check engine light code- does anyone know what this means?
Old Apr 20, 2007 | 03:04 PM
JORTS's Avatar
my check engine light was on so I went to Autozone and this is what they told me:
OBD code: 1298
Electric Load Dectector (ELD) Circuit
High Input
Probable causes:
1- poor electric connection
2- failed ELD
Old Apr 22, 2007 | 12:21 PM
Nakamichi's Avatar
~[τΏτ]~
Either the Either the Electrical Load Detector (ELD) needs to be replaced, and/or there's a opening in the circuitry path between the PCM/ECM and ELD.
Year/Engine Size?
Old Apr 22, 2007 | 06:48 PM
AznX TL's Avatar
where is....
by looking at his wheels it looks like a 99 2.3CL
Old Apr 23, 2007 | 04:05 PM
JORTS's Avatar
its a 1998 2.3 CL....
is that something that needs immediate attention?
is it an expensive cost?
thanks for the info!
Old Apr 25, 2007 | 09:56 PM
Nakamichi's Avatar
~[τΏτ]~
ELD Diagnostic Steps
Problem Verification:
1. Do the ECM/PCM Reset Procedure. (remove backup radio fuse for ~15 seconds)
2. Start the Engine.
3. Turn on headlights.
Q1. Does DTC P1298 appear?
NO -
1. Intermittent failure, system is OK at this time. Check for poor connections or loose wires at C256 (ELD) and ECM/PCM.
2. End of Diagnostics.
YES - Check for an open in the wire (GND line):
1. Turn the ignition switch and headlights OFF.
2. Disconnect the ELD 3P connector.
3. Check for continuity between body and round and ELD 3P connector terminal No. 1
4. Goto Q2.
Q2. Is there continuity?
NO -
1. Repair open in the wire between ELD connector and G402.
YES - Check for an open in the wire (EL line):
1. Disconnect the ECM/PCM connector A (32P).
2. Check for continuity between the ELD 3P connector terminal No. 2 and ECM/PCM connector terminal A30.
3. Goto Q3.
Q3. Is there continuity?
NO -
1. Repair open in the wire between the ELD connector and ECM/PCM.
YES - Check for a malfunction in the ELD:
1. Reconnect the ELD connector and ECM/PCM connector A (32P).
2. Start the engine and allow it to idle.
3. While measuring the voltage between the ECM/PCM connector terminals A30 and B20, turn the headlights on (low beam).
Q4. Does the voltage drop?
NO -
1. Replace ELD.
YES -
1. Substitute for a known-good PCM/PCM and recheck. If symptoms goes away replace the original ECM/PCM.
ASCII Art Fun
ELD 3P Connector (C256). This should plug into the ELD, which is located in the fuse box in the engine compartment.
│1│
│2│
│3│
ECM/PCM Connectors A (C32P)
│/ │2 │3 │4 │░░│5 │6 │7 │░░│8 │9 │10│11│
│12│13│14│15│/ │17│18│19│20│21│/ │23│24│
░░░░░░│25│26│27│░░│28│29│30│/ │░░│32│░░
Ahh.. Another productive work day in the IT world. Good luck in troubleshooting.
Old Apr 26, 2007 | 12:51 PM
JORTS's Avatar
i got the guys at autozone to erase the codes so my check engine light would go off...so far the check engine light has not came back on....does that mean the problem is not that big of a deal?
thanks again!
Old Apr 26, 2007 | 02:39 PM
Nakamichi's Avatar
~[τΏτ]~
Probably just a fluke (loose connections, etc). I say don't worry about it. If the light comes on, go through the troubleshooting procedures above.
Old Feb 28, 2013 | 07:11 PM
shawncyr's Avatar
5th Gear
Hi,
Regarding the ELD 3P connector in the fuse box, is pin 1 or pin 3 the pin closest to the firewall?
I wasn't sure what the double line above the "1" indicated.
Thanks.
Old Mar 11, 2013 | 11:57 PM
antonio3rd's Avatar
vtec kicked in yo
dont bother with the code it wont throw a CEL on anyway i disconnected mine. all it does is restrict the alt from running when the car senses there is no load on the altinator. complete BS dont even worry about it
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
