Two Wire harnesses on the back of HU?
I just put in a new stereo in my TL, when I took out the factor HU it had two plugs. Assuming one was for the 4 speakers and the other for the tweaters. I checked all around and I can't anything for the tweater harness. I was just wondering if anyone was able to find a harness for them or just cut it and wired them into the front speakers? Any input would be great. And maybe it's for something else but then I need to check my connection because my tweaters aren't working.
Received 2,329 Likes
The second harness is actually for the two midrange speakers in the headliner.
Those are mid-range? What size are they? Also, maybe you guys can help me here. Now that I have my new deck in, whenever heavy bass hits my lights fade. Not a whole lot but enough to make it annoying. I'm guessing it's because it's drawing too much power; what is the best way to fix this problem.
Do you have seperate amps hooked up in your system? I know this happened to me in my older car and i had to replace the Alternator, but you could really tell because when i gave it gas, the lights all got brighter. If its just during bass hits and the deck is the only thing that fades, thats normal...but you could always get a Feride Cap if you have an aftermarked amp powering your speakers or a sub or 2. That takes the drain off your system by building up a charge, and then when the bass hits (which draws the most power), the cap actually gives the power that it charged up instead of running totally off the battery/alternator.
Lord Ubber
The mids are a factory size and style. You can't find a match.
They are about 2-2.5 inches.
If you do a tweet you will destroy the sound of a good system.
As 4 the battery. Now that I have a awesome system I do notice the flickering @ strong bass
(when I have my bass level @ 13-15). I'm thinking about a drycell battery.
I normaly have my bass level@ 1-3.
I don't have an amp or a sub as of now. I just have an aftermarket deck wired to my stock speakers. It sounds great but whenever I have it cranked the stereo definitly fades and then depending on the bass hit the dash lights seem to fade. For some reason it seems to fade more when I have the accelerator pushed down; whenever I'm stopped my dash lights are fine. Weird!
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
11-13-2018 04:44 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
Gianni Formica
09-07-2015 08:28 PM
