03 type S intermittent starting/idling trouble
New car, 150k miles 6 speed. For about a week I didn’t have the issue, then one day I was starting the car, 3rd or 4th time I started it that day, and for some reason it cranked for an extra long time, struggled to start, then once it started it blubbered too life, rough sporadic idle, lasted about 15 seconds, car drove fine. That whole day it struggled to start, took a couple tries sometimes. Next day had no trouble, till about a week or so later (now). I’ve started the car maybe 5-6 times today and it progressively gets worse as the day goes. Same symptoms.
just did coils and spark plugs. Anyone have any ideas? Should I clean the EGr valve? I didn’t think it was the starter because the car turns over and cranks fine, and usually starts perfectly fine most the time.
Read over the thread below, note any similar symptoms you may be experiencing, it may be of some help if the relay has not already been replaced.
I had to replace the fuel main relay on both my automatic and CL-S6.
Fuel Pump Relay Problem... - AcuraZine - Acura Enthusiast Community
If you give it a go, make sure to get an OEM one. Sometimes you can get OEM off ebay for cheap. Just make sure it's not a look a like foreign 'knock-off' and the vendor is Acura / Honda. Best results are achieved by searching on the part #.
This thread gives a good idea as to where it is located.
DIY: Locate PGM-FI / Fuel Pump Relay / Main relay - AcuraZine - Acura Enthusiast Community
Good Luck!
Good Luck!
Good Luck!
Good Luck!
Which brand were the coils and plugs? What type os spark?
The OP to this thread has a 'build' going on over at:
If so, maybe you've seen / heard about OP's build?
Denso coils and spark plugs, got every fluid refreshed and filled when I bought it. I even run premium 92 ethanol free gas. Recently though I haven’t had the problem, probably for at least a few weeks
