Maint Req light
Old Dec 31, 2010 | 03:16 AM
PrideInUSA's Avatar
3rd Gear
Maint Req light
K so I have googled around for a while looking for a answer, and I would like to just double check. I have a 05 6speed tsx with just about 100,5xx miles and the maint light is blinking ten times. From what I understand its just the car telling me to take it in for the 100k check up. But to be honest I didn't realize it would flash till after I had a little problem today. I stopped somewhere and quickly turned the car off, then went to stick the key to the 2nd position for the radio to be on. Well I did it so fast the car stayed on. This is when I realized that light was blinking? Is it just the 100k check up or could there be something worse? Thanks in advance..
Old Dec 31, 2010 | 04:05 AM
AZN.M3NACE's Avatar
USDM -> JDM
All you have to do is turn the car off, hold the select/reset and as you are holding the select/reset button, turn the key to ignition II position, then keep holding the select reset button until the maint req light turns off. Once it turns off, start the car and the light will be gone. Hope this helps.
Old Dec 31, 2010 | 03:55 PM
Simba91102's Avatar
Old Guy
Sounds like you just need service. That's all that the maint. light indicates. If there's actually something wrong, one of the other idiot lights will come on. The maintenance light starts blinking at around 8000-8500 miles since the last time it was reset. By 10K miles it will stay on. The reset procedure is in the owner's manual (which you will do AFTER you do the required maintenance I assume).
Old Dec 31, 2010 | 04:17 PM
PrideInUSA's Avatar
3rd Gear
So its nothing bad then? Was just checkin! and thank you =]
Old Jun 18, 2011 | 10:02 AM
06mdx08tsx's Avatar
can you clarify what the select/rest button is?.. My local guy did a oil change as a favor and couldn't figure out the rest...
Old Jun 19, 2011 | 05:23 AM
Simba91102's Avatar
Old Guy
It's the button that protrudes from the dash (looking at the gauges, it's below the temperature gauge) on the LEFT side. The one you use to reset the trip odometer and to select the A or B trip odometer. And not that it makes any difference (cause there's nothing you can do about it), pushing it to reset the maintenance light will also reset the trip odo that is presently displayed (A or B).
Old Jan 7, 2013 | 05:00 PM
spin70er's Avatar
2008 TSX, tried what you had stated to turn off, but light stayed on. Held button for close to a minute with nothing happening. Is there something that is different for my year TSX?
Old Jan 8, 2013 | 04:51 PM
Simba91102's Avatar
Old Guy
Your car has a completely different system. The 04 and 05 TSX's have only a maintenance light that indicates maintenance is required every 10K miles. Starting in 06, a "Maintenance Minder" system was installed in the TSX. This has a display with 2 letter codes coupled with 5 number codes that indicate various items when they're in need of service. The reset procedure is in the owner's manual (along with a complete explanation of the maintenance minder codes), and is quite a bit more involved. RTFOM!
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
heykosal
1G RDX Problems & Fixes
Feb 27, 2016 06:43 PM
Greengecko
Sep 16, 2015 08:19 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
