatar
Wide Body 3.2 CL-S
DALLAS... i live in dallas... :P let us know how this goes
Old Jan 8, 2009 | 08:06 PM
  #65
chtrcy's Avatar
Kevin...is this what we discussed on Saturday for a trip to Dallas?
Old Jan 8, 2009 | 09:45 PM
  #66
yes sir on the 24th. G money says he is also going up there.
https://acurazine.com/forums/showthr...396371&page=13
btw: how's vegas?
Old Jan 9, 2009 | 09:45 PM
  #67
Elijah J's Avatar
...So many of my questions were answered in this thread! ~ Wheel hop indeed!
Old Jan 10, 2009 | 12:14 PM
  #68
chtrcy's Avatar
CES is da BOMB. BTW kevin...You CL-S is on the pamphlet for the Texas Heat Wave shows!! Yes everyone... a Acura CL-S is on a pamphlet that will be distributed to all the Heat Wave car shows across Texas!!
Old Jan 12, 2009 | 01:38 PM
  #69
i need someone else that is fed up with their innovative mounts to do the custom poly. we need to get a daily driver so that some miles can be logged in. or we can wait for my 50 mile weekends to add up. it would help if the innovative mounts were still in the car as it takes about one week for the poly to fully cure before they are installed.
OH HELL YA! i will post a scan of this flier once you bring it home.
Old Jan 12, 2009 | 02:01 PM
  #70
civicdrivr's Avatar
I wanna do this but I currently have my OEM mounts in there.
I'm pretty sure my front mount is toast. I'll probably buy all new mounts and poly-fill them. How long would it take someone who has never done the mounts in this car to swap them?
Old Jan 12, 2009 | 02:41 PM
  #71
Kilos of yayo in
How long does it take to cure? I have not gotten a chance to put stock front mount back in the car so I would be game.
Old Jan 12, 2009 | 05:11 PM
  #72
it will cure to the touch in 24 but i remember the instructions saying like 5 days for full cure. we need the full potential strength of the poly so you will want to let it cure the full time.
as for the installation of the front and side mounts it can be done in around 1-1.5 hours. the rear is the bitch. i would say around 2-3 hours.
Old Jan 12, 2009 | 07:25 PM
  #73
chtrcy's Avatar
I have my side and front mount sitting in a box in my garage. I will get with you on Saturday and see what it ill take to do this. Call me and we can meet up on Saturday. I drive about 200 miles a week.
Old Jan 12, 2009 | 11:10 PM
  #74
if you want to go on this i will order the poly tonight and it will be here by the weekend. lemme know.
Old Jan 13, 2009 | 06:36 AM
  #75
SPoolinspOON's Avatar
OG 3.x^7 rawr
I think i'm going to do this. I'm guessing it doesn't really matter if you use a used mount, as long as it isn't ripped....Now did you hook the vaccum back up for the front and Rear?
Old Jan 13, 2009 | 12:57 PM
  #76
the front yes because i did not rip into the mount. i just filled the air gap with the poly. i have a 6spd so my rear is different, no vacuum. for you folks that are auto treat it just like the front mount.
Old Jan 13, 2009 | 06:30 PM
  #77
jproy's Avatar
MP90 uninstalled
I haven’t been on in a while and saw this thread update just now in my email. Ironically, I left the Acura dealership one hour ago with two blown front mounts and one blown side mount for this very purpose. They were going to throw them away so I grabbed them. I was there having the wife’s RDX serviced. I have one blown and good (new) side mount as well as one extra good (new) front mount. So I have 3 front mounts and 3 side mounts. The car currently has the IM front and side installed with the stock 6MT rear mount. I will dissect one of the front mounts and decide what is the best method to fill for taking a pounding. I will tear the diaphragm to see about filling the whole front mount. I’m probably going to order the poly fill tonight. I will take pics and post when I'm done. It may be a few days as I am very busy. I have another auto 02 TL I own with a blown front and side mount also so I will probably see about the mounts for it also. Jim
Old Jan 13, 2009 | 06:45 PM
  #78
good to hear! i didn't tear into the front at all and would really like to know what's inside of it.
Old Jan 14, 2009 | 07:27 PM
  #79
typeR's Avatar
drum roll.......
with only the rear mount replaced i have MUCH less vibrations at idle. when i turn the AC you have to try to feel the increase in vibration. with the innovative rear you just turn the AC on and you could here the vibrations. no street test yet as tomorrow i will do the front and side.
*side note: i took out the rear damper due to having to spread the bracket apart and have not put it back in. i was nailing the motor and she didn't move at all, so that raised a question. do i even need the dampers with the stiffer mounts? i will probably put it back in just cuz.
i pulled mine seems like i remember almost 10 lbs with zero neg. affects
Old Jan 14, 2009 | 07:29 PM
  #80
typeR's Avatar
btw my front rear and sides were all filled with window weld for a long time with many many many track and hard street launches... my front accord v6 mt is my first cls mount filled also
