EDFC install, pics inside.
Old Dec 24, 2004 | 01:14 AM
dzuy's Avatar
Troutslap Mod-DUH-rator
a pain in the ass. it took me and friend about 6 hours. the hardest part is running the freakin wires.
i would recommend if you want edfc - then install it before you install the coilovers.
the back was a pain in the ass to get the motor on - b/c you have to screw down a screw thats in the middle of the motor. so if you want to install after you already have the coilovers on - makes sure you have a low profile right angle flathead screwdriver.
you have to remove a ton of panels. omg. i didn't want to take pics - my car looked like a nightmare - plus we were trying to get it done quickly.
i ended up putting it in the large compartment in the center console. i haven't decided if i want to velcro or use a bracket to hold down the edfc. the mat that comes inside the compartment hold the edfc fine tho. until you want to press some buttons - i'll probably install the bracket sometime soon.
running the wires from the firewall is a pain too. my friend did the wiring, poor guy haha. it's a hell of alot eaiser to go through the passenger side.
i messed something up during install tho - in the larger compartment - there was some kind of plastic that felt like it could be twisted or pryed off. i ended up prying it off - too bad it was a lens for the green light inside the compartment. oh well. it worked out - b/c i didnt have to drill any holes to run the wires - we just ran it through the opening left by the lamp haha.
if anyone needs the color codes for the wires that you need to splice into, let me know. you'll need constant power, parking light wire and accessory power.
another moment - make sure you run the wire UNDER the seatbelt in the rear. haha. oops.
my setup is super clean. the instructions are easy. basically - remove some hardware from the existing strut. replace it w/ some new hardware - dont turn the strut upside down or something wil fall out?!!?
then install the motor. wire it up.
bam! then you'll see this!!!!
a finished product inside the compartment:
Old Dec 24, 2004 | 01:24 AM
stuckthrotle's Avatar
Old Dec 24, 2004 | 01:36 AM
Wolfpack_TSX_22's Avatar
Man Dzuy, you've been putting some serious time into your car. Looks awesome
Old Dec 24, 2004 | 03:04 AM
Andynolife's Avatar
that's so cool ~
Old Dec 24, 2004 | 07:54 AM
tsxondubs's Avatar
kenstyle on 20's
damn some one is a baller .looks bad ass man , david
Old Dec 24, 2004 | 12:45 PM
acuratsx03's Avatar
Future Seminole
thats really cool... dont mind my n00bness, but whats the do exactly?
Old Dec 24, 2004 | 12:50 PM
Tsx536's Avatar
Rep'n Taxbrain.com
That....sh*t looks clean man!!! Damn....you got a lot of mods..and the big thing is they are all really nice mods!!
All you need now is a "Powered by TroutSlap" sticker...!!
Awesome...dawg..!!
Old Dec 24, 2004 | 01:00 PM
slo007's Avatar
Master in Science
Ummm, what is it?
slo007's Avatar
Master in Science
Seriously, all I see is a little panel with some numbers on it. What are they talking about?
Old Dec 24, 2004 | 01:02 PM
RMATIC09's Avatar
Awesome
RMATIC09's Avatar
can change the ride height with a push of a button.
Old Dec 24, 2004 | 02:04 PM
slo007's Avatar
Master in Science
<drooling> I like that! How much?
Old Dec 24, 2004 | 02:27 PM
cmf's Avatar
cmf
ATCer
Doesn't change ride height, it changes damping of the suspension.
Old Dec 24, 2004 | 03:12 PM
JeffTSX's Avatar
Subie Tech
Wow..not bad
Old Dec 24, 2004 | 04:42 PM
acuratsx03's Avatar
Future Seminole
wow, thats really cool. nice mod dzuy
Old Dec 24, 2004 | 04:45 PM
thenation's Avatar
kool
Old Dec 24, 2004 | 05:03 PM
Triz08's Avatar
i dont know if i missed something but what shocks are you riding on?
Old Dec 24, 2004 | 05:14 PM
slo007's Avatar
Master in Science
Meaning what? Change in comfort? Sport (stiff) vs. luxury (wobble)?
Old Dec 25, 2004 | 12:45 AM
cmf's Avatar
cmf
ATCer
Basically, yes. Change in comfort of ride.
Old Dec 25, 2004 | 12:46 AM
cmf's Avatar
cmf
ATCer
They're coilovers made by TEIN, so it would all be TEIN. Shocks, springs = TEIN.
Old Dec 25, 2004 | 09:08 PM
kangjin's Avatar
yup.
If you take out the red velvet not an ashtray and cut away some of the plastic the control unit fits perfectly in that space.
Old Jan 5, 2005 | 10:07 AM
dzuy's Avatar
thanks kangjin.
i didn't want mine there tho...
plus i didn't want any wires showing.
dzuy's Avatar
tein flex coilovers.
Old Jan 5, 2005 | 12:40 PM
jmathew34's Avatar
good job dzuy
Old Jan 5, 2005 | 07:31 PM
EURORTSX's Avatar
great job dzuy! looks so tight...
Old Jan 5, 2005 | 07:42 PM
kangjin's Avatar
yup.
haha, that ugly purple wire was my temporary rca for the aux in before i installed it in the center console.
no problem though, just wanted to offer an alternate location.
Old Jan 5, 2005 | 11:17 PM
dzuy's Avatar
Originally Posted by jmathew34
good job dzuy
thanks guys!
Old Jan 6, 2005 | 01:04 AM
EURORTSX's Avatar
Sup dzuy, im a noob to this EDFC and suspension stuff...but in terms of getting an EDFC, did u change your entire suspension like coilovers, shocks, springs? What would you need to get the EDFC to work efficiently?
Old Jan 6, 2005 | 07:24 AM
dzuy's Avatar
yes you have to change your whole suspension. more specifically - you have to replace your factory strut (spring + shock) assembly with a complete coilover assembly (spring + shock).
many people replace just the springs - but having a lowering spring on a stock shock is ok for short term - but eventually the stock shock will blow and will result in a very bouncy ride.
installing a complete coilover system is also easier than installing aftermarket lowering springs - this is because you can remove the whole strut assembly and install the new coilover system. as opposed to a spring where you have to remove the strut - then compress the stock spring - remove the spring - install new springs - reinstall strut.
also a complete coilover setup, such as tein or buddy club - has shocks that are designed to withstand a lowered ride height.
the coilovers that i have, tein flex - feauture ride height adjustability - as well as rebound/dampening adjustment. what that basically boils down to is you can set how soft/stiff you want your ride to be.
obviously - if you plan to take corners fast (like in a road course), then you will want to adjust the ride to be stiffer. for everyday driving - you don't want the ride to be too harsh so a softer setting would be appropiate.
this can be done by turning a knob on the top of the tein coilovers.
the edfc - electronic dampening force controller - does this for you. you have to install some motors on top of the knob of the coilover - then you can control how soft or stiff you want your ride to be inside your car.
there are three memory settings - so you can preset three different combinations of dampening.
Old Apr 16, 2005 | 09:34 PM
accsuperstar's Avatar
finally put on my EDFC. man this thing is cool. It even makes noises
Old Apr 16, 2005 | 09:43 PM
05_TSX_GP's Avatar
Top notch 6MT
Wow... dzuy, you got serious mods on your ride!!! I wasn't aware of this one as I joined just 2 months ago and now this thread from Dec '04 is revived so I just found out
05_TSX_GP ----> :troutslap
So I guess you use the stiffest damping setting for drag runs?
Old Apr 16, 2005 | 10:12 PM
kurt_bradley's Avatar
Makes noises? Does hitting the switches on the EDFC sound like one of these...?
I've got to go for a spin in this thing.
Old Apr 17, 2005 | 01:05 AM
dzuy's Avatar
it's funny b/c everyone told me to keep the front full soft and the rear full stiff.
but my best runs have been with the car full stiff
Old Apr 17, 2005 | 01:24 AM
CCColtsicehockey's Avatar
yeah i love my edfc when you want to have fun with the car and dont care about how bad the ride is push a button for full stiff and then when you want comfort push another button so easy. now i just have to get the proper spring rates since i have the springs for the euror and not the tsx and mine are softer so the ride is never really that stiff. anyone want to trade.
Old Apr 17, 2005 | 01:28 AM
Yeah, sure. The next time you're in my neck of the woods.
skathe
2G TSX Performance Parts & Modifications
23
Apr 10, 2020 06:36 PM
cycdaniel
Dec 17, 2019 10:58 AM
BoricuaTL
Apr 8, 2016 01:08 PM
bailey24
Nov 21, 2015 08:43 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
