Leakage Stain on Bolt
Old Jan 19, 2006 | 12:05 AM
fuckleberry's Avatar
Question Leakage Stain on Bolt
I removed the plastic Manifold Cover,
and noticed leakage stain on the corner bolt of the Cylinder Head Cover,
see pic, red circle :
This is not good right ? is it some washer or gasket gone bad ?
Also, it is quite dirty (like soot) at the bottom of the Cylinder Head Cover - does this indicate a problem ?
thanks
Old Jan 19, 2006 | 12:14 AM
JTso's Avatar
It's an easy fix. You need to replace the washer seals - 6 total, or you can just replace the problem one first. Item #16 in the pic below.
Old Jan 19, 2006 | 12:15 AM
HoRRo's Avatar
iVTEC no koe
Something like that would be covered under warranty, right ?
Old Jan 19, 2006 | 12:17 AM
JTso's Avatar
Hmm... probably. It's only a few bucks.
Old Jan 19, 2006 | 12:25 AM
thanks is it motor oil ? does the oil reach that high up ?
Old Jan 19, 2006 | 12:51 AM
CCColtsicehockey's Avatar
I am not an engine expert so some can correct me if I am wrong but when the engine is running yes oil reaches that high.
Old Jan 19, 2006 | 12:52 AM
poltergeist's Avatar
Yes....Yes.....
I'd first make sure the V/C hold-down nuts are tight. Has it been apart before that you know? Easy to replace if the seal is in fact the problem.
Old Jan 19, 2006 | 05:19 AM
moda_way's Avatar
yeah, all the "soot" is nothing more than oil that leaked out of that one seal, collected dirt, and now looks gross. I would do it under warranty just so they have a record of it.
tsx_boy
Dec 13, 2019 08:33 PM
neuronbob
23
Jul 16, 2019 10:48 AM
Charles Bennett
Jan 28, 2018 08:53 PM
kev87a
Oct 18, 2015 02:03 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
