Comptech Fuel Pressure regulator
No, because it is fairly linear and closer to a standard FPR when in vacuum. So you cannot lean it out by dropping the pressure. The ECU would detect the lean condition during idle and part throttle and adjust the fuel trim to the positive side. This would then be utilized during WOT pulls adding pulse width.
It may be useful at the track though by dropping the pressure right before a run to lean it out some and before the ECU has compensated. However, by the time you got back to the staging lanes after a run the fuel trim would be on the positive side.
Because you want to have the ability to tune yourself, the e-Manage will be your only real option. Since you can adjust timing as well as fuel (and have better resolution and finite mapping) you will have the ability to make more power with the e-Manage.
xsilverhawkx
09-28-2015 06:51 PM
