1999 Acura CL 2.3 battery Cables
Old Jul 22, 2010 | 06:31 PM
oceanna's Avatar
My negative battery terminal is so corroded that the car won't start once in a while. Once I clean the terminals and tighten the terminal it'll start right up. I'm positive it's the corrosion on the negative cable. I've gone to 3 automotive stores in my area and no one seems to have them. I've also looked online to find a replacement but haven't been successful finding cables for an Acura CL anywhere! Can anyone steer me in the right direction. Any help would be much appreciated
Michelle
Old Jul 22, 2010 | 07:34 PM
P0401's Avatar
I think you would need #10 in this photo http://www.acuraoemparts.com/delray/...All&vinsrch=no
you can probably write the part number down and get it from your local Acura/Honda dealer, the part number is 32600-SY8-900
Old Jul 22, 2010 | 09:38 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
I just made my own
Old Jul 23, 2010 | 11:46 AM
sickcl480's Avatar
I would go to a dealer first. If that does not work I would go to a car audio shop and get some large diameter ground wire with a battery ground terminal and whatever connector you need for the other end.
Old Jul 23, 2010 | 01:24 PM
mattastick's Avatar
Ring terminals.
OP, go get a basic battery connector and some 8-4awg wire and reground your battery. It literally takes 4 ring terminals, ~3' of wire and whatever battery post connector you want to use. Took me about 10-15 minutes to reground my battery.
Old Jul 23, 2010 | 02:00 PM
sickcl480's Avatar
Originally Posted by mattastick
Ring terminals.
Also make sure you put some battery terminal grease on to keep them from corroding again. It's like $0.99 at auto zone and it really does work. I went through several terminals before I learned that.
Old Jul 23, 2010 | 03:07 PM
(Mid-Atlantic)
They also have universal battery ground cables that you can buy as well
Old Jul 23, 2010 | 08:45 PM
saiko_cl_duck's Avatar
go to advance/autozone/etc...get a battery terminal, strip wire, clean wire, install.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
adreano17
Sep 16, 2015 02:54 PM
jordanboi
Sep 5, 2015 01:33 AM
