H1 High Beams Installation
Old 12-02-2006, 10:13 AM
EuRTSX's Avatar
Hey Azine, just needed some input on how to replace my H1 High Beam bulbs.
I've searched and found one similar thread called "High Beam Installation" but no one commented on it. Hopefully by now someone's done it before.
I know minkl's replaced his with Nokya H1 Hyper Yellow, which is the same that I just bought and received. Just need some pointers. Thanks guys.
Old 12-02-2006, 10:36 AM
New to Modding Cars
KapVu's Avatar
so you high beams are yellow bulbs or am I wrong?
Old 12-02-2006, 10:49 AM
EuRTSX's Avatar
Yes they are.
Old 12-02-2006, 10:57 AM
iVTEC no koe
HoRRo's Avatar
I believe the Owner's handbook/manual that comes with the car has instructions. Fairly easy replacement process. IIRC, you just move that locking wire mechanism and take out the bulb.
Old 12-02-2006, 11:32 AM
EuRTSX's Avatar
I'll look into that. Thanks for the info
Old 12-02-2006, 11:47 AM
Is waiting in
rex.'s Avatar
yes it's that simple.. and great to be out of lockup!
Old 12-02-2006, 12:06 PM
EuRTSX's Avatar
Any specific way of removing it? Ive been tuggin at the bulb for the past 10 minutes, and no luck on either side. I removed the wire that's attached to the bulb, which exposes the two metal prongs.
Old 12-02-2006, 12:28 PM
TodaSi's Avatar
I have yet to change any of my bulbs, but don't you unplug them then slightly twist them and then remove? Try that
Old 12-02-2006, 12:33 PM
EuRTSX's Avatar
I'll try that, even though that was the procedure for the H11 Fog Bulbs.
Old 12-02-2006, 01:04 PM
EuRTSX's Avatar
There's no way you can turn and pull, that's for the fog light installation and removal. The small slit for the bulb to go in is shaped like the bulb, so there is no turning. I've been pulling and pulling for an hour, and still no good. I'll just wait till later and when we have a install meet soon enough, I'll take my front end apart and just do some stuff.
Old 12-02-2006, 01:23 PM
New to Modding Cars
KapVu's Avatar
post some pics when you're done installing
Old 12-02-2006, 03:52 PM
Midwest TSXer
KingTSX's Avatar
Hasn't anyone done this that could offer some pics or help to get these High beams installed??
I would offer you some advice, but mine are still sitting in the packages until this 18degree temp changes to something warmer than 32 degrees outside...
Old 12-02-2006, 03:55 PM
Reach's Avatar
OK, its super easy man, don't over think it.
1. Unplug the wires to the bulb. Its a rather sizeable harness.
2. Move the metal clip that holds the bulb in place.
3. Pull straight back out. DO NOT rotate it, just straight in and out.
Re-install in reverse order. Do it in daylight or with a friend and a flashlight and it shouldn't be any problem to see it.
Old 12-02-2006, 04:16 PM
Midwest TSXer
KingTSX's Avatar
Now that's what I'm talking about
Old 12-02-2006, 04:22 PM
EuRTSX's Avatar
I'm a bit confused on number two. What do you mean move?
Old 12-02-2006, 06:38 PM
minkl81's Avatar
I believe you have to push in the metal bracket upward motion to clip off the bulb. Its very easy to do. If you look into it you'll see some kind of wire metal bracket holding the bulb in place. Just push that in slightly and it will flip out.
Old 12-02-2006, 06:48 PM
EuRTSX's Avatar
Thanks minkl81, I'll give that a try after I'm out of work.
Old 12-02-2006, 07:04 PM
6MT G37
Ruserious's Avatar
yea post some pics when ur done.
Old 12-02-2006, 07:24 PM
EuRTSX's Avatar
Not to waste any of your times, Minkl's picture from his thread a bit back is probably a better representation of the H1 Nokya Hyper Yellows.
And plus, I do not have the foglight rewire, and he does.
Here you go, this is Minkl's car with Nokya H11 and H1 bulbs.
Old 12-02-2006, 11:23 PM
Reach's Avatar
but did you get yours done??
Old 12-02-2006, 11:34 PM
EuRTSX's Avatar
It's a bit nippy out, and its 12:34am, and I have work tomorrow at 7 which means I really should be sleeping, yet I'm not because I'm retarded. Will do tomorrow after work.
Old 12-03-2006, 08:24 AM
CooLeh's Avatar
The metal clip can be a b@stard...not too bad unhooking it but sometimes damn hard to get it back on...
Take ur time as u dun want it springing out and getting lost somewhere...
Old 12-03-2006, 08:34 AM
EuRTSX's Avatar
Yeah, I'm reconsidering doing this until maybe a bit warmer out or when I have help from more experienced friends around the area, *cough* Mike, Kevin or Dillan *cough*
I'm gonna give it one more try after I get off from work.
Old 12-03-2006, 10:03 AM
Drives With Hands
rmpage's Avatar
Has anybody reported what it is like to drive with yellow high beams? It seems to me like it would be inferior to white light for activating the fluorescent or retro-reflective paint in road markings and such, so you would lose contrast and as a result, visibility. Yellow fog lights are beneficial for more obvious reasons like glare reduction, but I'm curious if anybody who has done this reports increased or diminished visibility during night driving.
Old 12-03-2006, 10:10 AM
EuRTSX's Avatar
Honestly, I rarely use my highbeams, they're pretty much going on for aesthetics purposes only.
Old 12-03-2006, 04:19 PM
STi'd
gavinn58's Avatar
Yep, I did mine just for aesthetics. If anyone's interested, I can take a pic later being that it's about 78 degrees right now with nights in the mid 60's!
Old 12-03-2006, 05:09 PM
iVTEC no koe
HoRRo's Avatar
I like the yellow better, it still activates fluorescent signs/markers fine. Might just come down to personal preference.
Old 12-03-2006, 08:08 PM
Reach's Avatar
Eur I don't mind doing it / showing you next time we meet up. Speaking of which, we should do something in the area soon. (lets take that to a new thread soon...)
Old 12-03-2006, 08:52 PM
EuRTSX's Avatar
Yeah, I had like 5 minutes after I got off of work today to try and tuggin' on the highbeams again right in my work parking lot, and no good.
I say we have a meet in like two weeks? Can't wait~ New thread, go ahead and make one Mike
Old 12-03-2006, 09:16 PM
EuRTSX's Avatar
Mike, I made a thread for MD/VA/DC Install meet in TSX Discussion.
https://acurazine.com/forums/showthr...192#post645192
Old 12-04-2006, 07:23 PM
minkl81's Avatar
still didn't find the clip? no need to tug anything. try pushing in either center left or right edge of the hole and feel if something pushes in.
Old 12-04-2006, 08:18 PM
EuRTSX's Avatar
Alright I'll give that a try tomorrow. If I still can't do it. I'll post pictures of what I'm doing.
02-25-2020 09:57 AM
Powder Monkey
2G CL Problems & Fixes
09-09-2018 12:55 AM
09-14-2015 10:10 AM
theinsvnity
09-10-2015 10:22 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: H1 High Beams Installation
