Back up camera
JDM Addict
![](http://i133.photobucket.com/albums/q73/mitchmonster/acura/camera.jpg)
I have this one and it works great.
the guys at the Acura dealership say it's far superior to the stock ones
they put in the new TSX and the MDX and whatnot.
just look up the product number and find the best deal out there.
Pioneer ND-BC2
I had mine cut/molded into the license plate:
![](http://i133.photobucket.com/albums/q73/mitchmonster/acura/plate-1.jpg)
but it comes all setup to be used like a normal one would be.
I was afraid of it getting stolen/ripped off, so I made it permanent, lol.
it's adjustable with the bracket that comes with it for mounting.
I bought this one from ebay last year. Very happy with it. It was recommended by other tsx owners too. You can email the seller directly and ask for it.
http://cgi.ebay.com/ebaymotors/ws/eB...1756&viewitem=
Doesn't Rice His Car
1 Post
If you search around, there's also a wiring scheme out there where you can get the camera hooked up for minimal cost (less than $20ish in wires/parts if I remember correctly).
JDM Addict
but it's not supposed to be, it's supposed to be mounted with
it's bracket and be adjustable and all of that.
I just did the custom thing on my own.
hook up is simple, requires very little extra to buy.
it plugs into the back of the navi dvd unit in the trunk.
and the power comes from one of the reverse lights.
there is a DIY I'm sure here and also on tsx club.
I think about $10 or less even! I remember buying extra parts in case I screwed it up, and the extras are like 90 cents each for the housing at mouser.com.
Hey, did you screw your camera into the car or did you use automotive tape to keep it in place? I worry about the camera popping off in carwashes!
2006 ASM tsx
good question jottle.
i actually pulled the trim out from under the trunklid.. hold on one second, let me furnish up some pictures...
actually found the thread. heres a ref: https://acurazine.com/forums/audio-video-electronics-navigation-22/06-back-up-cam-teaser-368797/ and direct copies of the pics of importance to this questions:
![](http://img.photobucket.com/albums/v650/vthree/navi/DSC01089.jpg)
NO that is not the cam, its a frys $20 cam.. i just wanted to test the cable lol. and was being cheap @ the time.
Let me help you!
I wonder if it would be feasible to use the license plate's bolt? Drill a hole through the camera's stand, and put the bolt through the plate, then the stand, then the car? If the bolt is one of those special bolts that you need a tool to un-do (like a special security/hex bolt, or those bolts in public restrooms that tighten but can't be untightened), perhaps the camera can be secured with minimal mods to the car?
I have had this one for a while and it works great. More expensive than others, But I think it is well worth it.
https://acurazine.com/forums/audio-video-electronics-navigation-22/review-sanyo-cca-bc200-backup-cam-396043/
actually found the thread. heres a ref: https://acurazine.com/forums/showthread.php?t=368797 and direct copies of the pics of importance to this questions:
2006 ASM tsx
i actually have a doms unit that i should be using soon.. incase i go through with it i could probally just sell off the harness i bought..
or if you search, you should see the thread to make your own harness =) its only a few bucks i think..
I made my own harness, it was about $2 in parts and that included extras of everything in case i messed one up.
Although I am not putting in a backup camera, I am rigging a DTV converter box up so I can watch TV on the navi screen
JDM Addict
um... nothing really.
you need what is in the pics below to make it happen usually:
![](http://i133.photobucket.com/albums/q73/mitchmonster/acura/camera-1.jpg)
^the camera and what it came with
![](http://i133.photobucket.com/albums/q73/mitchmonster/acura/connecter.jpg)
^the 7 slot little plug that fits into the back of the nav unit
![](http://i133.photobucket.com/albums/q73/mitchmonster/acura/pins.jpg)
^the little pins that go inside the plug that the wires attach to
![](http://i133.photobucket.com/albums/q73/mitchmonster/acura/rcas.jpg)
^extra RCA plugs to extend the wire, plug and play style, you can just solder though...
![](http://i133.photobucket.com/albums/q73/mitchmonster/acura/wireandsolder.jpg)
^and a bit of extra wire and some solder to make it all happen.
getting some heat shrink isn't a bad idea either to seal it all up real nice.
basically you just need to extend a wire and make a little plug for the end of it.
there is a DIY either on this site or on tsx club that shows exactly what to do.
the little plug you make just plugs into the back of the DVD unit in the trunk.
and the power comes from one of the reverse light wires. really, really simple install.
JDM Addict
http://www.tsx club.com/forums/showthread.php?t=17965
^just take out the space between tsx and club.
Audio is easy with the 06+ TSX, just use a cable from the RCA audio outputs of the DTV box to the AUX input under the armrest. I got a silent small 75W power inverter that I plug the box into(which only draws 10W, not much at all)
Too bad the box I have is just a bit too big to fit in the space under the armrest. I'll probably leave it under the passenger seat. As for an antenna, since I live close enough to Philly I just put a 12'' extendable monopole antenna on the back and it works.
Best Buy, walmart, target, etc. Have you not heard the countless commercials on TV about these converter boxes? The Zenith DTT901 is one of the best ones, you'll find if you do a little searching.
Here's my setup.
Camera:
![](http://etailelectronics.com/Merchant2/graphics/00000001/16245.jpg)
My Navi:
![](http://i11.photobucket.com/albums/a183/djmixmac/CIMG0182.jpg)
Installed:
![](http://i11.photobucket.com/albums/a183/djmixmac/CIMG0003-1.jpg)
In Action:
![](https://acurazine.com/forums/members/xenonhid-175721-albums-xenonhid-639-picture-backup-camera-avic-z3-navigation-system-05-tsx-4625.jpg)
![](https://acurazine.com/forums/members/xenonhid-175721-albums-xenonhid-639-picture-backup-camera-pioneer-avic-z3-my-2005-acura-tsx-4624.jpg)
Very Satisfied with the results as it has form and functionality of the OEM back up camera similar to the 07-08 MDX.
Camera:
My Navi:
Installed:
In Action:
Did you use a rubber grommet where the wire goes in to the car? Obviously you drilled a hole in the plastic piece, but I'm curious if people are making it water tight?
dude thats sick i need to get one of these, i think imma search around for one at bestbuys and have them install it for me... i need to get one of these i hit a short pole the other day and it had a mark on my bumper, didnt hit it too hard but i hit it and it left a mark, so imma get me one of these... haha
rockyboy
12-06-2022 02:29 PM
Soul_Deamon
11-13-2018 04:44 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
2015TLX
09-11-2015 02:56 PM
