ETS Intercooler question
Old Apr 1, 2019 | 08:49 AM
mistryp's Avatar
Hi guys,
I've been trying to figure out which type of gasket I would need to put here. If I don't have a gasket there, will it throw any codes?
Which gasket should I use here? Can I just use hondabond?
Old Apr 1, 2019 | 05:08 PM
Tomtwtwtw's Avatar
I ended up using some generic liquid gasket material. If you don't, you will likely have a small boost leak. I personally never threw any codes, but after sealing that connection I had better throttle response and fuel economy - especially at low rpm.
We'll see how smart that was when I have to take it back apart for my next spark plug change though. haha
Old Apr 1, 2019 | 06:44 PM
mistryp's Avatar
lol. You can always just undo the hoses and leave the base of the bpv on still so you wouldn’t have to mess with that mess again.
im sealing mine with Honda bond right now.
Old Apr 5, 2019 | 09:40 PM
CSmoney28's Avatar
CSmoney28
Get one from the dealership it use the liquid type, let me know how it works out for you...
Old May 24, 2019 | 11:54 PM
tite681's Avatar
Does ETS still produce the RDX specific Intercooler? Their website says no.
Old May 26, 2019 | 11:51 AM
ljcolomacks's Avatar
Maybe order through Heeltoe.
https://www.heeltoeauto.com/intercoo..._rdx_tmic.html
Old May 26, 2019 | 09:24 PM
tite681's Avatar
Thanks @ljcolomacks I'll give them a call. Seems like I've developed a Heeltoe spending habit lately.
Old Aug 22, 2019 | 09:35 PM
tite681's Avatar
Just had this intercooler and a Turbosmart Kompact installed. Went for a short test drive and noticed the bypass valve is louder and sometimes makes a noise right before blowing off. I didn't feel a major performance gain, but it could be because I didn't reset the ECU. I'm using the Hondata K&N short ram base map. Hoping these extra mods are compatible and doesn't affect anything negatively.
Old Aug 31, 2019 | 07:07 PM
CSmoney28's Avatar
CSmoney28
Unplug the battery for at least five minutes to reset the computer. That’s should help you out.
Old Sep 2, 2019 | 04:32 PM
tite681's Avatar
Resetting the ECU did the trick. Still using the K&N Intake Base Map. No CELs and seems to be running well. I don't see how a little colder air will negatively affect the out the box tune.
Old Sep 2, 2019 | 07:09 PM
CSmoney28's Avatar
CSmoney28
Post
I'm glad the computer reset did the trick for you!
It's just cooler air, which is denser thus the power increase.
A dyno tune is the best way to optimism power, but the regular hondata tuner is fine for baseline tuning numbers.
jeremychrist
Mar 24, 2010 11:45 AM
kdawg8526
Jul 31, 2009 03:19 PM
moeronn
Home & Garden
Dec 14, 2007 03:11 PM
njzprettyboy
Sep 8, 2006 07:03 PM
