Custom Poly Engine Mounts
Old Apr 9, 2009 | 11:12 PM
  #161
distortedolskool's Avatar
Pouring them this weekend! Im going to let them setup all next week and install next weekend. Wish me luck!
BTW, Im running 80A all around.
Quick question, what did you use to inject the poly into the mount? Did you just pour it in?
just pour it in nice and slow. the bubbles will rise to the top but you can vibrate it to help them rise faster.
chtrcy will have his mounts back in tomorrow evening. will report back with an update on an auto with front and side mounts filled. the rear will start next monday.
Old Apr 9, 2009 | 11:28 PM
  #162
civicdrivr's Avatar
Thanks for the fast response!
Ill let you guys know how it goes.
Old Apr 11, 2009 | 12:17 PM
  #163
1hotcls6's Avatar
sweet
Old Apr 11, 2009 | 12:45 PM
  #164
civicdrivr's Avatar
Three of the five are done. I had the front mount all taped up, or so I thought, so when I poured it it leaked. Oh well, I've got another can and I've still got to do the pass side mount. 80A is STIFF. I can't wait to install them.
Old Apr 11, 2009 | 09:23 PM
  #165
just finished the front and side on chtrcy's auto. damn! no mas hop and plants the tires now.
Old Apr 11, 2009 | 10:53 PM
  #166
Rajca's Avatar
wham bam thank you ma'am
im gonna do this when my car is gonna be taken to the track.
Old Apr 11, 2009 | 11:49 PM
  #167
meant to also mention:
vibrations are increased slightly. you can here it in the cabin but it is very tolerable. i did notice an increase in vibration with the car first idles down near a stop. mine does the same thing in the 6 speed if i let the RPMs fall low.
Old Apr 12, 2009 | 12:32 AM
  #168
civicdrivr's Avatar
60A or 80A?
Old Apr 12, 2009 | 12:54 AM
  #169
60A or 80A?
60a
Old Apr 12, 2009 | 10:28 PM
  #170
jproy's Avatar
MP90 uninstalled
great work guys
Old Apr 13, 2009 | 08:01 AM
  #171
chtrcy's Avatar
The vibration is a little noticable but tolerable. I turned the VSA off and punched it with absolutley no wheel hop. That is a beautiful thing.
Old Apr 13, 2009 | 08:16 AM
  #172
SPoolinspOON's Avatar
OG 3.x^7 rawr
man...I have the poly sitting at my house....no time to do this yet
Old Apr 13, 2009 | 10:19 AM
  #173
1hotcls6's Avatar
where can I get the poly from?
Old Apr 13, 2009 | 12:34 PM
  #174
pages dos:
http://www.mcmaster.com/nav/enter.asp?partnum=8644K24
Old Apr 13, 2009 | 12:39 PM
  #175
civicdrivr's Avatar
Finished pouring them yesturday. I really hope 80A isn't TOO stiff.
Im installing them this coming weekend. Im going to let the cure first.
Old Apr 13, 2009 | 12:46 PM
  #176
hopefully not but you're the first to run it. i'm sure you will have a little more vibrations than with the 60a. but in the same hand with that comes less movement and more traction.
your vibrations should not even come close to what people were experiencing with the innovative mounts.
Old Apr 13, 2009 | 12:52 PM
  #177
1hotcls6's Avatar
Is one can enough?
Old Apr 13, 2009 | 01:09 PM
  #178
civicdrivr's Avatar
Originally Posted by 1hotcls6
Is one can enough?
I used two. You may be able to use one, but I messed up on the front mount (didn't seal it up all the way) and had to re-pour it.
Old Apr 13, 2009 | 01:39 PM
  #179
jproy's Avatar
MP90 uninstalled
Two cans is enough to do the five mounts on the 6-speed. It takes all of one can to do the front and side mounts and will take probably half of another can to do the two transmission side mounts and the rear mount. I think using 80A on the front mount will not be a bad idea. Using 80A on all the mounts would not cause any more significant vibration. Its not that much more stiff. I went with 60A on the front and side and think it is plenty stiff. I still have not done the trans mounts or the rear and it is good enough as is. I will still be pouring the trans mounts and rear mounts with the 60A as soon as I have time to take them out for a few days.
FYI!!!! It is very important you let the poly set up for a few days before installing them. The instructions say to let it set up for seven days. You could probably install them after only 2-3 days but I would not do any spirited driving until 7 days has passed. Also my front mount has settled creating about 1/2 a millimeter gap between the top of the poly and the steel collar on the frong mount. I will probably pull it out and put a coat of poly between the collar and the existing poly just to get a tight seal. I have not noticed any reduction in performance because of the settling. The settling stopped about two days after I installed them and I now have 4000 miles on them since and they have not settled any more. Still very happy with the results.
Old Apr 13, 2009 | 01:41 PM
  #180
i just did one side and one front and used up an entire can, until the last drop. i could of used about another ounce because i split some. so you need 2 cans for all of the mounts. as stated by jim above.
Old Apr 13, 2009 | 02:55 PM
  #181
chtrcy's Avatar
I would highly recommend people doing this. I get better response from the engine when pushing the pedal.
Old Apr 13, 2009 | 05:59 PM
  #182
Rajca's Avatar
any diy, with pics and a step by step procedure.
Old Apr 13, 2009 | 06:30 PM
  #183
jproy's Avatar
MP90 uninstalled
I agree! The car feels like it pulls harder when I hit the accelerator.
Old Apr 13, 2009 | 07:18 PM
  #184
sorry no diy. just pics and 5 pages of chatter. there is plenty of info in this thread for anyone to tackle this. if you see something i didn't cover or have a question just ask.
  #185
civicdrivr's Avatar
BTW, I filled brand new mounts, so if anyone wants my old mounts, let me know. Im taking them out this weekend. They are from a 6 speed.
Old Apr 14, 2009 | 04:02 PM
  #186
JCharged's Avatar
Damn still waiting to do mine. Glad you all found a solution to the innovative mounts
Old Apr 14, 2009 | 07:43 PM
  #187
1hotcls6's Avatar
im waiting for mine to dry =]
Old Apr 15, 2009 | 06:29 PM
  #188
chtrcy's Avatar
Should be doing the rear mount probably next week.
Old Apr 15, 2009 | 07:01 PM
  #189
1hotcls6's Avatar
Heres my poly filled mounts with 60a. did all five. dropping the motor back in tomorrow
Old Apr 15, 2009 | 08:18 PM
  #190
OG 3.x^7 rawr
did you guys just use duct tape to seal the holes and pour?
Old Apr 15, 2009 | 08:29 PM
  #191
Rajca's Avatar
how does it feel went u try to move the urethane by hand?
Old Apr 15, 2009 | 10:51 PM
  #192
jproy's Avatar
MP90 uninstalled
1hotcls6,
Very clean work! Lookin' good!
Old Apr 15, 2009 | 11:03 PM
  #193
it doesn't move much by hand.
damn that is one clean front mount. that was the most difficult one to get completely filled.
Old Apr 16, 2009 | 07:26 PM
  #194
Chris's01's Avatar
Thumbs up Motor and Transmission mounts from Innovative Mounts.
I received my black hard poly mounts about 2 months ago and had them installed this past month by my local Acura dealership, they went on with no problems!, yes the car is going to have more pass through vibration in the steering wheel but other than that they are great! I had Acura check them this past week and they have not warped or been f-up. They include new more updated hardware.
I truly believe that they have worked out most of their issues in the past and I would recommend them any time.
Old Apr 16, 2009 | 07:44 PM
  #195
1hotcls6's Avatar
they are oretty damn firm. i love the way they came out!! motor is back in now, and car is off to tuning tomorrow!
Old Apr 16, 2009 | 07:53 PM
  #196
jproy's Avatar
MP90 uninstalled
Lets see some pics and please put them in the proper thread, The innovative mounts thread. It has grown quite large. This thread is about making our own mounts. Thanks for the info though. Im still skeptical
Old Apr 16, 2009 | 08:19 PM
  #197
1hotcls6's Avatar
i just wanna whore on this thread, cant wait till tomorrow!
Old Apr 17, 2009 | 07:56 AM
  #198
civicdrivr's Avatar
Mine go in tomorrow!!! And not a moment too soon!
Mine don't move at all.
  #199
civicdrivr's Avatar
x2
Old Apr 17, 2009 | 12:17 PM
  #200
nf3d0149ab's Avatar
Looks great!
I think this is awesome you guys are making these.
