comptech sway fitment issue
Old Jul 14, 2005 | 03:22 PM
euroStyle's Avatar
i too was experiencing some thumping after the sway install, its been about 2 weeks since install.
so i loosened the end links and unbolted the braces.
then i retightened the end links. and tried to align the bar, but it seems like the bar is either bent alittle or one side( the right/passenger side) is lower where the braces are.
the left side will make contact to the car but the right side wont. there is about a few centimeters gap. but retightened everything.
i tried everything from reunbolting everything and try aligning it right, but still wont fit perfectly.
and the ground surface is pretty even.
Old Jul 14, 2005 | 03:30 PM
ComptechTSX's Avatar
so i take it the thumping noise has continued for u?
Old Jul 14, 2005 | 03:32 PM
euroStyle's Avatar
no, its my first time happening.
after i retightened everything, havent taken for a drive yet.
Old Jul 14, 2005 | 04:52 PM
joerockt's Avatar
Just dial 1911
Hmmm, hope you dont have it upside down. I think its physically impossible, according to my thread, but take a look:
Click
Old Jul 14, 2005 | 05:07 PM
euroStyle's Avatar
Click
yeah, ive read that post awhile ago. and i dont think it has to do with anything being upside down.
Old Jul 14, 2005 | 05:10 PM
iTimmy's Avatar
dɐɹɔ ǝɥʇ ʇɐɥʍ
I think that could be your problem, you have to jack the car up by the body to get the sway bar aligned properly. Its too tight if you don't, I had my car on a drive on type lift and could not get the comptech bar to fit until I jacked up the body, at which point it was a piece of cake.
No the bar will not fit upside down, it would put the sway bar end links pointing up and in instead of down- and they won't bend that far in those directions.
Old Jul 14, 2005 | 05:39 PM
JTso's Avatar
When you are jacking up the car, make sure both wheels are off the ground. Otherwise, the bar will not line up correctly.
Old Jul 15, 2005 | 02:58 AM
euroStyle's Avatar
hmmm,
i thought i was suppose to keep it on the ground for a better fitment. ok, i'll try that. thanks
Old Jul 15, 2005 | 03:01 AM
BlackAc036's Avatar
I had a thumping issue too... It was with the greddy EVO2 hitting the swaybar. I used lower hangers for the exhaust and haven't had any problems since. Is your exhaust stock?
Old Jul 15, 2005 | 03:58 AM
euroStyle's Avatar
yep, stock.
Old Jul 15, 2005 | 12:34 PM
Arcticcl9's Avatar
Can't wait to drive
Make sure the bar is centered. Another thing is, when your car turns, the bar actually slides a bit left and right relative to the brackets and bushings, so do not overtighten it (16ft/lb or 22Nm is the recommended torque) to allow for a little movement. End links is 28lb/ft (38Nm) since there is movement there also.
I have the comptech sway bar, and I don't have any of the "clunking" issue. The only difference I have is changing out the rubber bushings with poly bushings.
Old Jul 15, 2005 | 01:53 PM
TSXDude's Avatar
Noobie 6MT driver
One question: How do you tighten the endlink nut?? There is no way you could fit the 5mm hex key and put a torque wrench over it.
Old Jul 15, 2005 | 01:57 PM
Arcticcl9's Avatar
Can't wait to drive
Just torque the nut without worrying about the hex. I did it that way and it was fine. Since it rusts a bit, the removal was what needed the hex.
Old Jul 15, 2005 | 02:06 PM
TSXDude's Avatar
Noobie 6MT driver
Gotcha!! Thanks
Old Jul 15, 2005 | 02:09 PM
joerockt's Avatar
Just dial 1911
Where did you find the poly bushings? I want to replace the rubber ones...
Old Jul 15, 2005 | 04:48 PM
JTso's Avatar
I got mine from here. The bushings come with silicone grease.
Old Jul 15, 2005 | 04:51 PM
euroStyle's Avatar
whats the difference from the poly bushing and the one comptech ships with?
Old Jul 15, 2005 | 06:36 PM
curls's Avatar
Someone stole "My Garage"
I assume it's # 95158 from this page? http://www.energysuspensionparts.com...20Bushings.asp
22mm....
Noticeable difference, or is the swaybar itself w/ stock bushings really enough on its own?
Old Jul 16, 2005 | 11:20 AM
joerockt's Avatar
Just dial 1911
The CT's are rubber.
Old Jul 16, 2005 | 11:22 AM
joerockt's Avatar
Just dial 1911
Cool, thanks! That link is the exact bushings I need correct?
Old Jul 17, 2005 | 02:54 AM
euroStyle's Avatar
yes, what are the advantages of having poly over rubber?
Old Jul 17, 2005 | 10:46 AM
JTso's Avatar
I think "some" came with rubber and the newer ones "might" come with poly bushings. My Comptech black bushings are poly, whereas another local member's are rubber. It's very obvious if you squeeze them. I have a new set of poly bushings side by side with the Comptech's, and the materials are the same. Which means, you will need to lube those bushings if they are poly.
Old Aug 31, 2005 | 10:59 AM
minkl81's Avatar
ahh... mine just started to clunk over the bumps too.
got mine installed at tire shop where car was fully lifted to install the sway bar.
they do suspension works too and just checked underneath and they
greased the bushings for me.
guess i'll go back and retorque it.
brackets and bushings: 16ft/lb
end links: 28ft/lb
right??
Old Aug 31, 2005 | 02:44 PM
joerockt's Avatar
Just dial 1911
end links: 28ft/lb
right??
Yea, I'm having the same issue, though not as bad as before. I suspect its the bracket bolts again. Im going to use Loctite this time...
Edit: Damn, there's a wide selection of Loctite threadlockers out there. Anyone have a suggestion on what to use?
Old Sep 1, 2005 | 06:36 PM
minkl81's Avatar
retorqued everything and still clunks... comptech sway bar design must be a defect from a scratch.
Old Sep 21, 2005 | 03:26 PM
MTLer's Avatar
The clunking bug has hit me too, Atleast i think it's the sway bar. I have had the bar installed for about 3 weeks or so and just today i hear this clunking sound. I thought it was the old sway bar i had left in the trunk.. i don't belive it is it, the clunk only seems to appear when i hit a bump or when i make a right jerk not left..
Is this the same issue? Is it even my RSB?
So i should retighten it?
Old Sep 22, 2005 | 11:16 AM
minkl81's Avatar
Yea.. any solutions to resolve this clunking problem with comptech rsb??
Clunking is very annoying..
Old Sep 23, 2005 | 01:47 AM
euroStyle's Avatar
The other day, LA was hit with a "weird" weather and started raining. anyways, the clunking came back. and it was really bad, sounded like everything was loose. so i went under the car, in the rain getting wet, and tried tightening everything, but they were tight as ever. nothing loose. and soon as everything got warm and dry again, it went away.
any of you guys think there is some relation?
Old Sep 23, 2005 | 08:04 AM
GIBSON6594's Avatar
My Garage
is your car lowered? do you have an aftermarket exhaust?
Old Sep 23, 2005 | 08:46 AM
MTLer's Avatar
My car is bone stock with the exception of the Comptech RSB. I am going to tighten it this weekend. Does this cause any harm at all? Or is it just a noise problem? Is it bad for me to drive while it is doing this?
Old Sep 25, 2005 | 01:39 AM
minkl81's Avatar
It's all stock.
Old Sep 25, 2005 | 01:42 AM
minkl81's Avatar
Yea.. During warm or hot weather, less clunking is present. I parked my car outside last night and during the morning drive more clunking was noticed.
Old Sep 26, 2005 | 02:46 PM
MTLer's Avatar
Ok so over the weekend i decided to jack my car and tighten the Endlinks on the RSB and see what happens. No noise! atleast for the time being. I will see if it returns in a couple weeks time.
I suggest you try tightening your endlinks, mines were not that loose maybe like a quarter turn? but it seems to make the difference.
lidobitesize
18
Oct 22, 2016 10:21 PM
k6biv
Sep 22, 2015 02:06 PM
MonkeyTrucker
Sep 21, 2015 06:15 PM
Sep 21, 2015 08:44 AM
k6biv
Sep 10, 2015 06:37 PM
