check engine light code- does anyone know what this means?
my check engine light was on so I went to Autozone and this is what they told me:
OBD code: 1298
Electric Load Dectector (ELD) Circuit
High Input
Probable causes:
1- poor electric connection
2- failed ELD
OBD code: 1298
High Input
Probable causes:
2- failed ELD
~[τΏτ]~
Either the Either the Electrical Load Detector (ELD) needs to be replaced, and/or there's a opening in the circuitry path between the PCM/ECM and ELD.
Year/Engine Size?
Year/Engine Size?
~[τΏτ]~
ELD Diagnostic Steps
Problem Verification:
1. Do the ECM/PCM Reset Procedure. (remove backup radio fuse for ~15 seconds)
2. Start the Engine.
3. Turn on headlights.
Q1. Does DTC P1298 appear?
NO -
1. Intermittent failure, system is OK at this time. Check for poor connections or loose wires at C256 (ELD) and ECM/PCM.
2. End of Diagnostics.
YES - Check for an open in the wire (GND line):
1. Turn the ignition switch and headlights OFF.
2. Disconnect the ELD 3P connector.
3. Check for continuity between body and round and ELD 3P connector terminal No. 1
4. Goto Q2.
Q2. Is there continuity?
NO -
1. Repair open in the wire between ELD connector and G402.
YES - Check for an open in the wire (EL line):
1. Disconnect the ECM/PCM connector A (32P).
2. Check for continuity between the ELD 3P connector terminal No. 2 and ECM/PCM connector terminal A30.
3. Goto Q3.
Q3. Is there continuity?
NO -
1. Repair open in the wire between the ELD connector and ECM/PCM.
YES - Check for a malfunction in the ELD:
1. Reconnect the ELD connector and ECM/PCM connector A (32P).
2. Start the engine and allow it to idle.
3. While measuring the voltage between the ECM/PCM connector terminals A30 and B20, turn the headlights on (low beam).
Q4. Does the voltage drop?
NO -
1. Replace ELD.
YES -
1. Substitute for a known-good PCM/PCM and recheck. If symptoms goes away replace the original ECM/PCM.
ASCII Art Fun
ELD 3P Connector (C256). This should plug into the ELD, which is located in the fuse box in the engine compartment.
│1│
│2│
│3│
ECM/PCM Connectors A (C32P)
│/ │2 │3 │4 │░░│5 │6 │7 │░░│8 │9 │10│11│
│12│13│14│15│/ │17│18│19│20│21│/ │23│24│
░░░░░░│25│26│27│░░│28│29│30│/ │░░│32│░░
Ahh.. Another productive work day in the IT world. Good luck in troubleshooting.
NO -
4. Goto Q2.
NO -
3. Goto Q3.
NO -
NO -
1. Replace ELD.
YES -
ASCII Art Fun
│1│
│2│
│3│
i got the guys at autozone to erase the codes so my check engine light would go off...so far the check engine light has not came back on....does that mean the problem is not that big of a deal?
thanks again!
thanks again!
vtec kicked in yo
dont bother with the code it wont throw a CEL on anyway i disconnected mine. all it does is restrict the alt from running when the car senses there is no load on the altinator. complete BS dont even worry about it
HeloDown
09-08-2015 06:51 PM
