H1 High Beams Installation
Hey Azine, just needed some input on how to replace my H1 High Beam bulbs.
I've searched and found one similar thread called "High Beam Installation" but no one commented on it. Hopefully by now someone's done it before.
I know minkl's replaced his with Nokya H1 Hyper Yellow, which is the same that I just bought and received. Just need some pointers. Thanks guys.
iVTEC no koe
I believe the Owner's handbook/manual that comes with the car has instructions. Fairly easy replacement process. IIRC, you just move that locking wire mechanism and take out the bulb.
Any specific way of removing it? Ive been tuggin at the bulb for the past 10 minutes, and no luck on either side. I removed the wire that's attached to the bulb, which exposes the two metal prongs.
Originally Posted by TodaSi
I have yet to change any of my bulbs, but don't you unplug them then slightly twist them and then remove? Try that
There's no way you can turn and pull, that's for the fog light installation and removal. The small slit for the bulb to go in is shaped like the bulb, so there is no turning. I've been pulling and pulling for an hour, and still no good. I'll just wait till later and when we have a install meet soon enough, I'll take my front end apart and just do some stuff.
OK, its super easy man, don't over think it.
1. Unplug the wires to the bulb. Its a rather sizeable harness.
2. Move the metal clip that holds the bulb in place.
3. Pull straight back out. DO NOT rotate it, just straight in and out.
Re-install in reverse order. Do it in daylight or with a friend and a flashlight and it shouldn't be any problem to see it.
Originally Posted by EuRTSX
I'm a bit confused on number two. What do you mean move?
Not to waste any of your times, Minkl's picture from his thread a bit back is probably a better representation of the H1 Nokya Hyper Yellows.
And plus, I do not have the foglight rewire, and he does.
Here you go, this is Minkl's car with Nokya H11 and H1 bulbs.
It's a bit nippy out, and its 12:34am, and I have work tomorrow at 7 which means I really should be sleeping, yet I'm not because I'm retarded. Will do tomorrow after work.
Take ur time as u dun want it springing out and getting lost somewhere...
Originally Posted by CooLeh
The metal clip can be a b@stard...not too bad unhooking it but sometimes damn hard to get it back on...
Yeah, I'm reconsidering doing this until maybe a bit warmer out or when I have help from more experienced friends around the area, *cough* Mike, Kevin or Dillan *cough*
I'm gonna give it one more try after I get off from work.
Drives With Hands
Has anybody reported what it is like to drive with yellow high beams? It seems to me like it would be inferior to white light for activating the fluorescent or retro-reflective paint in road markings and such, so you would lose contrast and as a result, visibility. Yellow fog lights are beneficial for more obvious reasons like glare reduction, but I'm curious if anybody who has done this reports increased or diminished visibility during night driving.
Honestly, I rarely use my highbeams, they're pretty much going on for aesthetics purposes only.
iVTEC no koe
Eur I don't mind doing it / showing you next time we meet up. Speaking of which, we should do something in the area soon. (lets take that to a new thread soon...)
Yeah, I had like 5 minutes after I got off of work today to try and tuggin' on the highbeams again right in my work parking lot, and no good.
I say we have a meet in like two weeks? Can't wait~ New thread, go ahead and make one Mike
Mike, I made a thread for MD/VA/DC Install meet in TSX Discussion.
https://acurazine.com/forums/showthr...192#post645192
Originally Posted by minkl81
still didn't find the clip? no need to tug anything. try pushing in either center left or right edge of the hole and feel if something pushes in.
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
