Keep Blowing Fuse
Old Sep 24, 2005 | 08:58 PM
danotto's Avatar
Keep Blowing Fuse
Every time I try to recharge my phone I blow the fuse that runs the power sockets. I have tried different chargers/phones and it blows every time. Is this something that I should address to the dealership? BTW, it is fuse #9 in the fuse box by the clutch pedal.
Old Sep 24, 2005 | 09:04 PM
Tsx536's Avatar
Rep'n Taxbrain.com
What amp fuse have you been replacing it with?
Are you replacing it with a fuse with the exact same amps everytime?
Can you plug other DC devices in without the fuse blowing?
Have you been able to use the charger in other cars without any problems?
Old Sep 24, 2005 | 09:34 PM
kurt_bradley's Avatar
Make sure there is no foreign object (ie: coin, staple, small metal anything) stuck in the actual plug jack. The #1 killer of fuses on a repeat basis is usually a foreign object. If you're cool there, just make sure you're using the right amp fuse and also make sure your phone charger isn't a complete POS.
Old Sep 24, 2005 | 11:06 PM
danotto's Avatar
I am using the correct blue 15 amp fuse. I will check for fod in the sockets.
Old Sep 24, 2005 | 11:26 PM
danotto's Avatar
Thanks a ton Kurt! There was a piece of my old cell charger still in there. Works fine now.
Old Sep 25, 2005 | 02:44 AM
I had a hunch. Good to hear you're good to go again.
Acura604
20
Aug 5, 2017 12:55 AM
hashbrown
Sep 29, 2015 12:13 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
ripit
Sep 26, 2015 06:19 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
