Leakage Stain on Bolt
I removed the plastic Manifold Cover,
and noticed leakage stain on the corner bolt of the Cylinder Head Cover,
see pic, red circle :
This is not good right ? is it some washer or gasket gone bad ?
Also, it is quite dirty (like soot) at the bottom of the Cylinder Head Cover - does this indicate a problem ?
thanks
thanks
Originally Posted by huckleberry
thanks is it motor oil ? does the oil reach that high up ?
I'd first make sure the V/C hold-down nuts are tight. Has it been apart before that you know? Easy to replace if the seal is in fact the problem.
neuronbob
23
Jul 16, 2019 10:48 AM
