TSX has bad MPG by default?
Old Jul 16, 2008 | 01:56 PM
czr's Avatar
czr
I think something is seriously wrong with my car, everything works fine only except i get an average around 7mpg.
Is this normal for stock configuration? I havent flashed my ecu yet but you shouldnt have to hack the ecu just to get near at least a decent MPG average right?
I put in premium 93 grade gas, What else could i check?
If i accelerate really hard i can see the gas needle animating.. What the hell is the deal?
Old Jul 16, 2008 | 01:59 PM
Richyroogy's Avatar
NBP 6MT
Either your gas needle is acting up or you have a fuel leak. Take it to the dealer.
Old Jul 16, 2008 | 02:00 PM
ChrisQ1980's Avatar
hates the winter
Sounds like something is seriously wrong. Take it to the dealer ASAP. Do you smell fuel? Mabye you have a leak.
Old Jul 16, 2008 | 02:04 PM
LuvMyTSX's Avatar
WTF. No, that is not normal.
Old Jul 16, 2008 | 02:29 PM
MMsTSX's Avatar
JDM Addict
I get about 27mpg city driving.
I get up to 40mpg highway driving.
you have a serious problem.
Old Jul 16, 2008 | 02:38 PM
JTso's Avatar
There seems to be a problem with your car, but it's not a common problem. How old is the car and how many miles?
Old Jul 16, 2008 | 02:52 PM
LukeaTron's Avatar
Your car has to be running like garbage too. There's no way you can dump that much fuel through an engine this small and have it run right... hell, I'm surprised it can even run at all. I have to suspect a fuel leak as well.
Old Jul 16, 2008 | 02:59 PM
intensity2x's Avatar
Have you calculated your MPG or are you going by the MID? If its showing you 7MPG but you calculate a normal MPG number then maybe the sensors that compute MPG are bad. If you run the numbers yourself and come up with 7MPG you have a serious problem.
Old Jul 16, 2008 | 03:00 PM
TS_eXpeed's Avatar
Problems galore.
I got over 40mpg on a highway trip I just took. lol
Old Jul 16, 2008 | 04:58 PM
hunterk1's Avatar
Poser / Fanboi
The TSX 500-mile club is growing everyday - these are people that can average 31mpg over 500 miles.
Your car has a major problem. Good luck getting it worked out.
Old Jul 16, 2008 | 05:12 PM
aaronng's Avatar
Driver/Detailer
Probably a faulty O2 sensor. Won't throw a code.
Old Jul 16, 2008 | 05:24 PM
hotpinoy69's Avatar
Certified BAMF
wow, i can't imagine 7mpg. that would put you as the first and only member of the 119 mile club!
Old Jul 16, 2008 | 10:17 PM
odannyboi's Avatar
resident asshole
Even Hummers get more than 7mpg... so yea, yer car aint normal.
As an earlier poster said... did you actually calculate 7mpg or is your MID telling you 7mpg?
Old Jul 17, 2008 | 02:21 AM
FoBuLouS's Avatar
I called paypal dammit!!
you have lamborghini engine in your tsx??? Oh nvm, lambos get 8mpg.......
Old Jul 17, 2008 | 07:41 AM
LukeaTron's Avatar
I don't think the O2 sensor could be throwing the ECU that far off without the ECU noticing that the sensor is bad and throwing a code. The gas has to be going somewhere other than in the engine because the engine would be drowning trying to run that rich.
Old Jul 17, 2008 | 09:10 AM
CSpaR's Avatar
Some of you get 40mpg??? I get on average 24-26mpg. My air filter and oil are changed regularly. Tire pressure is good and checked. I am a bit of a lead foot, but I dont recall ever getting more than 26 mpg on a good day. Anything else I can check?
Old Jul 17, 2008 | 10:02 AM
LukeaTron's Avatar
You'll only get that kind of mileage with 100% miles. It's actually not hard to do either. Just use steady acceleration and keep the speed below 70 mph. My best is 37.5 or so.
Old Jul 17, 2008 | 01:40 PM
jlukja's Avatar
Does the MID display instantaneous mileage? Maybe you're looking at instantaneous MPG while at WOT?
Old Jul 17, 2008 | 01:57 PM
SERVICEADVISOR's Avatar
Acura Owner Advocate
what ever you don't do not tell the dealer you messed with the ecu/pcm if you are trying to get it covered under warranty.
Old Jul 17, 2008 | 02:43 PM
bradykp's Avatar
Still Lovin my 06
highway? you can easily get 30+mpg by just driving with cruise control around 65/70mpg. 40 is achievable, but you have to drive with the "hypermiling" mindset almost....not fully, but mostly.
Old Jul 17, 2008 | 11:09 PM
odannyboi's Avatar
resident asshole
wrong... i got almost 39 with a little stop and go. Didn't draft, and just kept a steady pace.
The thing is, some of you guys probably like to floor it once an a while... watch the MPG drop while you are doing it.
With conservative (but no hypermiling) driving (i do 60% highway, 40% city), you could easily get 30mpg. Use shell v-power, too.
Old Jul 21, 2008 | 06:46 PM
The Dark Knight's Avatar
what does WOT mean?
Old Jul 21, 2008 | 06:50 PM
PACman's Avatar
Originally Posted by The Dark Knight
what does WOT mean?
Wide Open Throttle.
Old Jul 21, 2008 | 08:06 PM
aaronng's Avatar
Driver/Detailer
It has happened on this forum more than once where someone gets very poor fuel economy and it turns out that it was the O2 sensor eventhough it was not throwing a code.
Even with a heavy foot, he should be getting at least 10mpg.
Old Jul 21, 2008 | 10:18 PM
SoCaliTrojan's Avatar
Let me help you!
I used to be the worst case scenario, and even I got 14 mpg.
Old Jul 22, 2008 | 12:09 AM
aaronng's Avatar
Driver/Detailer
When I was on the race track doing WOT and keeping the revs between 5000 and 7000rpm, I still got 7.8 mpg. LOL
Old Jul 22, 2008 | 03:08 PM
Originally Posted by PACman
Wide Open Throttle.
Thanks!
Old Jul 22, 2008 | 07:00 PM
visuelz's Avatar
East Coast Crew
I'd hate to drive behind you on entrance ramps.
Old Jul 22, 2008 | 10:08 PM
nbtx's Avatar
still plays with cars
Since Mr "czr" has dropped a BS bomb on us with no feedback, I say let this thread die an honorable death. No TSX in the world can run crappy enough to get 7 mpg unless he forgets to shut it down each night.
Old Jul 23, 2008 | 10:28 AM
cls1000's Avatar
i'm finally getting over 20 now, but i have to keep the rpm's under 2k for a full tank to do it. i can just squeak out 300 miles. i think i hit 302 once. blah.
Old Jul 23, 2008 | 11:05 AM
LukeaTron's Avatar
What's your driving mix like? I get about the same results when I'm doing lots of short trips or driving in the city where I spend half my time sitting stopped at traffic lights waiting for no body (grrr). I can easily get over 500 miles out of a tank with pure highway miles though so I don't think anything is wrong.
Old Jul 31, 2008 | 02:21 PM
davidspalding's Avatar
Make a hole, coming thru!
Looking at czr's other posts, I'm not sure s/he's a troll, but I'm ... unimpressed with this thread's validity. ? I think you'd have to drive in D3 100% of the time to get 7 MPG.[1] I'm calling .
[1] I've done this. Driving on a campus and a dark crowded parking garage, I'll start off in D3, then when I hit the main road, wonder why my engine's revving so much. D'oh ... shift in to D, dummy.
Old Jan 2, 2013 | 04:50 PM
user 43567859860's Avatar
i'd say 95% of my travels are in city and less than two miles at a time.. i currently average about 15 mpg with just over 4,900 on the ODO... whenever i hit the highway for a decent trip it jumps to about 25...
Old Jan 3, 2013 | 12:35 PM
TexasHonda's Avatar
I just returned Sunday from a trip across SE states. I averaged about 37 mpg on last tank from S Miss. to Houston (very flat road). Peak mileage was over 39 mpg. I was driving about 70 mph for most part, but some slower due to traffic and reduced speed limit.
I would have the fuel system carefully checked for leaks.
good luck
Old Jan 8, 2013 | 06:40 PM
jonathaned3's Avatar
3rd Gear
good luck
37 MPG hand calculated, or as calculated by the on dash MID display?
Auto or manual?
I've had my 06 TSX for 2 years now. very well maintained, very nice and stock when I bought it.
I do 90% highway mileage, usually at 60mph.
I never stomp it, I never drive crazy, and the absolute BEST I could ever get on a tank was 29 mpg hand calculated. MID display was in the 32mpg range.
My average over 40k miles while stock in this car (again, 90% highway. I'm in TX too. Very flat roads for the most part) is 27mpg. After lowering, its still gettong exactly the same.
I tried all sorts of different driving techniques and no matter what, it would average 26-27 mpg on the tank. all hand calculated, of course. No CEL, no engine problems, proper tire air pressure, regular maintenance, no issues etc.
this is very frustrating to me. Mixed tanks i could see 26-27 average as reasonable. I have 15+ years of experience with Hondas, and over 3+ years of owning a 93 civic coupe my AVERAGE mpg was 45+. So I know how to drive economically.
I see regular reports of auto tsx's averaging 30+. And I know most people drive like idiots. of course I don't know if this is hand calculated or MID, but most people are saying hand calculated.
It seems like I'm splitting hairs to most people, but I figured I could average 30+ in this car with no problems whatsoever considering I do all highway and I know how to drive economically. btw, I've tried entire tanks of 60mph. 70mph. 80mph trying to find the "sweet spot" but NO MATTER WHAT, at the end of the tank it comes out at 27mpg. No matter what! It's annoying! Quite frankly it pisses me off.
Old Jan 8, 2013 | 06:43 PM
3rd Gear
Can't find an "edit" button but my car is auto btw. Finding a manual used tsx was like finding a needle in a haystack when I was looking.
Old Jan 9, 2013 | 12:45 PM
TexasHonda's Avatar
good luck
This is an Auto trans and mpg's were taken from the on-dash average. No way to get maximum average value except w/ the built in totalizer. I have not checked the built-in system carefully for accuracy, but it is reasonably close based on gallons purchased. My wife mostly drives this car on short trips and in-town average is below 25 mpg.
I had a leak (injector-rail oring) on 94 Accord injector that was difficult to see and was detected by smell/feel. I had worked on the engine and removed the fuel rail, so I was suspicious when I smelled gas strongly.
regards
Old Jan 9, 2013 | 01:26 PM
Braz60's Avatar
Regarding MPG I was thinking of upgrading to a K & N air filter has anyone did this and seen MPG improvement?
IBankMouse
Jun 13, 2020 12:53 PM
johnalfa
Nov 5, 2015 06:44 PM
hrothgar02
Nov 2, 2015 01:29 PM
kev87a
Oct 18, 2015 02:03 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
