Car won't start, please help
Old Jun 20, 2007 | 09:12 PM
horsey2k's Avatar
B A N N E D
When I start my car, it clicks many times, with interior lights flickering. Also I can't turn on the headlight. when I turn the headlight switch on, the interior lights flickering and headlight not on. Is it a starter problem?
Old Jun 20, 2007 | 09:33 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Do all the gauges and lights come on in the car?
Old Jun 20, 2007 | 09:40 PM
horsey2k's Avatar
B A N N E D
Yes, i can also listen the cd. power windows, sunroof, etc are working. but when I turn on the headlight, all the interior light is flickering and the headlight not on. It"s the same situation when I turn on the key
Old Jun 20, 2007 | 09:42 PM
(Mid-Atlantic)
You have a loose ground somewhere
Old Jun 20, 2007 | 09:57 PM
horsey2k's Avatar
B A N N E D
LoL, I just checked all the wires that connect to the battery, they are very tight.
Is it a big trouble on my car?
Old Jun 20, 2007 | 09:58 PM
AznX TL's Avatar
where is....
i think its your battery, my bros car did this, i could work everything until i tried to start the car. then everything would stop working. but it could also be a loose ground, when i had a loose ground nothing worked though.
Old Jun 20, 2007 | 10:07 PM
horsey2k's Avatar
B A N N E D
Could you please tell me where I can check for loose ground? I only know the one that connects the negative of the battery to the body.
Old Jun 20, 2007 | 10:44 PM
AznX TL's Avatar
where is....
there should be 2 grounds coming off the negative.
do you have a 2.x or 3.0?
Old Jun 20, 2007 | 10:47 PM
Sleep_DEPRIVED_Sleeper's Avatar
Turtle Charged, Biotcch!!
The car clicks when you turn the key? I sounds like the starter is bad...
Old Jun 20, 2007 | 10:48 PM
AznX TL's Avatar
where is....
dead battery also clicks.
definitely say give jump start a try.
Old Jun 20, 2007 | 11:27 PM
(Mid-Atlantic)
Try jump starting the car first, if it starts with a charge, it's the battery. If it still clicks it's the starter
Old Jun 21, 2007 | 02:49 AM
horsey2k's Avatar
B A N N E D
Thank you guys. My car is a 97 2.2CL. I just tried the jump start, and my car did start. I let the car run for about 10 minutes and drove around for 20 minutes. When I turned off the car and try to start again, I was in the same situation. I heard many times clicking sounds. Should I change the battery?
One more thing, when I jumped the battery from another car, my car couldn't start immediately, I had to wait about 5 minutes, and then the car started.
LoL, it took me all day to figure out what's wrong with my car, but the problem is still not figured out.
Old Jun 21, 2007 | 03:57 AM
It is your starter, not the battery. Just take it off (easy, 2-3 bolts) and bring it to Autozone or Kragen to test it. I think it's free or very cheap to test. If it's really bad then get one online and install it yourselves...
btw, you can jumpstart the car and drive to Autozone or Kragen, then take off the starter there etc. if you don't have another way to get there....
Old Jun 21, 2007 | 04:43 AM
subbuzz's Avatar
07 tl-s in
alittle more info would help some, any ind lights on?are your light's dimmer than normal? does it start sometimes and not others?
the starter you'll have power but it'll click and not try to turn over when you try to start. the clicking is why your light's were flickering.(interruption of power)my guess is a power problem, your car might not be getting enough juice to start.your batt is not holding a charge or your alt is not charging your batt.
Disconnect your battery while the car is running. If the car cuts off, you need a new alternator. If it stays on,it's fine.
i've replaced all 3 items(starter/batt/alt)on my lemon that i love. when my starter went i tried to jump it and bang on it and it was a no-go, so that's why i think you may have a power issue..
Old Jun 21, 2007 | 09:42 AM
732xghost's Avatar
the starter doesnt make a clicking noise. it makes almost a grinding noise. and when my starter went nothing flickered, the car just took forever or wouldnt start, so i would have to pop start it.
Old Jun 21, 2007 | 04:09 PM
AznX TL's Avatar
where is....
so im assuming it was the battery as stated in the other thread?
nice!
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
jordanboi
Sep 5, 2015 01:33 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
