Air Intake for 3.2
Air Intake for 3.2
I just ordered the weapon R dragon intake system with the ram air box addition that conects to the dragon air intake. Has any one bought either of these and is there a noticable differance
Originally Posted by ljmushock
I just bought the Secret Weapon and Im putting it on on Monday, I'll let ya know how it goes... Question, why did you choose the dragon over secret weapon?
Originally Posted by thA hiPnoTiC
how much was the intake? and please post pics
Originally Posted by mblackmarr
how did it affect the performance of your car.
Originally Posted by =]Shinoshi[=
Does it 'hiss' when you idle? I know my Secret Intake does, and it's quite annoying.
Originally Posted by c29842984
I know on my 2.5 the Secret Weapon made a noticeable difference. When I converted it to a cold air it made it even better.
Whats the difference between the dragon intake and the secret weapon intake? Would it be better to get the Dragon intake with the cold air sheild and the ram air attachment? or just stick with the secret weapon intake?
Im such a n00b
Originally Posted by 982.5TL
How did you convert it to cold air? what does that mean. is it not already a cold air intake? do you have pics?
Im such a n00b
Im such a n00b
WOW!, put my Weapon R on tonight..... Sick.... Absolutely Sick! Install was a bitch because you have to custom mount the bracket. At idle its quiet, between 1500-3000 rpms its a light throaty sound, when flooring it as soon as it hits 4000 rpm and the VIS kicks in....WOW sounds amazing you can really tell the difference that VIS makes when you hear it, the sound almost doubles after 4000 rpm... Ill post pics and try to get a sound clip up!
Im such a n00b
Im such a n00b
What about performance, does it feel like it has more power
Good news for secret weapon
I origanally ordered the dragon intake seystem from weapon-R because you could not get the heat shield that allowed you to connect the ram air intake hose to I was quite pissed off about this so I called Weapon-R and talked directly to one of the engineers that worked on the design of the secret weapon and asked why there is not a heat shield for the secret weapon. He said that it is being developed as we speak and it will be out this fall. But we can still connect the ram air intake hose to the secret weapon intake, and when the heat shiel comes out for the secret there will be a quick connect fitting for it and he said that this direct cold ram air charge system for the secret weapon is going to be like nothing else in the industry. Go to www.weapo-r.com and check it out it is going to be kick ass
hey mblackmarr, i am looking into doing the ram air to my dragon intake. I was wondering if you have any pics of the ram air inlet on the front airdam! this would be a cheap and easy upgrade, but the only thing that i am worried about is the mounting of the inlet on the front airdam. thanks
Originally Posted by KaMLuNg
i kinda wish that i was able to cut a hole in my front bumper to expose the cold air right into my filter that is sitting behind my passenger side bumper lights... any ideas???
~Cheers~
i already have a CAI... ill post pics later.. it just bugs me that the airflow can't me more direct...
then i went to this
in this last photo where the filter sits... ill try to take a better pic, its about time i clean the filter... the bumper lense sits right in front of it... if it was removed, then it would be a perfect direct airflow straight into the filter... right now, the air comes in from the center and has obstacles to go through... i was thinking about buying a vent/scoop, cutting out a hole under the bumper lense, and making it look flush/finished... any ideas??? otherwise another option is to just remove the wheel lining and install a real scoop, but then you risk rocks and puddles...
Kam:
I wouldnt remove the wheel lining, like you pointed out you risk rocks and puddles. Right now you've probably done the best you can with our setup. Removing the intake resonator box is the biggest restriction.
thats looks great man! i took my resonator box out too and have the short ram in, but i was wondering what the Weapon R Ram Air Inlet looks like mounted to the front bumper. The tube connecting the inlet to the filter runs through the hole and down where the resonator box was. I was just wondering how the ram air inlet sat bolted onto the bumper.
Kam:
welcome back ken, how was your vacation??
I DID manage to swim across the Columbia river delta, considered one of the most dangerous in the world
(much to the dismay of my g/f and family)So.. I got something accomplished.
Cut short due to the awful weather. Oh well...
! ~Cheers~
Originally Posted by Kicker09
hey KaMLuNg, where did u pick up that strut tower bar??
I'm going to buy a 1st gen RL bar and see if it fits
yes u can get a brand new one from the dealer for under 50$... but i would look around maybe u get a used one.. i got mine 10 bucks... it is basically bolt on... but u may have to modify the firewall for the bolts.. i have a sticky writeup...
i checked out the sticky..thanks! I am putting an MSD ignition in late oct, hopefully everything goes smooth and i'll post pics
i gotta fix the pics...let us know how much the MSD helps...
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
